  3. What's the "best" UPS for a Raspberry Pi 3B?
51 Posts 12 Posters 49.7k Views 12 Watching
  • alexsh1A alexsh1
    @gohan said in What's the "best" UPS for a Raspberry Pi 3B?:
    anyway 2A is more than enough for a Raspberry
    No, I do not think it is enough. They recommend 2.5A PSU for the latest RPI. I have 3A power supply for RPi3B. 2A was not enough, but I must say I have a few bits and bobs attached to my RPi like camera or Z-wave USB module
    @alexsh1 said in What's the "best" UPS for a Raspberry Pi 3B?:
    I did extensive measurements of the current drawn from the RPI3 and you can actually run on 1A, the extra power depends on the devices you connect to it (if you count the 4USB ports it is potentially 4x0.5A = 2A, you add the 0.7A from the RPI3 itself and you end up in the 2.5/3A range)
    sundberg84S alexsh1A 2 Replies Last reply
      sundberg84S
      sundberg84S
      @gohan cpu- load ?
        0.7A at full CPU load, while in idle it is about 0.2/0.25A
          alexsh1A
          alexsh1A
          alexsh1
          @gohan I did the same thing too. Only for my set-up. I am not interesting powering a bare RPi. 2.5A is not enough in my case - I am using 3A PSU. I suppose this is due to 20x4 screen I am running from the RPi together with other peripherals.
          • alexsh1A alexsh1
            @alexsh1 Which power supply are you using to supply the 3A?
            • rozpruwaczR
              rozpruwaczR
              rozpruwacz
              I tested the UPS PIco HV3.0B HAT Stack. On Rpi 1B and 3B. And it works perfectly :) maybe installation of the software is not very easy and the documentation is not very clear but i think it is worth the effort. And I got it for half the price of rpi3. Another +1 is that it has additional 3.3V ldo that can supply 150mA, should be sufficient to power the nrf24l01+ pa/lna module :)
                #45
                Just thought I'd mention that last week we had a lightning strike that was close enough that it completely fried both my irrigation controller and also the UPS on my wife's computer. Her computer did survive it though. So, although the odds may seem remote, it does happen. How lithium batteries would react to a lightning strike is unknown to me, so that's one of the reasons why I've ruled them out for use in a UPS. Unfortunately, doing so does seem to narrow the options considerably.
                alexsh1A 1 Reply Last reply
                  the battery is not the problem, but how the power supply will handle the voltage spike
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @neverdie for the lightning protection I use a surge protection extension lead like this
                    https://www.amazon.ca/Belkin-6-Outlet-Commercial-Protector-Rotating/dp/B000JV3CKA
                    Additionally, UPS PIco has got the following protection:
                    • System Protection
                    • Direct Raspberry Pi® Hardware Reset Button via Spring Test Pin (pogo pin)
                    • Programmable Watch-Dog Hardware feature (Still Alive Timer)
                    • PPTC 2.6A fuse
                    • ZVD circuit on 5V GPIO connections
                    • Microcontroller watch-dog
                    • Over Temperature protection
                    • Over Current protection
                    Re PSU, this is the one I have
                    Raspberry Pi 3 Charger, Aukru 5V 3000mA Power Supply 3A Micro USB Charger for Raspberry Pi 3 Model B / Pi 2 Model B / B+ Plus, Banana pi https://www.amazon.co.uk/dp/B017YW2CKM/ref=cm_sw_r_cp_api_i_o9d9AbBYH266F
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @gohan said in
                      Not a problem - a good surge protection can handle it. I have all my electronic devices including router powered through the surge protected extension lead
                      • siddarth sidS
                        siddarth sidS
                        siddarth sid
                        This thread is old, but still consists of the best suggestions for a Raspberry Pi UPS so adding my findings here.
                        Despite Pi being used for a lot of battery-powered projects, it's surprising to see that a well-defined UPS is not available.
                        While most of the above-suggested power boards will work fine, they lack form factor and customizability. I would rather take an open-source design and tweak it to my needs than just using a off-shelf black box.
                        So I am planning to improvise on this design called ["DIY Raspberry Pi UPS – An Uninterrupted Power Supply to Keep your Pi Safe during Power Failure"](DIY Raspberry Pi UPS – An Uninterrupted Power Supply to Keep your Pi Safe during Power Failure)
                        The author has provided both schematics and PCB layout so it should be easy to tweak the desing. The board is already designed to handle 1.5A (continous) and 3A (peak current) which would suffice well for my project. Though I could really use a software on/off feature like i should be able to shift between battery power and main power through a GPIO pin. Will share the design when I am until.
                        Until then if anyone has found better designs or features, please update me.
                        Power to you guys, thanks
                        • siddarth sidS siddarth sid
                          zboblamontZ
                          zboblamontZ
                          zboblamont
                          @siddarth-sid Perhaps irrelevant since form-factor featured in your post, but...
                          I put in a UPS which featured on Instructables a while back based on a MeanWell AD-55A PSU, which is still working since 2018. It's neither not neat or compact but has sailed through multiple power cuts suffered here with aplomb. Simple enough to wire up, no processing required, the SMPS does it all.
                          Never did get round to powering the router from it as originally intended, but ain't dead yet...
                          I think this links https://forum.mysensors.org/post/100533
                          • bjacobseB
                            bjacobseB
                            bjacobse
                            I'm quite lazy, and use this approach and use a USB powerbank, and check if DHCP server is alive or dead (Dead= no 230V)
                            https://raspi-ups.appspot.com/en/index.jsp
