  2. Bug Reports
  3. Possible Bug version 2.2.0
38 Posts 4 Posters 8.1k Views 3 Watching
  • S sindrome73
    Ok tomorrow calmly I will make these changes and update you .... A Tomorrow, and thanks for now .....
    AnticimexA
    AnticimexA
    Anticimex
    @sindrome73 I'm off to bed as well. Good night and we will figure something out later on.
    • S sindrome73
      alexsh1A
      alexsh1A
      alexsh1
      @sindrome73 You can try to load a default sketch from examples with signing to make sure everything is working fine.
      If you are out of memory, strange things may happen.
      • AnticimexA
        AnticimexA
        Anticimex
        https://www.mysensors.org/apidocs/group__memorysavings.html
        alexsh1A 1 Reply Last reply
        • AnticimexA Anticimex
          alexsh1A
          alexsh1A
          alexsh1
          #31
          @anticimex I must admit that in the world of ESP32 or SAMD I find atmega328p memory restriction more and more an issue. Its ok for 1 sensor and signing, but on some nodes I have 3-4 sensors and debugging and signing have to be disabled due to memory constrains.
          BTW, some nodes do behave strangely even when you approach memory limit.
          Having said that, I think we need to establish if @sindrome73 node is working fine - a default sketch plus signing would reveal it.
          AnticimexA 1 Reply Last reply
          • alexsh1A alexsh1
            AnticimexA
            AnticimexA
            Anticimex
            @alexsh1 sensors behave strange because stack space is consumed.
            Regarding signing and 2.2.0, I know for a fact it works, and I have tested it on atmega328p. But sure, trying with the secure actuator sketch should help reveal if the problem lies with the GW.
              sindrome73
              Hello!! Sorry if I'm late.....
              So I tried to do the checks as suggested .....
              If I load the schetck with Mysensors Ver 2.1 the Arduino IDE gives me 28620 Bytes used 93% of the space
              If I load the schetck with Mysensors Ver 2.2 the IDE of Arduino gives me 29310 Bytes used 95% of the space
              So it could be a problem of space and therefore makes my Arduino Pro unstable .....
              Tomorrow I'll try to load the same Scketch on An Arduino Uno that should have a little more space ..... I keep you updated on the developments
              AnticimexA alexsh1A 2 Replies Last reply
              • S sindrome73
                AnticimexA
                AnticimexA
                Anticimex
                @sindrome73 anything above 90% puts you well into the danger zone. Stack space is what is left after linker has placed the symbols. And the atmega328p has little ram so less than 10% of that ram is not much for the stack. I don't have the numbers of the library worst case stack usage but it depend heavily on what features you use and in the order they are used, and so on.
                • S sindrome73
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @sindrome73 Try to load any sketch from MySensors examples just to see if everything is working fine with v2.2.0. If you are running out of memory its a good practice to try the sketch on Mega or SAMD (more cpu+memory)
                  S 1 Reply Last reply
                  • alexsh1A alexsh1
                    sindrome73
                    Other sketches work, already tried !! And this from problems with 2.2
                    • S sindrome73
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @sindrome73 said in Possible Bug version 2.2.0:
                      If other sketches work with v2.2.0, the problem is 100% in low memory.
                      I had similar issue with my dust sensor - 98% memory was used. The node was unstable and froze on many occasions. I had to reduce the sketch.
                        mickecarlsson
                        Test if this reduces your memory consumption.
                        This is what I have added
                        Disable the splash screen with:
                        #define MY_SPLASH_SCREEN_DISABLED // This saves a couple of bytes
                        Then for every serial.print I have embedded those with #ifdef MY_DEBUG/#endif
                        There is no need to serial print when running in silent mode.
                        I have also embedded the missing serial.print with the F("string") function.
                        This saves memory by storing strings in flash instead of memory.
                        I could not get the code to compile as I don't have the proper DHT library.
                        // ---- - Stazione Meteo Francy Ver 1 - ----
                        // Enable debug prints
                        // #define MY_DEBUG
                        #define MY_PARENT_NODE_ID 0
                        #define   MY_RF24_CHANNEL 84
                        #define MY_SIGNING_SOFT
                        // Definisco il Nodo
                        #define MY_NODE_ID 66
                        // Nomino i figli del Nodo
                        #define CHILD_ID_TEMP 1
                        #define CHILD_ID_aaaa 2
                        #define CHILD_ID_HUMI 3
                        #define CHILD_ID_bbbb 4
                        #define CHILD_ID_BARO 5
                        #define CHILD_ID_LIGHT 6
                        const float ALTITUDE = 335;
                        //----------------------------- Pressione
                        //float pressione = 1017;
                        //int forecast = 4;
                        const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
                        enum FORECAST
                            STABLE = 0,            // "Stable Weather Pattern"
                            SUNNY = 1,            // "Slowly rising Good Weather", "Clear/Sunny "
                            CLOUDY = 2,            // "Slowly falling L-Pressure ", "Cloudy/Rain "
                            UNSTABLE = 3,        // "Quickly rising H-Press",     "Not Stable"
                            THUNDERSTORM = 4,    // "Quickly falling L-Press",    "Thunderstorm"
                            UNKNOWN = 5            // "Unknown (More Time needed)
                        #include <Adafruit_BMP085.h>
                        DHT dht;
                        Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
                        float lastPressure = -1;
                        float lastTemp = -1;
                        int lastForecast = -1;
                        const int LAST_SAMPLES_COUNT = 5;
                        float lastPressureSamples[LAST_SAMPLES_COUNT];
                        // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
                        // get kPa/h be dividing hPa by 10
                        #define CONVERSION_FACTOR (1.0/10.0)
                        int minuteCount = 0;
                        bool firstRound = true;
                        // average value is used in forecast algorithm.
                        float pressureAvg;
                        // average after 2 hours is used as reference value for the next iteration.
                        float pressureAvg2;
                        float dP_dt;
                        bool metric;
                        //Dichiarazioni per pause dei diversi blocchi
                        unsigned long int time;
                        unsigned long int lettura_Press;
                        unsigned long int lettura_Temp;
                        unsigned long int letturaluce_time;
                        int lastLightLevel; //Dichiarazione Luminosita
                        float temperatureDTH2;
                          sendSketchInfo("Temp e Umidita", "3");
                          present(CHILD_ID_aaaa, S_LIGHT);
                          present(CHILD_ID_HUMI, S_HUM);
                          present(CHILD_ID_bbbb, S_LIGHT);
                          present(CHILD_ID_BARO, S_BARO);
                        MyMessage msgaaaa(CHILD_ID_HUMI, V_LIGHT);
                        MyMessage msgHumi(CHILD_ID_HUMI, V_HUM);
                        MyMessage msgbbbb(CHILD_ID_HUMI, V_LIGHT);
                        MyMessage msgPres(CHILD_ID_BARO, V_PRESSURE);
                        MyMessage msgForecast(CHILD_ID_BARO, V_FORECAST);
                        MyMessage msg4(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                          // Setto il Pin dove e collegato il sensore di Temperatura DHT22
                          dht.setup(3);
                        #ifdef MY_DEBUG
                          //Settaggi del BMP180
                              if (!bmp.begin())
                                Serial.println(F("Could not find a valid BMP085 sensor, check wiring!"));
                                while (1) {}
                          //Fine settaggi BMP180
                        //-- Setup Variabili MILLIS per sensore di Pressione
                        time=millis();
                        lettura_Press = millis();
                        lettura_Temp = millis();
                        letturaluce_time = millis();
                        //Attivo Time MILLIS
                        time=millis();
                        //----------- Inizio DHT22 ------------------------
                        if(time>lettura_Temp+12000){
                        #ifdef MY_DEBUG
                        Serial.println(F("--- Temperatura ---  "));
                        float temperatureDTH;
                        float temperatureDHT = dht.getTemperature();
                        temperatureDTH2 = temperatureDTH;
                         //Invio la lettura della Temperatura
                          send(msgTemp.set(temperatureDHT, 1));
                          //delay(6000); // Faccio una pausa ed invio altra lettura
                         //Invio lettura Umidita
                          send(msgHumi.set(humidity, 1));
                          //delay(4000);
                        lettura_Temp=millis();
                        //---------- Inizio Pressione ---------------------------
                        if(time>lettura_Press+11000){
                        #ifdef MY_DEBUG
                        Serial.println(F("--- Tempo passato lego la Pressione---  "));
                        float temperatureDHT2;
                        float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
                        float temperature = temperatureDHT2;
                        if (!metric)
                                // Convert to fahrenheit
                                temperature = temperature * 9.0 / 5.0 + 32.0;
                        int forecast = sample(pressure);
                        #ifdef MY_DEBUG
                            Serial.print(F("Pressione = "));
                            Serial.print(pressure);
                            Serial.println(F(" hPa"));
                            Serial.print(F("Forecast = "));
                         if (pressure != lastPressure)
                                send(msgPres.set(pressure, 0));
                                lastPressure = pressure;
                        if (forecast != lastForecast)
                                send(msgForecast.set(weather[forecast]));
                                lastForecast = forecast;
                        lettura_Press=millis();
                        //-------------- Inizio Luminosita --------------------------
                        if(time>letturaluce_time+10000){
                        #ifdef MY_DEBUG
                        Serial.print(F("Tempo passato lego la Luce: "));
                            int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                        #ifdef MY_DEBUG
                            Serial.println(lightLevel);
                            //delay(1000);
                               if(lightLevel > lastLightLevel + 7 || lightLevel < lastLightLevel - 7){
                                send(msg4.set(lightLevel));
                        #ifdef MY_DEBUG
                                Serial.print(F("Invio nuova lettura LUX: "));
                                lastLightLevel = lightLevel;
                        letturaluce_time=millis();
                            //Fine Luminosita
                        //--------- Eventuale 4 Modulo -------------------------
                        // Chiusura Loop
                        //------------ Aggiuntivo Previsione del Barometro ---------------------
                        float getLastPressureSamplesAverage()
                            float lastPressureSamplesAverage = 0;
                            for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                                lastPressureSamplesAverage += lastPressureSamples[i];
                            lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                            return lastPressureSamplesAverage;
                        // Algorithm found here
                        // Pressure in hPa -->  forecast done by calculating kPa/h
                        int sample(float pressure)
                            // Calculate the average of the last n minutes.
                            int index = minuteCount % LAST_SAMPLES_COUNT;
                            lastPressureSamples[index] = pressure;
                            minuteCount++;
                            if (minuteCount > 185)
                                minuteCount = 6;
                            if (minuteCount == 5)
                                pressureAvg = getLastPressureSamplesAverage();
                            else if (minuteCount == 35)
                                float lastPressureAvg = getLastPressureSamplesAverage();
                                float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                                    dP_dt = change * 2; // note this is for t = 0.5hour
                                    dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
                            else if (minuteCount == 65)
                                    dP_dt = change; //note this is for t = 1 hour
                                    dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
                            else if (minuteCount == 95)
                                    dP_dt = change / 1.5; // note this is for t = 1.5 hour
                                    dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
                            else if (minuteCount == 125)
                                pressureAvg2 = lastPressureAvg; // store for later use.
                                    dP_dt = change / 2; // note this is for t = 2 hour
                                    dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
                            else if (minuteCount == 155)
                                    dP_dt = change / 2.5; // note this is for t = 2.5 hour
                                    dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
                            else if (minuteCount == 185)
                                    dP_dt = change / 3; // note this is for t = 3 hour
                                    dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
                                pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                            int forecast = UNKNOWN;
                                forecast = UNKNOWN;
                            else if (dP_dt < (-0.25))
                                forecast = THUNDERSTORM;
                            else if (dP_dt > 0.25)
                                forecast = UNSTABLE;
                                forecast = CLOUDY;
                                forecast = SUNNY;
                            else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
                                forecast = STABLE;
                                forecast = UNKNOWN;
                            // uncomment when debugging
                        #ifdef MY_DEBUG
                            Serial.print(F("Forecast at minute "));
                            Serial.print(minuteCount);
                            Serial.print(F(" dP/dt = "));
                            Serial.print(dP_dt);
                            Serial.print(F("kPa/h --> "));
                            return forecast;
