  2. Bug Reports
  3. Possible Bug version 2.2.0
38 Posts 4 Posters 8.1k Views 3 Watching
  • S sindrome73
    Ok tomorrow calmly I will make these changes and update you .... A Tomorrow, and thanks for now .....
    alexsh1A
    alexsh1A
    alexsh1
    @sindrome73 You can try to load a default sketch from examples with signing to make sure everything is working fine.
    If you are out of memory, strange things may happen.
    • AnticimexA
      AnticimexA
      Anticimex
      https://www.mysensors.org/apidocs/group__memorysavings.html
      alexsh1A 1 Reply Last reply
      • AnticimexA Anticimex
        alexsh1A
        alexsh1A
        alexsh1
        #31
        @anticimex I must admit that in the world of ESP32 or SAMD I find atmega328p memory restriction more and more an issue. Its ok for 1 sensor and signing, but on some nodes I have 3-4 sensors and debugging and signing have to be disabled due to memory constrains.
        BTW, some nodes do behave strangely even when you approach memory limit.
        Having said that, I think we need to establish if @sindrome73 node is working fine - a default sketch plus signing would reveal it.
        AnticimexA 1 Reply Last reply
        • alexsh1A alexsh1
          AnticimexA
          AnticimexA
          Anticimex
          @alexsh1 sensors behave strange because stack space is consumed.
          Regarding signing and 2.2.0, I know for a fact it works, and I have tested it on atmega328p. But sure, trying with the secure actuator sketch should help reveal if the problem lies with the GW.
            sindrome73
            Hello!! Sorry if I'm late.....
            So I tried to do the checks as suggested .....
            If I load the schetck with Mysensors Ver 2.1 the Arduino IDE gives me 28620 Bytes used 93% of the space
            If I load the schetck with Mysensors Ver 2.2 the IDE of Arduino gives me 29310 Bytes used 95% of the space
            So it could be a problem of space and therefore makes my Arduino Pro unstable .....
            Tomorrow I'll try to load the same Scketch on An Arduino Uno that should have a little more space ..... I keep you updated on the developments
            AnticimexA alexsh1A 2 Replies Last reply
            • S sindrome73
              AnticimexA
              AnticimexA
              Anticimex
              @sindrome73 anything above 90% puts you well into the danger zone. Stack space is what is left after linker has placed the symbols. And the atmega328p has little ram so less than 10% of that ram is not much for the stack. I don't have the numbers of the library worst case stack usage but it depend heavily on what features you use and in the order they are used, and so on.
              • S sindrome73
                alexsh1A
                alexsh1A
                alexsh1
                @sindrome73 Try to load any sketch from MySensors examples just to see if everything is working fine with v2.2.0. If you are running out of memory its a good practice to try the sketch on Mega or SAMD (more cpu+memory)
                S 1 Reply Last reply
                • alexsh1A alexsh1
                  sindrome73
                  Other sketches work, already tried !! And this from problems with 2.2
                  • S sindrome73
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @sindrome73 said in Possible Bug version 2.2.0:
                    If other sketches work with v2.2.0, the problem is 100% in low memory.
                    I had similar issue with my dust sensor - 98% memory was used. The node was unstable and froze on many occasions. I had to reduce the sketch.
                      mickecarlsson
                      Test if this reduces your memory consumption.
                      This is what I have added
                      Disable the splash screen with:
                      #define MY_SPLASH_SCREEN_DISABLED // This saves a couple of bytes
                      Then for every serial.print I have embedded those with #ifdef MY_DEBUG/#endif
                      There is no need to serial print when running in silent mode.
                      I have also embedded the missing serial.print with the F("string") function.
                      This saves memory by storing strings in flash instead of memory.
                      I could not get the code to compile as I don't have the proper DHT library.
                      // ---- - Stazione Meteo Francy Ver 1 - ----
                      // Enable debug prints
                      // #define MY_DEBUG
                      #define MY_PARENT_NODE_ID 0
                      #define   MY_RF24_CHANNEL 84
                      #define MY_SIGNING_SOFT
                      // Definisco il Nodo
                      #define MY_NODE_ID 66
                      // Nomino i figli del Nodo
                      #define CHILD_ID_TEMP 1
                      #define CHILD_ID_aaaa 2
                      #define CHILD_ID_HUMI 3
                      #define CHILD_ID_bbbb 4
                      #define CHILD_ID_BARO 5
                      #define CHILD_ID_LIGHT 6
                      const float ALTITUDE = 335;
                      //----------------------------- Pressione
                      //float pressione = 1017;
                      //int forecast = 4;
                      const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
                      enum FORECAST
                          STABLE = 0,            // "Stable Weather Pattern"
                          SUNNY = 1,            // "Slowly rising Good Weather", "Clear/Sunny "
                          CLOUDY = 2,            // "Slowly falling L-Pressure ", "Cloudy/Rain "
                          UNSTABLE = 3,        // "Quickly rising H-Press",     "Not Stable"
                          THUNDERSTORM = 4,    // "Quickly falling L-Press",    "Thunderstorm"
                          UNKNOWN = 5            // "Unknown (More Time needed)
                      #include <Adafruit_BMP085.h>
                      DHT dht;
                      Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
                      float lastPressure = -1;
                      float lastTemp = -1;
                      int lastForecast = -1;
                      const int LAST_SAMPLES_COUNT = 5;
                      float lastPressureSamples[LAST_SAMPLES_COUNT];
                      // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
                      // get kPa/h be dividing hPa by 10
                      #define CONVERSION_FACTOR (1.0/10.0)
                      int minuteCount = 0;
                      bool firstRound = true;
                      // average value is used in forecast algorithm.
                      float pressureAvg;
                      // average after 2 hours is used as reference value for the next iteration.
                      float pressureAvg2;
                      float dP_dt;
                      bool metric;
                      //Dichiarazioni per pause dei diversi blocchi
                      unsigned long int time;
                      unsigned long int lettura_Press;
                      unsigned long int lettura_Temp;
                      unsigned long int letturaluce_time;
                      int lastLightLevel; //Dichiarazione Luminosita
                      float temperatureDTH2;
                        sendSketchInfo("Temp e Umidita", "3");
                        present(CHILD_ID_aaaa, S_LIGHT);
                        present(CHILD_ID_HUMI, S_HUM);
                        present(CHILD_ID_bbbb, S_LIGHT);
                        present(CHILD_ID_BARO, S_BARO);
                      MyMessage msgaaaa(CHILD_ID_HUMI, V_LIGHT);
                      MyMessage msgHumi(CHILD_ID_HUMI, V_HUM);
                      MyMessage msgbbbb(CHILD_ID_HUMI, V_LIGHT);
                      MyMessage msgPres(CHILD_ID_BARO, V_PRESSURE);
                      MyMessage msgForecast(CHILD_ID_BARO, V_FORECAST);
                      MyMessage msg4(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                        // Setto il Pin dove e collegato il sensore di Temperatura DHT22
                        dht.setup(3);
                      #ifdef MY_DEBUG
                        //Settaggi del BMP180
                            if (!bmp.begin())
                              Serial.println(F("Could not find a valid BMP085 sensor, check wiring!"));
                              while (1) {}
                        //Fine settaggi BMP180
                      //-- Setup Variabili MILLIS per sensore di Pressione
                      time=millis();
                      lettura_Press = millis();
                      lettura_Temp = millis();
                      letturaluce_time = millis();
                      //Attivo Time MILLIS
                      time=millis();
                      //----------- Inizio DHT22 ------------------------
                      if(time>lettura_Temp+12000){
                      #ifdef MY_DEBUG
                      Serial.println(F("--- Temperatura ---  "));
                      float temperatureDTH;
                      float temperatureDHT = dht.getTemperature();
                      temperatureDTH2 = temperatureDTH;
                       //Invio la lettura della Temperatura
                        send(msgTemp.set(temperatureDHT, 1));
                        //delay(6000); // Faccio una pausa ed invio altra lettura
                       //Invio lettura Umidita
                        send(msgHumi.set(humidity, 1));
                        //delay(4000);
                      lettura_Temp=millis();
                      //---------- Inizio Pressione ---------------------------
                      if(time>lettura_Press+11000){
                      #ifdef MY_DEBUG
                      Serial.println(F("--- Tempo passato lego la Pressione---  "));
                      float temperatureDHT2;
                      float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
                      float temperature = temperatureDHT2;
                      if (!metric)
                              // Convert to fahrenheit
                              temperature = temperature * 9.0 / 5.0 + 32.0;
                      int forecast = sample(pressure);
                      #ifdef MY_DEBUG
                          Serial.print(F("Pressione = "));
                          Serial.print(pressure);
                          Serial.println(F(" hPa"));
                          Serial.print(F("Forecast = "));
                       if (pressure != lastPressure)
                              send(msgPres.set(pressure, 0));
                              lastPressure = pressure;
                      if (forecast != lastForecast)
                              send(msgForecast.set(weather[forecast]));
                              lastForecast = forecast;
                      lettura_Press=millis();
                      //-------------- Inizio Luminosita --------------------------
                      if(time>letturaluce_time+10000){
                      #ifdef MY_DEBUG
                      Serial.print(F("Tempo passato lego la Luce: "));
                          int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                      #ifdef MY_DEBUG
                          Serial.println(lightLevel);
                          //delay(1000);
                             if(lightLevel > lastLightLevel + 7 || lightLevel < lastLightLevel - 7){
                              send(msg4.set(lightLevel));
                      #ifdef MY_DEBUG
                              Serial.print(F("Invio nuova lettura LUX: "));
                              lastLightLevel = lightLevel;
                      letturaluce_time=millis();
                          //Fine Luminosita
                      //--------- Eventuale 4 Modulo -------------------------
                      // Chiusura Loop
                      //------------ Aggiuntivo Previsione del Barometro ---------------------
                      float getLastPressureSamplesAverage()
                          float lastPressureSamplesAverage = 0;
                          for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                              lastPressureSamplesAverage += lastPressureSamples[i];
                          lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                          return lastPressureSamplesAverage;
                      // Algorithm found here
                      // Pressure in hPa -->  forecast done by calculating kPa/h
                      int sample(float pressure)
                          // Calculate the average of the last n minutes.
                          int index = minuteCount % LAST_SAMPLES_COUNT;
                          lastPressureSamples[index] = pressure;
                          minuteCount++;
                          if (minuteCount > 185)
                              minuteCount = 6;
                          if (minuteCount == 5)
                              pressureAvg = getLastPressureSamplesAverage();
                          else if (minuteCount == 35)
                              float lastPressureAvg = getLastPressureSamplesAverage();
                              float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                                  dP_dt = change * 2; // note this is for t = 0.5hour
                                  dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
                          else if (minuteCount == 65)
                                  dP_dt = change; //note this is for t = 1 hour
                                  dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
                          else if (minuteCount == 95)
                                  dP_dt = change / 1.5; // note this is for t = 1.5 hour
                                  dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
                          else if (minuteCount == 125)
                              pressureAvg2 = lastPressureAvg; // store for later use.
                                  dP_dt = change / 2; // note this is for t = 2 hour
                                  dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
                          else if (minuteCount == 155)
                                  dP_dt = change / 2.5; // note this is for t = 2.5 hour
                                  dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
                          else if (minuteCount == 185)
                                  dP_dt = change / 3; // note this is for t = 3 hour
                                  dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
                              pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                          int forecast = UNKNOWN;
                              forecast = UNKNOWN;
                          else if (dP_dt < (-0.25))
                              forecast = THUNDERSTORM;
                          else if (dP_dt > 0.25)
                              forecast = UNSTABLE;
                              forecast = CLOUDY;
                              forecast = SUNNY;
                          else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
                              forecast = STABLE;
                              forecast = UNKNOWN;
                          // uncomment when debugging
                      #ifdef MY_DEBUG
                          Serial.print(F("Forecast at minute "));
                          Serial.print(minuteCount);
                          Serial.print(F(" dP/dt = "));
                          Serial.print(dP_dt);
                          Serial.print(F("kPa/h --> "));
                          return forecast;
