  3. SW_Signing failing: !TSF:MSG:SIGN FAIL
27 Posts 3 Posters 4.6k Views 3 Watching
  • joaoabsJ joaoabs
    With an arduino UNO (same processor type: mega 328p) as GW the behaviour is the same.
    This is just the arduino board connected to a laptop, via an USB3 port (should have enough power). I've also added a 47uF capacitor between 5v and GND, but the behaviour is the same. (the NRFs already have their own 4.7uF capacitor)
    Any idea/suggestuin?
    AnticimexA
    AnticimexA
    Anticimex
    @joaoabs no, I am afraid I am out of options. Did you do a comparison with and without signing, just to rule out if signing is the cause of the radio seemingly failing at either end?
    The radio also have verbose debug flags. Perhaps someone with more knowledge about radio debugging could draw conclusions from those.
    • joaoabsJ joaoabs
      AnticimexA
      AnticimexA
      Anticimex
      @joaoabs one thing I see is that you did not include the ram usage on the GW, just the flash usage. Is the ram usage within reasonable levels? (at least below 75%)
      • joaoabsJ
        joaoabsJ
        joaoabs
        wrote on last edited by joaoabs
        The GW sketch is the simplest possible. It is the SerialGateway.ino example just with the added flags for the signing.
        It seems to have enough resources
        Sketch uses 21440 bytes (66%) of program storage space. Maximum is 32256 bytes.
        Global variables use 1401 bytes (68%) of dynamic memory, leaving 647 bytes for local variables. Maximum is 2048 bytes.
        The node sketch is the Relay example sketch, where I then added, one by one, the code from other examples such as Door/Win/Button (tripwire), Temperature (DS18B20), Temp/Hum (DHT22) and Motion (HC-SR501).
        I have a pretty basic version control, so for each new sensor type I was adding I was just creating another file. Since all the signature process was done (and written in the eeprom), I went back to the basics (sketch with Relay + Door) with the signing flags enabled and could confirm it worked with signatures (so it must be something I added). I then went version-by-version, enabling the flags and confirmed it was still working as I was progressing.
        I've now reached a point where I just have the last sensor to add (Motion HC-SR501) but the available memory is concerning:
        Sketch uses 28030 bytes (91%) of program storage space. Maximum is 30720 bytes.
        Global variables use 1542 bytes (75%) of dynamic memory, leaving 506 bytes for local variables. Maximum is 2048 bytes.
        Low memory available, stability problems may occur.
        I'll leave as it is, (disabling the signing debug, the memory use drops to 71%). Just out of curiosity, I checked the memory use on the original node sketch (without signing debug) and it was 73%.
        Still not sure if it was an issue related with the memory or with the additional code I added for the Motion Sensor.
        However, the strange conclusion is that it was really on the node, and not on the gateway as we thought.
        I'll leave it on during the night in order to see if it hangs or something.
        Thanks for your help!
        Joaoabs
        AnticimexA tekkaT 2 Replies Last reply
        • joaoabsJ joaoabs
          Joaoabs
          AnticimexA
          AnticimexA
          Anticimex
          @joaoabs I am glad that you at least came to some form of conclusion. I suspect this is just another example of the sketch running out of ram for the stack. The symptoms can be really weird and unpredictable. Just a slight change on the execution path and something that worked fine just before simply explodes or, executed something completely different.
          We really are pushing it with signing on atmega328p, because the library also grows in size with time (new features come in).
          I'd say, and I will probably soon update the documentation with it, that signing/security does technically work on atmega328p, but due to the limited ram, it's usability is very limited to just basic sketches.
          Thanks for reporting this. It adds to the hive mind of knowledge and experience in troubleshooting :+1:
          • joaoabsJ
            joaoabsJ
            joaoabs
            The node is still sending periodic updates after 8h uptime. I guess I can considered it as stable.
            By the way, I have a couple of ATSHA204A-STUCZ-T ordered. I think I can easily migrate to HW signing as soon as I get them.
            Will the HW signing unload the AT328p?
            AnticimexA 1 Reply Last reply
            • joaoabsJ joaoabs
              AnticimexA
              AnticimexA
              Anticimex
              @joaoabs yes, but you need to redo personalization for it, but you have that under control so it should be easy for you.
              Yes, the atsha will put less strain on the atmega328p. Difficult to say how much and if it will resolve your issue but I'd say it's worth a try :)
              • joaoabsJ joaoabs
                Joaoabs
                tekkaT
                tekkaT
                tekka
                @joaoabs Could you post the full sketch where signing fails? I assume one of the external libraries may interfere with SPI communication. To confirm, please test this PR with the failing sketch and upload the full debug log here.
                https://github.com/mysensors/MySensors/pull/1116
                • tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  @joaoabs Any updates on the issue?
                  • joaoabsJ
                    joaoabsJ
                    joaoabs
                    Sorry for the delayed answer, I was making sure I had a better testing enviroment:
                    Controller/Gateway: RPI3 with OpenHab2 and NRF24L01+ connected directly to the pin header. The NRF has a 4.7uF capacitor soldered to it and is the simple + model (not PA+NLA)
                    Node: Arduino mini pro 3v 8MHz, in a prototype board with:
                    • Hi-Link power supply (220AC to 5V DC)
                    • 2200uF capactior to stabilize 5V (and also a pico range one to filter high frequencies)
                    • 3.3V regulator
                    • 100uf capacitor to stabilize 3.3V (and also a pico range one to filter high frequencies)
                    • NRF24L01+ feed from the 3.3V regulator and with an additional 4.7uF capacitor
                    • Connections made by wire around the board
                    • The board is supposed to:
                      • Interact with a 4-relay module
                      • Read the temperature of several DS18B20's (only used 1 in the testing)
                      • Detect presence in 3 motion sensors
                      • Read temperature/Humidity from a DHT22
                    • The node is ~6m away of the GW/Controller with line of sight
                    • The pins and skecth options are in its own comments.
                    • The " && transportSanityCheck());" patch was applied
                    • Signing is activated
                    Code:
                     * This program is free software; you can redistribute it and/orlçyovzwqi71234567890ll
                     * Version 1.0
                     * Combined sketch with:
                     *      - NODE ID 44
                     *      - Relay sketch, base sketch for all          - PIN 3,4,5,6  -   Child ID from 1,2,3,4
                     *      - DOOR sketch (trip alarm), added code       - PIN A0,A1    -   Child ID 30,31
                     *      - TEMP sketch (DS18B20), added code          - PIN 8        -   Child ID from 10 to 18  (defined 8 as MAX)
                     *      - Hum sketch (DHT22), added code             - PIN A7       -   Child ID 50 (Temp) and 60 (Hum)
                     *      - MOTION sketch, added code                  - PIN A6       -   Child ID 70
                     * BOARD
                     * D0 - RX (not used - but can be used with a plug on the programing header))
                     * D1 - TX (not used - but can be used with a plug on the programing header))
                     * D2 - NRF24 IRQ
                     * D3 - RJ-45 (3)
                     * D4 - 1-W (RJ-45 (4) & pin header)
                     * D5 - Relay (5) (relay pin header has 6 pins where 6 is 5v and 1 is GND)
                     * D6 - Relay (4)
                     * D7 - Relay (3)
                     * D8 - Relay (2)
                     * D9 - NRF CE
                     * D10- NRF CS
                     * D11- NRF MOSI
                     * D12- NRF MISO
                     * D13- NRF SCK
                     * A0 - RJ-45 (6)  (DOOR Sketch)
                     * A1 - RJ-45 (2)  (DOOR Sketch)
                     * A2 - RJ-45 (1)
                     * A3 - RJ-45 (4)
                     * A4 - I2C
                     * A5 - I2C
                     * A6 - PIR (pin header)  (MOTION Sketch)
                     * A7 - DHT (pin header)
                     * All sketches copied from http://www.mysensors.org
                     * signing "hidden" page: https://www.mysensors.org/apidocs-beta/group__MySigninggrpPub.html
                    // Static node ID definition
                    #define MY_NODE_ID 44
                    //#define MY_RADIO_NRF5_ESB
                    //#define MY_RADIO_RFM95
                    //#define MY_REPEATER_FEATURE
                    //CODE FOR SIGNING************************************************
                    //#define MY_SIGNING_WEAK_SECURITY
                    #define MY_SIGNING_SOFT
                    #define MY_SIGNING_SOFT_RANDOMSEED_PIN A4
                    #define MY_SIGNING_REQUEST_SIGNATURES  // will inform the gateway that I expect it to sign all messages to me
                    //What features/Sketches to use?  ************************************************
                    #define RELAY
                    //#define DHTCODE
                    #define DOOR
                    #define MOTION
                    //#define TEMP
                    //CODE OF DOOR SKETCH************************************************
                    #ifdef DOOR
                    #define CHILD_ID_A 30
                    #define CHILD_ID_B 31
                    #define BUTTON_PIN_A  A0  // Arduino Digital I/O pin for button/reed switch
                    #define BUTTON_PIN_B  A1  // Arduino Digital I/O pin for button/reed switch
                    Bounce debouncer_a = Bounce();
                    Bounce debouncer_b = Bounce();
                    int oldValue_a=-1;
                    int oldValue_b=-1;
                    MyMessage msg_door_a(CHILD_ID_A,V_TRIPPED);
                    MyMessage msg_door_b(CHILD_ID_B,V_TRIPPED);
                    //CODE OF MOTION SKETCH************************************************
                    #ifdef MOTION
                    int oldMotion_a=-1;
                    //uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                    #define DIGITAL_INPUT_SENSOR_MOTION_A A6   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                    #define CHILD_ID_MOTION_A 70   // Id of the sensor child
                    // Initialize motion message
                    MyMessage msg_motion_a(CHILD_ID_MOTION_A, V_TRIPPED);
                    //CODE OF TEMP SKETCH************************************************
                    #ifdef TEMP
                    #include <OneWire.h>
                    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
                    #define MAX_ATTACHED_DS18B20 10
                    int numSensors=0;
                    bool receivedConfig = false;
                    bool metric = true;
                    MyMessage msg_temp(0,V_TEMP);
                    //CODE FOR LOOP************************************************
                    long x = 327670;
                    int y = 32767;
                    //CODE OF RELAY SKETCH************************************************
                    #ifdef RELAY
                    #define RELAY_PIN 5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                    //CODE OF DHT SKETCH************************************************
                    #ifdef DHTCODE
                    //#include "DHT.h"
                    #define DHT_DATA_PIN A7
                    #define SENSOR_TEMP_OFFSET 0
                    static const uint64_t UPDATE_INTERVAL = 60000;
                    #define CHILD_ID_HUM 50
                    #define CHILD_ID_TEMP 60
                    float lastTempdht;
                    float lastHumdht;
                    uint8_t nNoUpdatesTempdht;
                    uint8_t nNoUpdatesHumdht;
                    //bool metric = true;
                    DHT dht;
                    void before()
                     #ifdef RELAY
                     for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                            pinMode(pin, OUTPUT);
                     #ifdef TEMP
                     sensors.begin();
                    #ifdef DOOR
                      // Setup the button A
                      pinMode(BUTTON_PIN_A,INPUT);
                      // Activate internal pull-up
                      digitalWrite(BUTTON_PIN_A,HIGH);
                      debouncer_a.attach(BUTTON_PIN_A);
                      debouncer_a.interval(5);
                      // Setup the button B
                      pinMode(BUTTON_PIN_B,INPUT);
                      digitalWrite(BUTTON_PIN_B,HIGH);
                      debouncer_b.attach(BUTTON_PIN_B);
                      debouncer_b.interval(5);
                    #ifdef MOTION
                      pinMode(DIGITAL_INPUT_SENSOR_MOTION_A, INPUT);      // sets the motion sensor digital pin as input
                    #ifdef TEMP
                    #ifdef DHTCODE
                       sendSketchInfo("MIXED JOAOABS SOTAO", "1.0");
                    //FOR RELAY: Child ID from 1 to 4
                    #ifdef RELAY
                            //  present(sensor, S_BINARY);
                             present(sensor, S_BINARY, "RELAYS", true);  // forcing ack for this child's messages
                    //FOR DOOR: Child ID 30
                    #ifdef DOOR
                     // present(CHILD_ID_A, S_DOOR);
                     // present(CHILD_ID_B, S_DOOR);
                      present(CHILD_ID_A, S_DOOR, "DOOR_A", true);  // CHILD ID = 30 and forcing ack for this child's messages
                      present(CHILD_ID_B, S_DOOR, "DOOR_B", true);  // CHILD ID = 31 and forcing ack for this child's messages
                    #ifdef MOTION
                    present(CHILD_ID_MOTION_A, S_MOTION, "PIR", true); // CHILD ID =  70 and forcing ack for this child's messages
                    //FOR TEMP: Child ID from 10 to 18  (defined 8 as MAX)
                    #ifdef TEMP
                         int a;
                         a=i+10;
                         present(a, S_TEMP);
                    #ifdef DHTCODE
                    //FOR DHT: Child ID 50 and 60
                      present(CHILD_ID_HUM, S_HUM);
                    #ifdef DOOR
                    //For DOOR A
                    debouncer_a.update();
                      // Get the update value
                      int value_a = debouncer_a.read();
                      if (value_a != oldValue_a) {
                         // Send in the new value
                         send(msg_door_a.set(value_a==HIGH ? 1 : 0));
                         oldValue_a = value_a;
                    //For DOOR B
                    debouncer_b.update();
                      int value_b = debouncer_b.read();
                      if (value_b != oldValue_b) {
                         send(msg_door_b.set(value_b==HIGH ? 1 : 0));
                         oldValue_b = value_b;
                    #ifdef MOTION
                        // Read digital motion value
                        int valueMotion_a = digitalRead(DIGITAL_INPUT_SENSOR_MOTION_A);
                        if (valueMotion_a != oldMotion_a)
                         #ifdef MY_DEBUG
                         Serial.println(valueMotion_a);
                         #endif MY_DEBUG
                         send(msg_motion_a.set(valueMotion_a?"1":"0"));  // Send tripped value to gw
                         oldMotion_a = valueMotion_a;
                    //Loop Code ************************************************
                    //Resets every 1-2 minutes
                      if (x>0)
                        x=x-1;
                        y=y-1;
                        if (x==0 && y==0)
                         #ifdef MY_DEBUG
                      Serial.println("****** counters reached 0 **************");
                         x = 1600000;
                         y = 32767;
                    // So Let's fetch temperatures from Dallas sensors
                    #ifdef TEMP
                      sleep(conversionTime);
                     //   Serial.println("temperature:");
                     //   Serial.println(temperature);
                        #if COMPARE_TEMP == 1
                         int a=i+10;
                          send(msg_temp.setSensor(a).set(temperature,1));
                        #ifdef DHTCODE
                        dht.readSensor(true);
                        delay(2000);
                        float temperaturedht = dht.getTemperature();
                        if (isnan(temperaturedht))
                        else if (temperaturedht != lastTempdht || nNoUpdatesTempdht == FORCE_UPDATE_N_READS)
                         lastTempdht = temperaturedht;
                         if (!metric)
                          temperaturedht = dht.toFahrenheit(temperaturedht);
                         // Reset no updates counter
                         nNoUpdatesTempdht = 0;
                         temperaturedht += SENSOR_TEMP_OFFSET;
                         send(msgTemp.set(temperaturedht, 1));
                         #ifdef MY_DEBUG
                         Serial.print("T: ");
                         Serial.println(temperaturedht);
                         nNoUpdatesTempdht++;
                        float humiditydht = dht.getHumidity();
                        if (isnan(humiditydht))
                       else if (humiditydht != lastHumdht || nNoUpdatesHumdht == FORCE_UPDATE_N_READS) {
                       lastHumdht = humiditydht;
                       nNoUpdatesHumdht = 0;
                       send(msgHum.set(humiditydht, 1));
                       #ifdef MY_DEBUG
                       Serial.print("H: ");
                       Serial.println(humiditydht);
                        nNoUpdatesHumdht++;
                        //THERE IS ONLY RECEIVE CODE for RELAY.  DOOR, TEMP and HUM are just sent periodically and not on-demand
                        if (message.type==V_STATUS) {
                            // Change relay state
                            digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                            // Store state in eeprom
                    If we only choose the relay-related code, I can feel some reliability. Every command that is sent is executed.
                    If I activate just the temperature code, I start having signature failures when trying to open/close relays. Not always, but often, so reliability is affected. Example of trying to change the relay 4 (44:4).
                    May  3 18:31:32 nettemp mysgw: GWT:RFC:C=0,MSG=44;3;1;1;2;1
                    May  3 18:31:32 nettemp mysgw: !TSF:MSG:SEND,0-0-44-44,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                    May  3 18:31:32 nettemp mysgw: !TSF:MSG:SIGN FAIL
                    May  3 18:31:33 nettemp mysgw: GWT:RFC:C=0,MSG=44;3;1;1;2;1
                    May  3 18:31:33 nettemp mysgw: !TSF:MSG:SEND,0-0-44-44,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                    May  3 18:31:33 nettemp mysgw: !TSF:MSG:SIGN FAIL
                    May  3 18:31:34 nettemp mysgw: GWT:RFC:C=0,MSG=44;3;1;1;2;1
                    May  3 18:31:34 nettemp mysgw: !TSF:MSG:SEND,0-0-44-44,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                    May  3 18:31:34 nettemp mysgw: !TSF:MSG:SIGN FAIL
                    (nothing appears in the node log, as it haven't received anything).
                     __  __       ____
                            |___/                      2.2.0
                    16 MCO:BGN:INIT NODE,CP=RNNNAS--,VER=2.2.0
                    25 MCO:BGN:BFR
                    69 TSM:INIT
                    70 TSF:WUR:MS=0
                    77 TSM:INIT:TSP OK
                    79 TSM:INIT:STATID=44
                    81 TSF:SID:OK,ID=44
                    82 TSM:FPAR
                    102 TSF:MSG:SEND,44-44-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    159 TSF:MSG:READ,0-0-44,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    164 TSF:MSG:FPAR OK,ID=0,D=1
                    2109 TSM:FPAR:OK
                    2110 TSM:ID
                    2111 TSM:ID:OK
                    2113 TSM:UPL
                    2115 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    2122 TSF:MSG:READ,0-0-44,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    2127 TSF:MSG:PONG RECV,HP=1
                    2129 TSM:UPL:OK
                    2131 TSM:READY:ID=44,PAR=0,DIS=1
                    2136 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                    2142 TSF:MSG:READ,0-0-44,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                    2152 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                    2158 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                    2246 TSF:MSG:SEND,44-44-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=OK:2.2.0
                    2255 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    2262 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    2352 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
                    2360 TSF:MSG:READ,0-0-44,s=255,c=3,t=16,pt=0,l=0,sg=1:
                    2382 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    2397 TSF:MSG:READ,0-0-44,s=255,c=3,t=6,pt=0,l=1,sg=1:M
                    2485 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    2491 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    2581 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=11,pt=0,l=19,sg=1,ft=0,st=OK:MIXED JOAOABS SOTAO
                    2591 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    2598 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    2685 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=12,pt=0,l=3,sg=1,ft=0,st=OK:1.0
                    2694 TSF:MSG:SEND,44-44-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    2701 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    2791 TSF:MSG:SEND,44-44-0-0,s=1,c=0,t=3,pt=0,l=6,sg=1,ft=0,st=OK:RELAYS
                    2801 TSF:MSG:SEND,44-44-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    2807 TSF:MSG:READ,0-0-44,s=1,c=0,t=3,pt=0,l=6,sg=0:RELAYS
                    2812 TSF:MSG:ACK
                    2814 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    2904 TSF:MSG:SEND,44-44-0-0,s=2,c=0,t=3,pt=0,l=6,sg=1,ft=0,st=OK:RELAYS
                    2914 TSF:MSG:SEND,44-44-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    2920 TSF:MSG:READ,0-0-44,s=2,c=0,t=3,pt=0,l=6,sg=0:RELAYS
                    2926 TSF:MSG:ACK
                    2927 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    3015 TSF:MSG:SEND,44-44-0-0,s=3,c=0,t=3,pt=0,l=6,sg=1,ft=0,st=OK:RELAYS
                    3024 TSF:MSG:SEND,44-44-0-0,s=4,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    3031 TSF:MSG:READ,0-0-44,s=3,c=0,t=3,pt=0,l=6,sg=0:RELAYS
                    3036 TSF:MSG:ACK
                    3038 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    3125 TSF:MSG:SEND,44-44-0-0,s=4,c=0,t=3,pt=0,l=6,sg=1,ft=0,st=OK:RELAYS
                    3134 TSF:MSG:SEND,44-44-0-0,s=30,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    3140 TSF:MSG:READ,0-0-44,s=4,c=0,t=3,pt=0,l=6,sg=0:RELAYS
                    3145 TSF:MSG:ACK
                    3147 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    3234 TSF:MSG:SEND,44-44-0-0,s=30,c=0,t=0,pt=0,l=6,sg=1,ft=0,st=OK:DOOR_A
                    3244 TSF:MSG:SEND,44-44-0-0,s=31,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    3250 TSF:MSG:READ,0-0-44,s=30,c=0,t=0,pt=0,l=6,sg=0:DOOR_A
                    3256 TSF:MSG:ACK
                    3257 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    3344 TSF:MSG:SEND,44-44-0-0,s=31,c=0,t=0,pt=0,l=6,sg=1,ft=0,st=OK:DOOR_B
                    3353 TSF:MSG:SEND,44-44-0-0,s=70,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    3360 TSF:MSG:READ,0-0-44,s=31,c=0,t=0,pt=0,l=6,sg=0:DOOR_B
                    3365 TSF:MSG:ACK
                    3367 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    3460 TSF:MSG:SEND,44-44-0-0,s=70,c=0,t=1,pt=0,l=3,sg=1,ft=0,st=OK:PIR
                    3467 MCO:REG:REQ
                    3470 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                    3476 TSF:MSG:READ,0-0-44,s=70,c=0,t=1,pt=0,l=3,sg=0:PIR
                    3481 TSF:MSG:ACK
                    3483 TSF:MSG:READ,0-0-44,s=255,c=3,t=16,pt=0,l=0,sg=1:
                    3510 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    3524 TSF:MSG:READ,0-0-44,s=255,c=3,t=27,pt=1,l=1,sg=1:1
                    3609 MCO:PIM:NODE REG=1
                    3611 MCO:BGN:STP
                    3613 MCO:BGN:INIT OK,TSP=1
                    3619 TSF:MSG:SEND,44-44-0-0,s=30,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    3627 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    3714 TSF:MSG:SEND,44-44-0-0,s=30,c=1,t=16,pt=2,l=2,sg=1,ft=0,st=OK:1
                    3722 TSF:MSG:SEND,44-44-0-0,s=31,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    3734 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    3822 TSF:MSG:SEND,44-44-0-0,s=31,c=1,t=16,pt=2,l=2,sg=1,ft=0,st=OK:1
                    3832 TSF:MSG:SEND,44-44-0-0,s=70,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    3844 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    3932 TSF:MSG:SEND,44-44-0-0,s=70,c=1,t=16,pt=0,l=1,sg=1,ft=0,st=OK:0
                    26080 TSF:MSG:READ,0-0-44,s=1,c=3,t=16,pt=0,l=0,sg=1:
                    26106 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    26120 TSF:MSG:READ,0-0-44,s=1,c=1,t=2,pt=0,l=1,sg=1:0
                    26205 TSF:MSG:ACK REQ
                    26209 TSF:MSG:SEND,44-44-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                    Incoming change for sensor:1, New status: 0
                    26216 TSF:MSG:READ,0-0-44,s=1,c=3,t=16,pt=0,l=0,sg=1:
                    26240 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    26250 TSF:MSG:READ,0-0-44,s=1,c=1,t=2,pt=0,l=1,sg=1:0
                    26334 TSF:MSG:ACK REQ
                    26339 TSF:MSG:SEND,44-44-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                    29867 TSF:MSG:READ,0-0-44,s=2,c=3,t=16,pt=0,l=0,sg=1:
                    29888 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    29902 TSF:MSG:READ,0-0-44,s=2,c=1,t=2,pt=0,l=1,sg=1:0
                    29986 TSF:MSG:ACK REQ
                    29991 TSF:MSG:SEND,44-44-0-0,s=2,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                    Incoming change for sensor:2, New status: 0
                    29999 TSF:MSG:READ,0-0-44,s=2,c=3,t=16,pt=0,l=0,sg=1:
                    30022 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    30031 TSF:MSG:READ,0-0-44,s=2,c=1,t=2,pt=0,l=1,sg=1:0
                    30116 TSF:MSG:ACK REQ
                    30120 TSF:MSG:SEND,44-44-0-0,s=2,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                    31344 TSF:MSG:READ,0-0-44,s=3,c=3,t=16,pt=0,l=0,sg=1:
                    31366 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    31373 TSF:MSG:READ,0-0-44,s=3,c=1,t=2,pt=0,l=1,sg=1:0
                    31457 TSF:MSG:ACK REQ
                    31464 TSF:MSG:SEND,44-44-0-0,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                    31471 TSF:MSG:READ,0-0-44,s=3,c=3,t=16,pt=0,l=0,sg=1:
                    31498 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    31510 TSF:MSG:READ,0-0-44,s=3,c=1,t=2,pt=0,l=1,sg=1:0
                    31594 TSF:MSG:ACK REQ
                    31597 TSF:MSG:SEND,44-44-0-0,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                    32621 TSF:MSG:READ,0-0-44,s=4,c=3,t=16,pt=0,l=0,sg=1:
                    32643 TSF:MSG:SEND,44-44-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                    32657 TSF:MSG:READ,0-0-44,s=4,c=1,t=2,pt=0,l=1,sg=1:0
                    Incoming change for sensor:4, New status: 0
                    32752 TSF:MSG:SEND,44-44-0-0,s=31,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    32758 TSF:MSG:READ,0-0-44,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    32845 TSF:MSG:SEND,44-44-0-0,s=31,c=1,t=16,pt=2,l=2,sg=1,ft=0,st=OK:0
                    33015 MCO:SLP:MS=94,SMS=0,I1=255,M1=255,I2=255,M2=255
                    33020 TSF:TDI:TSL
                    33022 MCO:SLP:WUP=-1
                    33025 TSF:TRI:TSB
                    160429 MCO:SLP:MS=94,SMS=0,I1=255,M1=255,I2=255,M2=255
                    160434 TSF:TDI:TSL
                    160436 MCO:SLP:WUP=-1
                    160438 TSF:TRI:TSB
                    I'll keep doing some more tests and will report it here. Meanwhile if there is anything else you'd like me to try, do let me know.
                    Joaoabs
                    • joaoabsJ joaoabs
                      • 3.3V regulator
                      Code:
                       * Version 1.0
                       *      - NODE ID 44
                       * BOARD
                       * D2 - NRF24 IRQ
                       * D3 - RJ-45 (3)
                       * D6 - Relay (4)
                       * D7 - Relay (3)
                       * D8 - Relay (2)
                       * D9 - NRF CE
                       * D10- NRF CS
                       * D11- NRF MOSI
                       * D12- NRF MISO
                       * D13- NRF SCK
                       * A2 - RJ-45 (1)
                       * A3 - RJ-45 (4)
                       * A4 - I2C
                       * A5 - I2C
                      #define RELAY
                      //#define DHTCODE
                      #define DOOR
                      #define MOTION
                      //#define TEMP
                      #ifdef DOOR
                      int oldValue_a=-1;
                      int oldValue_b=-1;
                      #ifdef MOTION
                      int oldMotion_a=-1;
                      #ifdef TEMP
                      int numSensors=0;
                      bool metric = true;
                      long x = 327670;
                      int y = 32767;
                      #ifdef RELAY
                      #ifdef DHTCODE
                      //#include "DHT.h"
                      float lastTempdht;
                      float lastHumdht;
                      DHT dht;
                      void before()
                       #ifdef RELAY
                       #ifdef TEMP
                       sensors.begin();
                      #ifdef DOOR
                      #ifdef MOTION
                      #ifdef TEMP
                      #ifdef DHTCODE
                      #ifdef RELAY
                      #ifdef DOOR
                      #ifdef MOTION
                      #ifdef TEMP
                           int a;
                           a=i+10;
                           present(a, S_TEMP);
                      #ifdef DHTCODE
                      #ifdef DOOR
                      //For DOOR A
                      //For DOOR B
                      #ifdef MOTION
                           #ifdef MY_DEBUG
                           #endif MY_DEBUG
                        if (x>0)
                          x=x-1;
                          y=y-1;
                          if (x==0 && y==0)
                           #ifdef MY_DEBUG
                           x = 1600000;
                           y = 32767;
                      #ifdef TEMP
                           int a=i+10;
                          #ifdef DHTCODE
                          delay(2000);
                           if (!metric)
                           #ifdef MY_DEBUG
                         #ifdef MY_DEBUG
                          nNoUpdatesHumdht++;
                       __  __       ____
                              |___/                      2.2.0
                      25 MCO:BGN:BFR
                      69 TSM:INIT
                      70 TSF:WUR:MS=0
                      77 TSM:INIT:TSP OK
                      81 TSF:SID:OK,ID=44
                      82 TSM:FPAR
                      2109 TSM:FPAR:OK
                      2110 TSM:ID
                      2111 TSM:ID:OK
                      2113 TSM:UPL
                      2129 TSM:UPL:OK
                      2812 TSF:MSG:ACK
                      2926 TSF:MSG:ACK
                      3036 TSF:MSG:ACK
                      3145 TSF:MSG:ACK
                      3256 TSF:MSG:ACK
                      3365 TSF:MSG:ACK
                      3467 MCO:REG:REQ
                      3481 TSF:MSG:ACK
                      3611 MCO:BGN:STP
                      33020 TSF:TDI:TSL
                      33025 TSF:TRI:TSB
                      160434 TSF:TDI:TSL
                      160438 TSF:TRI:TSB
                      Joaoabs
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @joaoabs the failures you see are not signing failures. It is NACKs. Messages are not reaching its destination, and when that happens signing won't work. So you also get errors relating to signing as a consequence.
                      It is the rf link that is unstable in your latest log.
                      • joaoabsJ
                        joaoabsJ
                        joaoabs
                        Thanks Anticimex for replying back,
                        I understand now the root cause is not related with the signing itself. It makes sense.
                        I may have wrongly associated to it becasue I read somewhere that the radio communication can be affected by signing because the packets are full and therefore the probability to have a missed bit in the between is bigger.
                        However, the RF link is the same in test 1 and test 2 (~6m with line of sight), and the result is totally different... It must be something on the code, not in the RF link, don't you think?
                        Joaoabs
                        • joaoabsJ joaoabs
                          Joaoabs
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @joaoabs well, I agree that it should not affect the airborne part of it, but one way or another it prevents the messages from coming through. Perhaps your sensor communication induce some disturbance in the radio supply?
                          • joaoabsJ
                            joaoabsJ
                            joaoabs
                            #24
                            Some more testing:
                            I realised I was doing a rookie mistake: When testing, I changed PC and the default options to compile the mini-pro were 16MHz/5V on the new PC, while mine is 8MHz/3.3v.
                            I guess this difference in the clock was messing up the timmings on the 1-W bus, hence the eractic behaviour.
                            Now the sketch with the door/motion, relay and temp(DS18B20) seems to be more stable. Adding the DHT code, we get back to erratic behaviour, as the initial post, althought the used memory without "MY_DEBUG" is 70% used.
                            I'll be doing more tests and report back.
                            • joaoabsJ joaoabs
                              Some more testing:
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @joaoabs thanks for reporting. Is this with or without @tekka's patch?
                              • joaoabsJ joaoabs
                                Some more testing:
                                tekkaT
                                tekkaT
                                tekka
                                @joaoabs Please post then full debug log when you observe the erratic behaviour (previously mentioned patch must be applied).
                                joaoabsJ 1 Reply Last reply
                                • tekkaT tekka
                                  joaoabsJ
                                  joaoabsJ
                                  joaoabs
                                  @tekka What debug flag should I activate for this?
                                  When I see the erratic behavior there isn't nothing appearing in the serial console, even with the MY_DEBUG on, so I guess there should be other that is of your interest...
