  3. Latest beta build of Domoticz (9379) crashes when adding new sensors
14 Posts 3 Posters 3.7k Views 3 Watching
    can you try to make another gw on the fly with some other arduino board or esp8266? just to rule out the raspberry as much as possible. Try to roll back also to gw 2.2 and lower PA level to MIN
    • GertSandersG
      GertSandersG
      GertSanders
      I went back to the stable release of Domoticz, still use the beta ethernet gateway and now presentation of sensors is back to normal.
      But it all started with the fact that I wanted to include a sensor based on the atmega1284p. That still seems to be a probem. The code on the sensor side is the Arduino MySensors library (2.2.0).
      So as an update: presentation of sensors does crash on 9379, still waiting for a newer version of Domoticz before I move to the beta again.
      alexsh1A 1 Reply Last reply
      • GertSandersG GertSanders
        alexsh1A
        alexsh1A
        alexsh1
        @gertsanders I replied here.
        https://forum.mysensors.org/topic/9059/solved-mys-2-2-0-my_debug-fails-on-certain-bootloaders/7
        Let's get rid of your !TSM:FPAR:FAIL issue first. ID will not be issued if parent is not found.
        • alexsh1A
          alexsh1A
          alexsh1
          @GertSanders
          Hi Gert. Any luck?
          GertSandersG 2 Replies Last reply
          • alexsh1A alexsh1
            @GertSanders
            Hi Gert. Any luck?
            GertSandersG
            GertSandersG
            GertSanders
            @alexsh1 nope. The atmega328p's all work properly and get recognised. The atmega1284p never gets a reply.
            I'm wondering if it has to do with the selection of pinout. I selected "Standard" pinout, which is a pin definition used in AVR Freaks site. There is also Bobuino and Sanguino. Still need to test those.
            • alexsh1A alexsh1
              @GertSanders
              Hi Gert. Any luck?
              GertSandersG
              GertSandersG
              GertSanders
              @alexsh1
              SOLVED: the problem with my atmega1284p was the mapping of the CE pin.
              I needed to add the following to my sketch:
              #define MY_RF24_CE_PIN 1
              The reason is that I used a "standard" pinout, so CE is not on Arduino pin 9.
              In my pin-definition "CE" is Arduino pin 1 or chip pin PB1.
              There are several mappings possible for this chip:
              https://github.com/MCUdude/MightyCore
              So I need to look at the pin mapping again, and may refresh the boot loader with one of the MightyCore boot loaders ( I flashed this chip back in early 2015).0_1525511039763_IMG_0375.JPG
              I use the following mapping:
              // ATMEL ATMEGA1284P
              //           (D 0) PB0  1|        |40  PA0 (AI 0 / D24)
              //           (D 1) PB1  2|        |39  PA1 (AI 1 / D25)
              //      INT2 (D 2) PB2  3|        |38  PA2 (AI 2 / D26)
              //       PWM (D 3) PB3  4|        |37  PA3 (AI 3 / D27)
              //    PWM/SS (D 4) PB4  5|        |36  PA4 (AI 4 / D28)
              //      MOSI (D 5) PB5  6|        |35  PA5 (AI 5 / D29)
              //  PWM/MISO (D 6) PB6  7|        |34  PA6 (AI 6 / D30)
              //   PWM/SCK (D 7) PB7  8|        |33  PA7 (AI 7 / D31)
              //                 RST  9|        |32  AREF
              //                 VCC 10|        |31  GND
              //                 GND 11|        |30  AVCC
              //               XTAL2 12|        |29  PC7 (D 23)
              //               XTAL1 13|        |28  PC6 (D 22)
              //      RX0 (D 8)  PD0 14|        |27  PC5 (D 21) TDI
              //      TX0 (D 9)  PD1 15|        |26  PC4 (D 20) TDO
              // RX1/INT0 (D 10) PD2 16|        |25  PC3 (D 19) TMS
              // TX1/INT1 (D 11) PD3 17|        |24  PC2 (D 18) TCK
              //      PWM (D 12) PD4 18|        |23  PC1 (D 17) SDA
              //      PWM (D 13) PD5 19|        |22  PC0 (D 16) SCL
              //      PWM (D 14) PD6 20|        |21  PD7 (D 15) PWM
              And there is some renaming here:
              static const uint8_t SS   = 4;
              static const uint8_t MOSI = 5;
              static const uint8_t MISO = 6;
              static const uint8_t SCK  = 7;
              static const uint8_t SDA = 17;
              static const uint8_t SCL = 16;
              static const uint8_t LED = 7;
              static const uint8_t A0 = 24;
              static const uint8_t A1 = 25;
              static const uint8_t A2 = 26;
              static const uint8_t A3 = 27;
              static const uint8_t A4 = 28;
              static const uint8_t A5 = 29;
              static const uint8_t A6 = 30;
              static const uint8_t A7 = 31;
              So most pins mapped correctly, except for CE ...
              fixed now with the #define
                @alexsh1
                //                 RST  9|        |32  AREF
                //                 VCC 10|        |31  GND
                //                 GND 11|        |30  AVCC
                alexsh1A
                alexsh1A
                alexsh1
                @gertsanders that’s interesting. How exactly do you connect nrf24l01+?
                I have Mightyduino
                http://www.innovafabs.eu/index.php?route=product/category&path=18_64
                Glad you sorted it out
                • alexsh1A alexsh1
                  I have Mightyduino
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @alexsh1
                  MISO, MOSI and SCK are connected to the pins that carry this function
                  CE -> PB1
                  CSN -> PB4
                  I use PB0 to show a flashing in the bootloader.
                    @alexsh1
                    CE -> PB1
                    CSN -> PB4
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @gertsanders Thank you! You are using prototype wires or did you come up with a PCB adapter? I would like to MySensorise it, but would rather use an adapter.
                    I also wish there was a solder joint for the power LED
                    • alexsh1A alexsh1
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @alexsh1 hi Alex, it is how I routed my PCB.
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @gertsanders but do you have an adapter PCB like this one
                        https://oshpark.com/shared_projects/CtW4Xaow
                        or connect your PCB with wires?
                        • alexsh1A alexsh1
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @alexsh1
                          I have a DIL connector on my PCB, and the nrf24l01+ plugs into it. On my testboard I'm still using the non-smd version.
                            @alexsh1
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @gertsanders said in Latest beta build of Domoticz (9379) crashes when adding new sensors:
                            DIL connector
                            :+1:
                            I do not have a PCB. I have the atmega1284p board (Mightyduino) -> https://oshpark.com/shared_projects/zuZ4OIae
                            and would like to have a moteino like board with either nrf24l01+ or rfm69 on it
                            I can use wires to connect a transceiver but would like to have a neat solution
                            12.5k
