  3. 💬 Unnamed project
💬 Unnamed project
mysensors mysensors library an
11 Posts 4 Posters 2.7k Views 3 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/569/Unnamed-project
      Have you found an inexpensive source for the Atmega 328p-mu? So far, the cheapest I've found is:
      https://www.ebay.com/itm/10pcs-ATMEGA328P-MU-MEGA328P-MU-QFN-32/292431653458?hash=item441648ea52:g:D2QAAOSwmuVacfep
      • berkseoB
        berkseoB
        berkseo
        https://ru.aliexpress.com/item/5PCS-LOT-ATMEGA328P-MU-MEGA328P-MU-ATMEGA328-328P-MU-QFN/32847386871.html?spm=a2g0v.search0104.3.9.756b5f4elTBBr1&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10344_10068_5722815_10342_10343_10340_5722915_10341_10543_10698_10697_5722615_10696_10084_10083_10618_10307_10301_5722715_5711215_10059_10534_10212_308_100031_10103_441_10624_10623_10622_5711315_5722515_10621_10620_10125,searchweb201603_28,ppcSwitch_4&algo_expid=b086873b-793f-4c33-be6d-bc159136d1e8-1&algo_pvid=b086873b-793f-4c33-be6d-bc159136d1e8&transAbTest=ae803_1&priceBeautifyAB=0
        • berkseoB
          berkseoB
          berkseo
          not expensive 328Ñ€-au. And sometimes size is very important
          • berkseoB berkseo
            @berkseo Thanks! I just ordered it to test how easy/hard it is to solder. If I can manage that, then I may switch over to it.
            Nca78N 1 Reply Last reply
              @neverdie said in 💬 MyS Duino:
              0.45mm pitch, it will be a pain to hand solder and the big ground pad at the bottom is out of reach, get a stencil.
              berkseoB 1 Reply Last reply
              • berkseoB
                berkseoB
                berkseo
                It is not difficult. A solder paste and a solder dryer will help you. The chip is fixed on the board with a clip, so that it does not blow away. I soldered the chip for a self-made board. It was hard to do the tracks. On a good industrial board, it will simply be a pleasure to solder. :)
                • Nca78N Nca78
                  berkseoB
                  berkseoB
                  berkseo
                  @nca78 said in 💬 MyS Duino:
                  soldering paste and soldering dryer :) It's very simple :)
                  https://ru.aliexpress.com/item/Free-shipping-2013-New-2PCS-Lot-100-Hong-Kong-MECHANIC-BGA-Solder-Flux-Paste-Soldering-Tin/922291342.html?spm=a2g0v.search0204.3.23.2cb57150vey63U&s=p&ws_ab_test=searchweb0_0%2Csearchweb201602_1_10152_10151_10065_10344_10068_10342_10343_10340_5722611_10341_10543_10698_10697_10696_5722911_5722811_10084_5722711_10083_10618_10307_10301_5711211_10059_10212_308_100031_10103_441_10624_10623_10622_10621_10620_5711311_5722511_10125%2Csearchweb201603_32%2CppcSwitch_3_ppcChannel&transAbTest=ae803_2&priceBeautifyAB=0
                  https://ru.aliexpress.com/item/110-240-AC/32844571674.html?spm=a2g0v.search0204.3.59.649e519fCHRWZY&ws_ab_test=searchweb0_0%2Csearchweb201602_1_10152_10151_10065_10344_10068_10342_10343_10340_5722611_10341_10543_10698_10697_10696_5722911_5722811_10084_5722711_10083_10618_10307_10301_5711211_10059_10212_308_100031_10103_441_10624_10623_10622_10621_10620_5711311_5722511_10125%2Csearchweb201603_32%2CppcSwitch_3_ppcChannel&algo_expid=0152a640-c1c2-47b6-b06f-7b03feadea51-8&algo_pvid=0152a640-c1c2-47b6-b06f-7b03feadea51&transAbTest=ae803_2&priceBeautifyAB=0
                  berkseoB NeverDieN 2 Replies Last reply
                  • berkseoB berkseo
                    berkseoB
                    berkseoB
                    berkseo
                    @berkseo A small piece of paste under the chip solves the problem of soldering 33 contacts, under the chip it is only one and very large)))
                    • berkseoB berkseo
                      @berkseo said in 💬 MyS Duino:
                      No stencil?
                        No stencil?
                        berkseoB
                        berkseoB
                        berkseo
                        No stencil?
                        will add later ...
                        PCB manufacturing process
                        https://www.youtube.com/watch?v=8tg0u7rf7Xg
