  3. LoRa Gateway
LoRa Gateway
18 Posts 4 Posters 7.4k Views 4 Watching
  • alexsh1A Offline
    alexsh1A Offline
    alexsh1
    OK, excellent. I have not tried lora coverage myself (apart from single channel GW for TTN). In fact I did not even built one for my home automation. I think the best usage of it are things like remote location sensors. I know a guy who is utilising lora for HAB (High Altitude Ballooning) projects - http://www.daveakerman.com/
    I am trying to think about where at home I can utilise one, but so far RFM69 is covering everything for me. Having said that, your GW is a simple and minimalist one and I can probably build one just to tinker.
    PS BTW, water leak sensors - I have a couple of z-wave sensors. They were not DIY, but the advantage is that they just work and look very nice.
    • R Offline
      R Offline
      ricorico94
      Seems a great project !
      Can you clarify the difference with your previous minimalist gateway : the new one is linked to Domoticz controller through wifi, but how was the minimalist linked to controller ? Wasnt'it already through wifi ? Or do you mean this new approach enhances the wifi connectivity by using ESP-Link ? (to be frank, I don't really understand what makes ESP-Link so good, as I never investigated it)
      br,
      Ricorico94
      N 1 Reply Last reply
      • R ricorico94
        br,
        Ricorico94
        N Offline
        N Offline
        @ricorico94 The main difference is that the newer project can use ESP-LINK on the ESP8266, whereas the first one can't. However, you are correct: with the right programming both can use wi-fi
        • N Offline
          N Offline
          Also, I've confirmed that ESP-LINK doesn't run on the ESP32, so the only way to use it is with an ESP8266 plus an additional MCU, which is what this newer version enables.
          • R Offline
            R Offline
            ricorico94
            I think I could understand the wiring thanks to your other projects (the shield for ESP-link on Wemos D1 mini), but I'd appreciate if you could clarify it -just to make sure since I see the 90° connector on picture is not like the one in your shield)
            Could you detail also the SW/scripts and settings you use ?
            Ricorico94
            • R ricorico94
              Ricorico94
              N Offline
              N Offline
              @ricorico94
              To overcome the overhang, I've since put everything onto a single shield for the ESP8266 D1 Mini:
              • N Offline
                N Offline
                Of course, another way to handle the overhang would be to make it overhang in the opposite direction, where the overhang wouldn't matter:
                https://www.openhardware.io/view/273/ESP-LINK-ESP8266-WeMos-D1-Mini-Adapter-Board
                That would work too.
                • R Offline
                  R Offline
                  ricorico94
                  This is even one step further as I understand you get rid of the sandwich Arduino pro mini by soldering directly an ATMEGA328p. It makes the overall setup much more dense indeed. Congratulations !
                  Could you share the details on software (scripts..) you used for the whole setup ?
                  I'm also interested in settings you use, because based on another thread, I had seen that some settings for RFM95 had an impact on error rates.
                  • R ricorico94
                    N Offline
                    N Offline
                    @ricorico94 said in LoRa Gateway:
                    Nothing meaningful to share as yet. I'm using RadioHead to verify that the hardware works as intended.
                    • N Offline
                      N Offline
                      Currently priced at $3.01 per module with free shipping:
                      https://www.aliexpress.com/item/LoRa-Series-Ra-01-Spread-Spectrum-Wireless-Module-Ultra-10KM-433M-RF-Chip-SX1278/32799821469.html?spm=a2g0s.13010208.99999999.262.rCAs4B
                      https://www.aliexpress.com/item/LoRa-Series-Ra-02-Spread-Spectrum-Wireless-Module-Ultra-10KM-433M-RF-Chip-SX1278/32799769669.html?spm=a2g0s.13010208.99999999.265.rCAs4B
                      • N Offline
                        N Offline
                        Epilog: the fully integrated ESP-LINK LoRa gateway has no antenna overhang and is working fine. :)
                        • alowhumA Offline
                          alowhumA Offline
                          alowhum
                          Cool.
                          Have you seen these?
                          https://nl.aliexpress.com/item/RCmall-2-Sets-partij-LoRa32u4-II-Lora-Development-Board-Module-LiPo-Atmega328-SX1276-HPD13-868-MHZ/32832789857.html
                          • N Offline
                            N Offline
                            Hadn't seen it. I'm lately of the mind that it's better to have everything (including sensors) integrated onto a single board.
