  2. Enclosures / 3D Printing
  3. Domoticz Nextion remote
14 Posts 4 Posters 4.7k Views 4 Watching
  • MiKaM
    MiKaM
    MiKa
    nice idea ;)
    https://github.com/ledfreak3d/Domoticz-remote-
    https://www.youtube.com/watch?v=c9OlHDThYEU&t
    https://www.domoticz.com/forum/viewtopic.php?f=38&t=19472
    alexsh1A 1 Reply Last reply
      Nice idea indee, not sure about the battery life as it seems the esp8266 will never actually sleep and I don't know how much power is using the nextion while turned off
      • MiKaM MiKa
        nice idea ;)
        alexsh1A
        alexsh1A
        alexsh1
        @mika @gohan Yes, I saw it on Domoticz forum. Nice one.
        Mine is the same size, but much less functionality for a simple reason - I do not have anything else to control.
        • alexsh1A alexsh1
          alexsh1A
          alexsh1A
          alexsh1
          I did order Nextion though some time ago and it is in my "to do" list.
          The facie has just arrived. Hopefully I can finish it soon.
          Stay tuned!
            how is battery drain?
            alexsh1A 2 Replies Last reply
              alexsh1A
              alexsh1A
              alexsh1
              @gohan I did not have to charge the battery in 6 months. I am using Li-on 9v battery - I could have been more efficient with 3.7v one and implement a charger as well. I just did not bother.
              Do not forget that the controller is on very briefly to do scenes and then you turn it off.
                alexsh1A
                alexsh1A
                alexsh1
                @gohan thatโ€™s the exact battery Iโ€™m using
                It comes with a charger.
                http://s.aliexpress.com/7VZNrAby
                  How do you wake the mcu? The screen uses serial
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @gohan it is a top secret proprietary technology called a switch ๐Ÿ˜†๐Ÿ˜†๐Ÿ˜†
                    Itโ€™s very simple - you just do not need to have it on all the time. Alternatively you can put it up on the wall and use 240V as a power source
                      Ah, that's not fair ๐Ÿ˜
                      • Nca78N
                        Else there's a pretty simple thing called accelerometer, you can wake up you board with movement when you pick it up or with tap/double tap
                          In fact I was asking how do you wake the mcu with a tap on the screen, since I understood it uses only serial communication.
                          • Nca78N Nca78
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @nca78 thatโ€™s way too advanced. My principle is to keep it simple ;)
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @gohan I was never thinking like that. The startup time is about 1sec. Given Iโ€™m obsessed with a battery life and the device is only used occasionally, I could not come up with anything better than the switch.
                              With your input, this post could be even better ๐Ÿ’—
