  3. Pin Change Interrupts debounce
16 Posts 3 Posters 3.9k Views 3 Watching
  • alexsh1A alexsh1
    This is the most of the loop function I have apart from sleep.
     if (IRQHigh) {
        send(msg.set("1"));
        IRQHigh = false;
    @alexsh1 how about adding global variables for all interrups like this
    volatile unsigned long lastInterruptD1 = 0;
    volatile unsigned long lastInterruptD2 = 0;
    and inside the ISRs set the corresponding variable to millis() like this
    lastInterruptD1 = millis();
    and in loop have a series of
    if(lastInterruptD1 != 0 && millis()-lastInterruptD1 > DEBOUNCE_MS){
      // Do whatever the interrupt does here
    You could use an array instead of individual variables to make the code cleaner, especially if you want to cover a lot of pins. Which board/Arduino are you using?
    alexsh1A 1 Reply Last reply
      alexsh1A
      alexsh1A
      alexsh1
      @mfalkvidd it is a custom made board using atmega328p-au with sensebender bootloader running at 8Mhz and 3.3V.
      I'll try the above, however, does millis() work while sleeping?
      • alexsh1A alexsh1
        @alexsh1 it will return the last value, but it will not increment. That's one of the reasons ISRs should exit quickly.
          alexsh1A
          alexsh1A
          alexsh1
          @mfalkvidd
          Want to share what I found in case others have a similar issue.
          const unsigned long debounceTime = 50;
          volatile bool ir_selector_pressed = false;
          ISR (PCINT2_vect) { // handle pin change interrupt for D0 to D7 here
            static unsigned long previousStateChangeMillis = 0;
            static bool previousPinState = HIGH;
            bool pinState = digitalRead(SELECTOR_BTN);
            if (pinState != previousPinState) { // ignore pin changes of pins other than SELECTOR_BTN
              if (pinState == LOW) { // only falling events
                if ((millis() - previousStateChangeMillis) > debounceTime) { // debounce
                  ir_selector_pressed = true;
              previousPinState = pinState;
              previousStateChangeMillis = millis();
          • alexsh1A
            alexsh1A
            alexsh1
            Another way to debounce is to stop interrupts in loop, sleep for say 20 seconds and then resume interrupts.
            • alexsh1A alexsh1
              @alexsh1 this is in general a bad idea, as it will also stop eg reception of serial data and incoming packages (when using message queuing).
              • YveauxY Yveaux
                alexsh1A
                alexsh1A
                alexsh1
                @yveaux you mean stopping interrupts?
                • alexsh1A alexsh1
                  @alexsh1 yup
                  • YveauxY Yveaux
                    @alexsh1 yup
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @yveaux What is the best way to do it please?
                    • alexsh1A alexsh1
                      @alexsh1 The easiest way would probably use a debounce-library.
                      These normally aren't using interrupts, but you have to question yourself if you really need interrupts in your case.
                      I don't have any readymade, tested code which uses interrupts and debounces switches.
                      • YveauxY Yveaux
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @yveaux said in Pin Change Interrupts debounce:
                        I'll look into that. Thank you
