  2. Bug Reports
  3. Possible Bug version 2.2.0
38 Posts 4 Posters 8.1k Views 3 Watching
  • S sindrome73
    tell me how to abbilitate the detailed signature debug .....
    AnticimexA
    AnticimexA
    Anticimex
    @sindrome73 https://www.mysensors.org/apidocs-beta/group__MySigningTroubleshootinggrp.html
      sindrome73
      Here is the log with the Debug signed abbreviation.
      I specify that I had to disable // # define MY_DEBUG because the scketch is too big
      • S sindrome73
        AnticimexA
        AnticimexA
        Anticimex
        @sindrome73 signing messages look sane. But the logs look very corrupt. It also looks like the sketch crashed and restarted so I suspect you are running out of stack space. The arduino IDE reports and warns about memory usage and I suspect you get a warning on that.
          sindrome73
          Yes indeed I have already said this !! So true that to have the DEBUG of the signature I had to disable the DEBUG.
          But with this same script, and going to Mysensors 2.1 it works !!
          AnticimexA 1 Reply Last reply
          • S sindrome73
            AnticimexA
            AnticimexA
            Anticimex
            @sindrome73 you could try to completely disable debug on your node and observe the behavior of your gw or controller.
              sindrome73
              Ok .... Tomorrow I'll do it ..... But it will be difficult to have the Gateway Log because with the signature enabled, the sketch is very large, and does not allow me to activate the Debug ....
              • S sindrome73
                AnticimexA
                AnticimexA
                Anticimex
                @sindrome73 well, 2.2.0 could be requiring more memory than 2.1. You can compare since the IDE reports exactly how much memory is used.
                  sindrome73
                  But it is the same with both 2.2 and 2.1.
                  With Arduino Pro Mini, enabling the signature debugging must be disabled because it exceeds counque the maximum available memory .......
                  • S sindrome73
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @sindrome73 you could see in your controller if communication gets though. I could see in the node log that signing handshaking takes place. So I am sure your problem is memory use. You need to reduce the size of your sketch. Or get more powerful hardware to support the features you want to use.
                      sindrome73
                      Ok tomorrow calmly I will make these changes and update you .... A Tomorrow, and thanks for now .....
                      AnticimexA alexsh1A 2 Replies Last reply
                      • S sindrome73
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @sindrome73 I'm off to bed as well. Good night and we will figure something out later on.
                        • S sindrome73
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @sindrome73 You can try to load a default sketch from examples with signing to make sure everything is working fine.
                          If you are out of memory, strange things may happen.
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            https://www.mysensors.org/apidocs/group__memorysavings.html
                            alexsh1A 1 Reply Last reply
                            • AnticimexA Anticimex
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #31
                              @anticimex I must admit that in the world of ESP32 or SAMD I find atmega328p memory restriction more and more an issue. Its ok for 1 sensor and signing, but on some nodes I have 3-4 sensors and debugging and signing have to be disabled due to memory constrains.
                              BTW, some nodes do behave strangely even when you approach memory limit.
                              Having said that, I think we need to establish if @sindrome73 node is working fine - a default sketch plus signing would reveal it.
                              • alexsh1A alexsh1
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @alexsh1 sensors behave strange because stack space is consumed.
                                Regarding signing and 2.2.0, I know for a fact it works, and I have tested it on atmega328p. But sure, trying with the secure actuator sketch should help reveal if the problem lies with the GW.
                                  sindrome73
                                  Hello!! Sorry if I'm late.....
                                  So I tried to do the checks as suggested .....
                                  If I load the schetck with Mysensors Ver 2.1 the Arduino IDE gives me 28620 Bytes used 93% of the space
                                  If I load the schetck with Mysensors Ver 2.2 the IDE of Arduino gives me 29310 Bytes used 95% of the space
                                  So it could be a problem of space and therefore makes my Arduino Pro unstable .....
                                  Tomorrow I'll try to load the same Scketch on An Arduino Uno that should have a little more space ..... I keep you updated on the developments
                                  • S sindrome73
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @sindrome73 anything above 90% puts you well into the danger zone. Stack space is what is left after linker has placed the symbols. And the atmega328p has little ram so less than 10% of that ram is not much for the stack. I don't have the numbers of the library worst case stack usage but it depend heavily on what features you use and in the order they are used, and so on.
                                    • S sindrome73
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @sindrome73 Try to load any sketch from MySensors examples just to see if everything is working fine with v2.2.0. If you are running out of memory its a good practice to try the sketch on Mega or SAMD (more cpu+memory)
                                      S 1 Reply Last reply
                                      • alexsh1A alexsh1
                                        sindrome73
                                        Other sketches work, already tried !! And this from problems with 2.2
                                        • S sindrome73
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @sindrome73 said in Possible Bug version 2.2.0:
                                          If other sketches work with v2.2.0, the problem is 100% in low memory.
                                          I had similar issue with my dust sensor - 98% memory was used. The node was unstable and froze on many occasions. I had to reduce the sketch.
