  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • ben999B
    ben999B
    ben999
    Hi
    Can we talk about redundancy please? What if one or more sensor fail on a one-wire bus? Would it make the whole line unusable?
    As part of a central heating MySensorization i would like to have groups of 3 sensors and have some sort of redundancy check.
    Would i be allowed to run multiple one-wire busses on a single arduino?
    Thanks a lot foryour help
    • ben999B ben999
      Hi
      @ben999 you can have as many onewire buses as you have digital pins. Just add more of these:
      ben999B 1 Reply Last reply
        ben999B
        ben999B
        ben999
        @mfalkvidd thanks a lot. Yes, that looks good to me. I will have a go.
        The real big question now is about what happens when one or more sensor fails on the line.
        I am not talking about removing a sensor, which doesn't produce any fault.
        My concern is how does a DS18 ends its life under normal operation? Complete shortcut?
        mfalkviddM zboblamontZ 2 Replies Last reply
        • ben999B ben999
          @ben999 I don't think there are any guarantees on how it will fail. If there are, the datasheet should list them.
          • ben999B ben999
            zboblamontZ
            zboblamontZ
            zboblamont
            @ben999 I cannot remember WHERE I read it, but if a DS18B20 fails it will either send impossible results when addressed or fail to be addressed at all as it is digitally addressed. Only cable short circuits can pull the entire chain down, as I found out when two socket pins had crossed over (sensor crimped into telephone plugs).
              ben999B
              ben999B
              ben999
              @mfalkvidd thank you for the idea. Had a look (boooooring reading for me :D ) but no mention to failiure
              @zboblamont you're right. Seems that a faulty sensor return "85" (top of my head). And a "dead" sensor looses its bus address (next sensor on the chain takes its address and so on)
              Thanks a lot gentlemen :)
              rejoe2R 1 Reply Last reply
              • ben999B ben999
                rejoe2R
                rejoe2R
                rejoe2
                @ben999 said in 💬 Temperature Sensor:
                That's not exactly right. Each of the 1-wire devices uses a hardcoded, unique address that can not be changed.
                So if you use the standard sketch with multiple DS18B20, in case of detached or replaced sensors you may get reported the measured temperatures comming from the same physical DS18B20 device under a different ChildID (after node reboot). To avoid effects like that, one has to take additional measures as described here . In short:
                • Use an array with the physical ID's to address them
                • Store a hash-array (done automatically) to identify "known" physical ID's that have once been attached to the bus as well as the ChildID used for MySensors.
                • rejoe2R rejoe2
                  ben999B
                  ben999B
                  ben999
                  @rejoe2 oooooooooh great! thanks a lot, exactly what i was looking for !!!
                  • ben999B ben999
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @ben999 You are welcome :grinning:
                    • P
                      P
                      pintman
                      When I try to compile the sketch for an ESP8266 I get an error in DallasTemperature.h which results in an error in OneWire.h
                      OneWire.h:108:2: error: #error "Please define I/O register types here"  #error "Please define I/O register types here"
                      Is it possible to make the sensor run on an ESP?
                      • cashew75C
                        cashew75C
                        cashew75
                        Hi, I'm having a hard time getting this Temperatursensor to work with Home Assistant. When i start it it doesn't register with the HA. If I use the same hardware and switch out the sensor to a DHT sensor (new sketch of course) then it works out of the box, HA sees the sensor. I've tried changing the Dallas DS18B20, but nothing. If i look at the logs the gateway have no problem with the sensor. Is there something in the code for the sensor that doesn't add up to it being presented to HA in the right way? I'm quite the newbie when it comes to programming.
                          Have you tried another controller like mycontroller?
                          cashew75C 1 Reply Last reply
                            cashew75C
                            cashew75C
                            cashew75
                            @gohan No I have not. I have a RF-Link also connected to the HA and it's working great. As I said, if I use the same hardware that I used to control the Dallas sensor and change the sensor to a DHT sensor the DHT sensor is accepted by HA and shows up as a sensor. That's why I was asking if there is something in the code for the Temperature sensor sketch that has to be changed to be able to present it to HA.
                              pls post the code that is not working
                                cashew75C
                                cashew75C
                                cashew75
                                @gohan Thanks for the quick reply! Well I've use the standard sketch for this Temperatur sensor. This is the code i've got.
                                #include <OneWire.h>
                                int numSensors=0;
                                bool receivedConfig = false;
                                bool metric = true;
                                MyMessage msg(0,V_TEMP);
                                void before()
                                  sensors.begin();
                                     present(i, S_TEMP);
                                  sleep(conversionTime);
                                    #if COMPARE_TEMP == 1
                                  sleep(SLEEP_TIME);
                                • pepsonP
                                  pepsonP
                                  pepson
                                  Anybody has sketch for sensors dallas DS18b20 with identify it with ID Dallas ?
                                  And i can change value 16 to more sensors ? Example 20 ?
                                  • A
                                    APL2017
                                    Looking at code example it seems to be sufficient to set bool metric = false to get readings in Fahrenheit, but node still returns readings in C. Any idea why?
                                    • A APL2017
                                      @apl2017 if I'm looking at the same sketch as you are looking at, the metric variable is never used. getControllerConfig() is used to fetch the controller's metric setting instead.
                                      • R Rene046
                                        I sofar got the sketch running and giving good data on serial and into domoticz
                                        i only could use some help with how to sent my Temperature in Celsius to domoticz to
                                        i tried to use:
                                        send(msgTemp.set(insideThermometer ,2));
                                        and
                                        send(msgTemp.set(tempC,2));
                                        both without luck, the first did transmit some data but wrong numbers
                                        second did nothing think because with this i done i does not know what address the DS1820 is on.
                                        Im learning every day something new....
                                        Maybe someone could help,
                                        G
                                        G
                                        gniazdoj
                                        @Rene046
                                        Hi guys
                                        Hi
                                        can you advice how to manage Domoticz to display 2 decimals under Temperature sensors page, when following line MsgTemp.set(temperature,2) I can see on arduino serial monitor, mysensors sent 20.75 value, the same value i can see under child item with Hardware tab but not on sensor where 20.75*C is rounded to 20.8. its fine for general log but i want to have stable temperature for heating system. I have added code to count average from last X records like 20 or 40 with 0.25 steps, this stabilize Heating system and protect it against on/off to frequently.
                                        Additionally when i use JSON it will present proper value under sensor page, same with ESPEasy and 2 decimal configuration on ESP.
                                        do you know how i can changed domoticz to force him to present 2 decimals?
                                        Mysensors 2.3.1/2.3.2
                                        Domoticz 4.10717
                                        raspberry pi
                                        Thank you
                                        Jakub
                                        K 1 Reply Last reply
                                        • G gniazdoj
                                          @Rene046
                                          Hi guys
                                          Hi
                                          Domoticz 4.10717
                                          raspberry pi
                                          Thank you
                                          Jakub
                                          K
                                          K
                                          kimot
                                          Domoticz globally or only with MySensors ?
                                          My Domoticz is the same version like yours.
                                          Temperatures from ESPeasy are with two decimals on Temperature sensors page, but on devices page only one decimal.
                                          Exactly the opposite like you wrote.
                                          G 1 Reply Last reply
