  3. having trouble with water flow sensor + relay + moisture
4 Posts 3 Posters 1.3k Views 3 Watching
  • T Offline
    T Offline
    tsunami
    wrote on last edited by tsunami
    Hi, I've build my own node with mqtt to send waterflow sensor and DHT22 and moisture data to Domoticz and have one Relay to control. but both relay and waterflow sketches has receive function and when I write both of them in one function, relay doesn't show up in domoticz devices or hardware(child node);
    here is my code:
    #define DHT_DATA_PIN 6
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 5000;
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 1
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define CHILD_ID_MOISTURE 2
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    MyMessage msgMoisture(CHILD_ID_MOISTURE, V_HUM);
    DHT dht;
    static int sensorValue;
    int soilPin = A0;
    int soilPower = 5;
    #define DIGITAL_INPUT_SENSOR 3                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR 450000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
    #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
    #define MAX_FLOW 30                             // Max flow (l/min) value to report. This filters outliers.
    #define CHILD_ID_WATER 1
    uint32_t SEND_FREQUENCY =
        5000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
    MyMessage flowMsg(CHILD_ID_WATER,V_FLOW);
    MyMessage volumeMsg(CHILD_ID_WATER,V_VOLUME);
    MyMessage lastCounterMsg(CHILD_ID_WATER,V_VAR1);
    double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
    volatile uint32_t pulseCount = 0;
    volatile uint32_t lastBlink = 0;
    volatile double flow = 0;
    bool pcReceived = false;
    uint32_t oldPulseCount = 0;
    uint32_t newBlink = 0;
    double oldflow = 0;
    double volume =0;
    double oldvolume =0;
    uint32_t lastSend =0;
    uint32_t lastPulse =0;
    void before()
      for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
     sendSketchInfo("Smart Irrigation System", "1.0");
      present(CHILD_ID_MOISTURE, S_MOISTURE);
      present(CHILD_ID_WATER, S_WATER);
      present(CHILD_ID_HUM, S_HUM);
      present(sensor, S_BINARY);
      pinMode(soilPower, OUTPUT);//Set D6 as an OUTPUT
      // initialize our digital pins internal pullup resistor so one pulse switches from high to low (less distortion)
      pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
      pulseCount = oldPulseCount = 0;
      request(CHILD_ID_WATER, V_VAR1);
      lastSend = lastPulse = millis();
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
      uint32_t currentTime = millis();
      if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY)) {
        lastSend=currentTime;
        if (!pcReceived) {
          //Last Pulsecount not yet received from controller, request it again
          return;
        if (!SLEEP_MODE && flow != oldflow) {
          oldflow = flow;
          Serial.print("l/min:");
          Serial.println(flow);
          // Check that we dont get unresonable large flow value.
          if (flow<((uint32_t)MAX_FLOW)) {
            send(flowMsg.set(flow, 2));                   // Send flow value to gw
        // No Pulse count received in 2min
        if(currentTime - lastPulse > 120000) {
          flow = 0;
        // Pulse count has changed
        if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
          oldPulseCount = pulseCount;
          Serial.print("pulsecount:");
          Serial.println(pulseCount);
          send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
          double volume = ((double)pulseCount/((double)PULSE_FACTOR));
          if ((volume != oldvolume)||(!SLEEP_MODE)) {
            oldvolume = volume;
            Serial.print("volume:");
            Serial.println(volume, 3);
            send(volumeMsg.set(volume, 3));               // Send volume value to gw
      if (SLEEP_MODE) {
        sleep(SEND_FREQUENCY);
        soilmoisture();
    void soilmoisture()
      digitalWrite(soilPower, HIGH);
    delay(10);//wait 10 milliseconds
    sensorValue = analogRead(soilPin);
    digitalWrite(soilPower, LOW);
    sensorValue = map(sensorValue, 0, 680, 0, 100);
      send(msgMoisture.set(sensorValue));
      if (message.type==V_VAR1) {
        uint32_t gwPulseCount=message.getULong();
        pulseCount += gwPulseCount;
        flow=oldflow=0;
        Serial.print("Received last pulse count from gw:");
        pcReceived = true;
      if (message.type==V_STATUS) {
        // Change relay state
        digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        // Store state in eeprom
    void onPulse()
      if (!SLEEP_MODE) {
        uint32_t newBlink = micros();
        uint32_t interval = newBlink-lastBlink;
        if (interval!=0) {
          if (interval<500000L) {
            // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
            return;
          flow = (60000000.0 /interval) / ppl;
        lastBlink = newBlink;
      pulseCount++;
    anyone can help me?
    and any suggestion to clean up my code?
    thanks in advanced.
    • T tsunami
      here is my code:
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      int soilPin = A0;
      int soilPower = 5;
      double oldflow = 0;
      double volume =0;
      void before()
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
          if (!pcReceived) {
            return;
            oldflow = flow;
            flow = 0;
              oldvolume = volume;
        if (SLEEP_MODE) {
          soilmoisture();
      void soilmoisture()
          flow=oldflow=0;
          pcReceived = true;
      void onPulse()
        if (!SLEEP_MODE) {
          if (interval!=0) {
              return;
        pulseCount++;
      anyone can help me?
      thanks in advanced.
      @tsunami if you look at the debug output, you will probably see that the presentation presents the relay and the water sensor with the same child id.
      You'll need to use a higher number for one of the IDs.
        T Offline
        T Offline
        tsunami
        @mfalkvidd I've changed CHILD_ID for nodes but nothing changed and moisture data show up in DHT22's humidity!
          @tsunami said in having trouble with water flow sensor + relay + moisture:
          try
          #define CHILD_ID_MOISTURE 12
          #define CHILD_ID_HUM 13
          #define CHILD_ID_TEMP 14
          Also delete node from controller if you still see the ID mixed up
