  3. attachInterrupt and sleep()
10 Posts 2 Posters 3.3k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    Can anyone tell me if mcu wakes up if IRQ is changing in the following setup? OR do I have to use sleep(digitalPinToInterrupt(IRQ), CHANGE, SLEEP_TIME);
    pinMode(IRQ, INPUT);
    attachInterrupt(digitalPinToInterrupt(IRQ), wakeup, RISING);
    void loop {
    sleep(SLEEP_TIME);
    void wakeup()
    detected = true;
    • alexsh1A alexsh1
      void loop {
      sleep(SLEEP_TIME);
      void wakeup()
      detected = true;
      @alexsh1 yes, you should preferably use the MySensors sleep() interface, unless you know exactly what you're doing.
      Furthermore, using the MySensors API will assure compatibility with future versions of the library.
      alexsh1A 1 Reply Last reply
      • YveauxY Yveaux
        alexsh1A
        alexsh1A
        alexsh1
        @yveaux Thank you|! But does attachInterrupt works with a simple sleep() from MySensors? I cannot call ISR from sleep(attachInterrupt()....)
        • alexsh1A alexsh1
          @alexsh1 not sure what you are trying to achieve here... Is this the same question as in the initial post?
          • YveauxY Yveaux
            alexsh1A
            alexsh1A
            alexsh1
            @yveaux
            I am trying to understand if there a difference on how to put a node to sleep. Please see below and compare it to my initial post.
            The node is working fine, but it seems that the sensor on IRQ is not working. This is why I am asking.
            It is sleep() + attachInterrupt vs sleep(attachInterrupt...) question
            void loop {
            if (detected)
            sleep(attachInterrupt(digitalPinToInterrupt(IRQ), CHANGE, SLEEP_TIME);
            alexsh1A YveauxY 2 Replies Last reply
            • alexsh1A alexsh1
              @yveaux
              void loop {
              if (detected)
              alexsh1A
              alexsh1A
              alexsh1
              @Yveaux Let me tell you want I am doing and perhaps it would be easier for you to understand. I have a node with multiple sensors. Additionally, I have a i2c lightning sensor with IRQ connected to D2 of atmega328p. The node has to wake up every 10-15 mins for send regular information from sensors AND also has to wake up every time there is an interrupt on D2.
              • alexsh1A alexsh1
                @yveaux
                void loop {
                if (detected)
                @alexsh1 said in attachInterrupt and sleep():
                This is invalid, as attachInterrupt returns nothing; ref: https://www.arduino.cc/reference/en/language/functions/external-interrupts/attachinterrupt/
                Just use
                int8_t cause = sleep( digitalPinToInterrupt( IRQ ), CHANGE, SLEEP_TIME );
                and have MySensors handle the wakeup by interrupt and sleep timeout for you.
                The cause will tell you if it woke from interrupt or because of a timeout, as described by https://www.mysensors.org/apidocs-beta/group__MySensorsCoregrp.html#ga57a5217aff45276f40018165d2fb10a1
                • YveauxY Yveaux
                  Just use
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @yveaux said in attachInterrupt and sleep():
                  Thank you for spotting it - this was my mistake.
                  I meant
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @Yveaux this is what you mean, right?
                    I need to refactor my code a bit to try it.
                      switch (cause) {
                        case MY_WAKE_UP_BY_TIMER:
                    //Take measurements from sensor and msg to GW.
                           case digitalPinToInterrupt(IRQ):
                       // Lightning sensor interrupt
                    • alexsh1A alexsh1
                        switch (cause) {
                      @alexsh1 yes, correct! :+1:
