  3. Relay output activates when power off/on
8 Posts 3 Posters 1.3k Views 3 Watching
  • JoupilJ Offline
    JoupilJ Offline
    Joupil
    I've just discovered NodeManager. Wow! So simple for coding great stuffs and mixing functions!
    Unfortunately I'm stuck resolving the issue below.
    The last node I created was built to open 3 doors (I've hacked an old Somfy remote controller) Each door is open/closed using a relay. I've used SensorLatchingRelay1Pin three times. It works like a charm.
    The problem is that when unplugging the node then replug it the relays are all activating. In case off power failure all doors will open at last!
    Is there something to know to solve that major issue?
    Thanks in advance,
    NodeManager Padawan.
    dbemowskD 1 Reply Last reply
      Do your relais activate when pin goes low?
      • JoupilJ Joupil
        Thanks in advance,
        dbemowskD Offline
        dbemowskD Offline
        @joupil Look in your setup() routine where you define the relay pins as outputs with:
        pinmode(relay, OUTPUT)
        and immediately after that, add this:
        dititalWrite(relay, HIGH);  //Or use LOW instead of HIGH depending on your relays
        to tell them to start in the off position. If you are using latching relays, depending on the type, you may need something else.
        • JoupilJ Offline
          JoupilJ Offline
          Joupil
          Thanks for all.
          NodeManager presents this method:
          // what to do during setup
          void SensorDigitalOutput::onSetup() {
          // setup the pin
          pinMode(_pin, OUTPUT);
          // setup the off pin if needed
          if (_pin_off > 0) pinMode(_pin_off, OUTPUT);
          // report immediately
          _report_timer->unset();
          // turn the relay off by default
          setStatus(OFF);
          Shall I write :
          // setup the pin
          dititalWrite(_pin, HIGH);
          or turn the relay On by default?
          Thank you
          • JoupilJ Joupil
            Thanks for all.
            // setup the pin
            setStatus(OFF);
            Shall I write :
            // setup the pin
            Thank you
            dbemowskD Offline
            dbemowskD Offline
            @joupil I guess the first thing is to know if you are actually using a latching relay or a standard relay module. If it is a standard relay module, then you need to check whether it is an active high or active low module. I believe that was the reason for @gohan's question. If your goal is to have the relay off when the node starts up, then there should be somewhere in NodeManager that would allow you to define what type of relay module you have, whether it is active high, or active low. It looks like this line calls a routine to set the relay to off by default during setup:
            setStatus(OFF);
            So the problem may be that you have your relay module defined wrong in NodeManger. I haven't used NodeManager myself yet, so I don't know how it works, but that would be my guess.
              In fact I was asking because it is a common problem when using active low relay boards
              • JoupilJ Offline
                JoupilJ Offline
                Joupil
                Unfortunatly none of these methods worked for me.
                • "setStatus(OFF);" was already set in NodeManager
                • I tried to set it "ON": the result was the same
                • I changed this setup to "dititalWrite(_pin, HIGH);" then the debugger displays "digitalWrite not declared" (well, I don't know what to do, I'm not an experienced coder)
                For all: the relays turn on when pins go high.
                To me the original setup is correct but with no effect at startup. (Setup is in the file NodeManagerLibrary.ino)
                I wrote a simple program 2 years ago and wanted to switch to NodeManager. But this issue is annoying. In this old program the method was following:
                // Fetch relay status
                present(sensor, S_BINARY);
                pinMode(pin, OUTPUT);
                // Set relay to 0
                digitalWrite(pin, RELAY_OFF);}
                This worked fine with no relay switch at startup.
                Still stuck...
                Thank you in advance for your help.
                Joupil
                • JoupilJ Offline
                  JoupilJ Offline
                  Joupil
                  I solved this issue by simply commenting
                  //setStatus(OFF);
                  in NodeManagerLibrary.ino
                  Thanks for all
                  Joupil
                  11.8k
                  113.2k
