  3. Help with OTA
Help with OTA
9 Posts 2 Posters 1.7k Views 2 Watching
  • alexsh1A Offline
    alexsh1A Offline
    alexsh1
    Hello
    I cannot figure out why my OTA setup is not working.
    I have a node with Sensebender bootloader, a sketch with #define MY_OTA_FIRMWARE_FEATURE. However, when I assign the FW in MYSController nothing happens.
    The node is not sleeping - I put flash.initialize(); in setup and wait (..) in the loop.
    Can anyone assist please?
    • alexsh1A alexsh1
      Hello
      T Offline
      T Offline
      tekka
      @alexsh1 Please post your sketch and a full node log to understand what is going on.
      alexsh1A 1 Reply Last reply
      • T tekka
        alexsh1A Offline
        alexsh1A Offline
        alexsh1
        @tekka
        OK, I simplified sketch as follows and right now something has been going on, but it says "NO UPDATE" in the log:
        // Enable debug prints to serial monitor #define MY_DEBUG //#define MY_DEBUG_VERBOSE_SIGNING
        // Enable and select radio type attached //#define MY_RADIO_NRF24 //#define MY_RADIO_NRF5_ESB #define MY_RADIO_RFM69 //#define MY_RADIO_RFM95 #define MY_RFM69_NEW_DRIVER #define MY_RFM69_ATC_MODE_DISABLED //#define MY_DEBUG_VERBOSE_RFM69 #define MY_RFM69_FREQUENCY RFM69_868MHZ #define MY_RFM69_NETWORKID 90 #define MY_NODE_ID 2 #define CHILD_ID_BATT 1
        //Signing
        //#define MY_SIGNING_ATSHA204
        #define LED_PIN 9
        SPIFlash flash(8);
        MyMessage msgBatt(CHILD_ID_BATT, V_VOLTAGE);
        uint32_t SLEEP_TIME = 12000;  // sleep time between reads (seconds *
        1000 milliseconds)
        long lastBattery = -100;
        int sendBattery = 0;
        uint16_t lastresult = 0;
        void before() {
           wdt_disable();
           flash.initialize();
           //flash.sleep();
           Serial.println("-------------------------");
           Serial.print("Flash DeviceID: ");
           Serial.println(flash.readDeviceId(), HEX);
           sendSketchInfo("MyMultiSensor Board", "1.1");
           present(CHILD_ID_BATT, S_POWER);
           bool forceTransmit = true;
           sendBattLevel(forceTransmit);
           wait(SLEEP_TIME);
        long readVcc() {
           long result;
           ADCSRA |= _BV(ADSC); // Convert
           while (bit_is_set(ADCSRA, ADSC));
           result = ADCL;
           result |= ADCH << 8;
           result = 1125300L / result; // Back-calculate AVcc in mV
           return result;
           if (force) lastBattery = -1;
           long vcc = readVcc();
           if (vcc != lastBattery) {
             lastBattery = vcc;
             float send_voltage = float(vcc) / 1000.0f;
             Serial.print("voltage = ");
             Serial.println(send_voltage);
             send(msgBatt.set(send_voltage, 3));
             // Calculate percentage
             long percent = vcc / 14.0;
             sendBatteryLevel(percent);
        This is the log:
        voltage = 3.24
        144547 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.242
        145156 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
          __  __       ____
                 |___/                      2.3.0-alpha
        18 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.3.0-alpha
        28 MCO:BGN:BFR
        28 TSM:INIT
        30 TSF:WUR:MS=0
        32 TSM:INIT:TSP OK
        34 TSM:INIT:STATID=2
        36 TSF:SID:OK,ID=2
        38 TSM:FPAR
        45 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        991 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        997 TSF:MSG:FPAR OK,ID=0,D=1
        2054 TSM:FPAR:OK
        2054 TSM:ID
        2056 TSM:ID:OK
        2058 TSM:UPL
        2168 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2654 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2660 TSF:MSG:PONG RECV,HP=1
        2662 TSM:UPL:OK
        2664 TSM:READY:ID=2,PAR=0,DIS=1
        2746
        TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:FFFFFFFFFFFFFFFF0300
        3334 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        3694 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        3809
        TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=11,sg=0,ft=0,st=OK:2.3.0-alpha
        3987 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        4333 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        4497
        TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:MyMultiSensor
        Board
        5093 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
        5720 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
        5726 MCO:REG:REQ
        6557 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        6969 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        6975 MCO:PIM:NODE REG=1
        6977 MCO:BGN:STP
        Flash DeviceID: 1F65
        6981 MCO:BGN:INIT OK,TSP=1
        voltage = 3.24
        7143 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.242
        7727 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
        voltage = 3.24
        19838 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.242
        20197 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
        voltage = 3.24
        32307 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.242
        32509 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
        33294 TSF:MSG:READ,0-0-2,s=0,c=4,t=1,pt=6,l=8,sg=0:14000100F00627A2
        33300 OTA:FWP:UPDATE
        33583 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EF
        33726
        TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100EF06
        33927
        TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100EF06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        33937 OTA:FWP:RECV B=06EF
        33941 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EE
        34054
        TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100EE06
        34174
        TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100EE06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        34185 OTA:FWP:RECV B=06EE
        34189 OTA:FRQ:FW REQ,T=0014,V=0001,B=06ED
        34453
        TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100ED06
        34691 OTA:FRQ:FW REQ,T=0014,V=0001,B=06ED
        34785
        34875
        TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100ED06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        34887 OTA:FWP:RECV B=06ED
        34889 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EC
        35244
        TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100EC06
        35332
        35342 OTA:FWP:RECV B=06ED
        35346 !OTA:FWP:WRONG FWB
        35391 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EC
        36624
        !TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=NACK:14000100EC06
        36632 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EC
        37638
        TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=1,st=OK:14000100EC06
        37646 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EC
        37748
        37990
        TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100EC06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        38002 OTA:FWP:RECV B=06EC
        38004 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EB
        38088
        TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100EB06
        38402
        38412 OTA:FWP:RECV B=06EC
        38414 !OTA:FWP:WRONG FWB
        38490
        TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100EB06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        38500 OTA:FWP:RECV B=06EB
        38504 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EA
        38598
        TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100EA06
        38942
        TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100EA06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        38952 OTA:FWP:RECV B=06EA
        38955 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E9
        39129
        TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E906
        39456 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E9
        40695
        !TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=NACK:14000100E906
        40704 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E9
        41623
        TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=1,st=OK:14000100E906
        41631 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E9
        41906
        42133 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E9
        43380
        43388 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E9
        44275
        44283 !OTA:FRQ:FW UPD FAIL
        44406
        TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E9060000FFFFFFFFFFFFFFFFFFFFFFFFFFFF
        44417 !OTA:FWP:NO UPDATE
        voltage = 3.23
        45752 !TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=NACK:3.233
        46305 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:95
        voltage = 3.24
        58406 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.242
        59062 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
        voltage = 3.24
        71587 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.242
        71731 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
        voltage = 3.24
        83832 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.242
        83955 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
        • alexsh1A Offline
          alexsh1A Offline
          alexsh1
          I am using AT25DF512C-MAHN-T
          • alexsh1A alexsh1
            T Offline
            T Offline
            tekka
            wrote on last edited by tekka
            @alexsh1 Looks like an RFM69 link issue: a missed ACK from the node after requesting FW block 14000100EB06. Since you are on 2.3.0-alpha it's worthwile testing with 2.2.0 (as we have some ongoing work on the RFMxx drivers). Also, what HW are you using on the gateway?
            • T tekka
              alexsh1A Offline
              alexsh1A Offline
              alexsh1
              @tekka GW is 2.3.0-alpha as well (Sensebender + RFM69W). I am using new rfm69 driver. Shall I try both the GW and the node switching to 2.2.0?
              • alexsh1A alexsh1
                T Offline
                T Offline
                tekka
                @alexsh1 Yup :+1:
                • T tekka
                  @alexsh1 Yup :+1:
                  alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  @tekka OK, I cannot setup
                  under 2.2.0 - the parent cannot be found so I had to go back to the old driver.
                  This is the log from the node (partially cut - too long):
                   __  __       ____
                          |___/                      2.2.0
                  16 MCO:BGN:INIT NODE,CP=RRONA---,VER=2.2.0
                  26 MCO:BGN:BFR
                  28 TSM:INIT
                  30 TSF:WUR:MS=0
                  32 TSM:INIT:TSP OK
                  36 TSF:SID:OK,ID=2
                  38 TSM:FPAR
                  1257 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  1439 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  1445 TSF:MSG:FPAR OK,ID=0,D=1
                  3264 TSM:FPAR:OK
                  3264 TSM:ID
                  3266 TSM:ID:OK
                  3268 TSM:UPL
                  3276 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  3317 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  3323 TSF:MSG:PONG RECV,HP=1
                  3328 TSM:UPL:OK
                  3330 TSM:READY:ID=2,PAR=0,DIS=1
                  3340 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:FFFFFFFFFFFFFFFF0300
                  3358 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  3436 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  3657 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
                  3676 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  5691 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:MyMultiSensor Board
                  5709 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                  5926 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
                  5933 MCO:REG:REQ
                  5943 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  5974 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  5980 MCO:PIM:NODE REG=1
                  5982 MCO:BGN:STP
                  5986 MCO:BGN:INIT OK,TSP=1
                  voltage = 3.24
                  6006 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.242
                  6223 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                  16842 TSF:MSG:READ,0-0-2,s=0,c=4,t=1,pt=6,l=8,sg=0:14000100F00627A2
                  16848 OTA:FWP:UPDATE
                  17131 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EF
                  17143 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100EF06
                  17207 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100EF06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  17217 OTA:FWP:RECV B=06EF
                  17219 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EE
                  17233 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100EE06
                  17293 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100EE06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  17303 OTA:FWP:RECV B=06EE
                  17307 OTA:FRQ:FW REQ,T=0014,V=0001,B=06ED
                  17319 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100ED06
                  17379 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100ED06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  17389 OTA:FWP:RECV B=06ED
                  17393 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EC
                  17405 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100EC06
                  17467 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100EC06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  17477 OTA:FWP:RECV B=06EC
                  17481 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EB
                  17494 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100EB06
                  17553 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100EB06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  17565 OTA:FWP:RECV B=06EB
                  17567 OTA:FRQ:FW REQ,T=0014,V=0001,B=06EA
                  17580 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100EA06
                  17641 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100EA06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  17651 OTA:FWP:RECV B=06EA
                  17655 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E9
                  17668 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E906
                  17731 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E9060000FFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  17741 OTA:FWP:RECV B=06E9
                  17745 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E8
                  17758 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E806
                  17819 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E80640240D0A006E616E00696E66006F7666
                  17831 OTA:FWP:RECV B=06E8
                  17833 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E7
                  17846 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E706
                  17909 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E70600000000C224F8256224A02434244E24
                  17920 OTA:FWP:RECV B=06E7
                  17922 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E6
                  17934 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E606
                  17997 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E6060000781D481D191D471D1C1D241D381D
                  18008 OTA:FWP:RECV B=06E6
                  18012 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E5
                  18024 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E506
                  18085 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E506656E6442617474657279203D20000000
                  18096 OTA:FWP:RECV B=06E5
                  18100 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E4
                  18112 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E406
                  18173 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E406616765203D20004F5054333030310073
                  18184 OTA:FWP:RECV B=06E4
                  18188 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E3
                  18200 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E306
                  voltage = 3.23
                  19464 !TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=NACK:3.233
                  19681 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:95
                  19689 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E3
                  19701 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E306
                  19812 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E306656E736F7220426F61726400766F6C74
                  19822 OTA:FWP:RECV B=06E3
                  19826 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E2
                  19838 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E206
                  19900 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E20670686100312E31004D794D756C746953
                  19910 OTA:FWP:RECV B=06E2
                  19914 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E1
                  19927 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E106
                  19988 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E10641434B0021003F00322E332E302D616C
                  19998 OTA:FWP:RECV B=06E1
                  20002 OTA:FRQ:FW REQ,T=0014,V=0001,B=06E0
                  20015 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100E006
                  20076 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100E006443A20003C4E4F4E43453E004F4B004E
                  20088 OTA:FWP:RECV B=06E0
                  20090 OTA:FRQ:FW REQ,T=0014,V=0001,B=06DF
                  20103 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100DF06
                  20164 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100DF06697400466C6173682044657669636549
                  20176 OTA:FWP:RECV B=06DF
                  20178 OTA:FRQ:FW REQ,T=0014,V=0001,B=06DE
                  20191 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100DE06
                  20254 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100DE0667682D4C696D6974004C6F772D4C696D
                  20264 OTA:FWP:RECV B=06DE
                  20269 OTA:FRQ:FW REQ,T=0014,V=0001,B=06DD
                  20281 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100DD06
                  20342 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:14000100DD0630303120446576696365204944004869
                  20353 OTA:FWP:RECV B=06DD
                  20357 OTA:FRQ:FW REQ,T=0014,V=0001,B=06DC
                  20369 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:14000100DC06
                  20430 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:140001001400000000002C76D888DC674F0823DFC1DF
                  324265 OTA:FWP:RECV B=0014010002000C944F040C944F040C944F040C944F04
                  331968 OTA:FWP:RECV B=0002
                  331970 OTA:FRQ:FW REQ,T=0014,V=0001,B=0001
                  331982 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:140001000100
                  332046 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:1400010001000C944F040C944F040C94A6040C944F04
                  332056 OTA:FWP:RECV B=0001
                  332060 OTA:FRQ:FW REQ,T=0014,V=0001,B=0000
                  332072 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:140001000000
                  332136 TSF:MSG:READ,0-0-2,s=255,c=4,t=3,pt=6,l=22,sg=0:1400010000000C9427040C945E220C9485220C944F04
                  332146 OTA:FWP:RECV B=0000
                  332150 OTA:FWP:FW END
                  334950 OTA:CRC:B=06F0,C=A227,F=A227
                  334954 OTA:FWP:CRC OK
                   __  __       ____
                          |___/                      2.2.0
                  26 MCO:BGN:BFR
                  28 TSM:INIT
                  30 TSF:WUR:MS=0
                  32 TSM:INIT:TSP OK
                  36 TSF:SID:OK,ID=2
                  38 TSM:FPAR
                  1345 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  1351 TSF:MSG:FPAR OK,ID=0,D=1
                  3264 TSM:FPAR:OK
                  3264 TSM:ID
                  3266 TSM:ID:OK
                  3268 TSM:UPL
                  3328 TSM:UPL:OK
                  3340 TSF:MSG:SEND,2-2-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:14000100F00627A20300
                  4569 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                  6582 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=OK:2.2.0
                  6801 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  7229 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  7450 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:MyMultiSensor Board
                  7469 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                  7686 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
                  7692 MCO:REG:REQ
                  7905 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  7936 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  7942 MCO:PIM:NODE REG=1
                  7944 MCO:BGN:STP
                  7948 MCO:BGN:INIT OK,TSP=1
                  voltage = 3.24
                  7966 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.242
                  8185 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                  voltage = 3.23
                  20205 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.233
                  20424 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                  voltage = 3.23
                  32442 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.233
                  32661 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                  voltage = 3.23
                  44681 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.233
                  44900 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                  voltage = 3.23
                  56924 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.233
                  56946 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                  Does this mean that the OTA FW update done?
                  • alexsh1A alexsh1
                     __  __       ____
                            |___/                      2.2.0
                    26 MCO:BGN:BFR
                    28 TSM:INIT
                    30 TSF:WUR:MS=0
                    32 TSM:INIT:TSP OK
                    36 TSF:SID:OK,ID=2
                    38 TSM:FPAR
                    3264 TSM:FPAR:OK
                    3264 TSM:ID
                    3266 TSM:ID:OK
                    3268 TSM:UPL
                    3328 TSM:UPL:OK
                    5933 MCO:REG:REQ
                    5982 MCO:BGN:STP
                    voltage = 3.24
                    voltage = 3.23
                     __  __       ____
                            |___/                      2.2.0
                    26 MCO:BGN:BFR
                    28 TSM:INIT
                    30 TSF:WUR:MS=0
                    32 TSM:INIT:TSP OK
                    36 TSF:SID:OK,ID=2
                    38 TSM:FPAR
                    3264 TSM:FPAR:OK
                    3264 TSM:ID
                    3266 TSM:ID:OK
                    3268 TSM:UPL
                    3328 TSM:UPL:OK
                    7692 MCO:REG:REQ
                    7944 MCO:BGN:STP
                    voltage = 3.24
                    voltage = 3.23
                    voltage = 3.23
                    voltage = 3.23
                    voltage = 3.23
                    alexsh1A Offline
                    alexsh1A Offline
                    alexsh1
                    @tekka Now it says "403195 OTA:FWP:UPDATE SKIPPED" when try to update it.
                    EDIT: Despite getting
                    48732 OTA:FWP:RECV B=0000
                    48736 OTA:FWP:FW END
                    48865 OTA:CRC:B=0050,C=46D4,F=46D4
                    48867 OTA:FWP:CRC OK
                    Firmware is not updated
                    12.1k
