  3. Multiple messages to same node, seems to miss one.
17 Posts 4 Posters 4.3k Views 3 Watching
  • YveauxY Yveaux
    @crankycoder You didn't describe your hardware, but if it's based on nRF24 the issue could be that this radio has a 3 level deep queue for incoming messages. If more than 3 messages come in faster than the node can handle, the last message(s) will get lost.
    You can counter this by either sending the messages with more time inbetween or turn on message buffering by defining MY_RX_MESSAGE_BUFFER_FEATURE (make sure the nRF24 IRQ pin is connected!)
    There's some discussion on the topic here: https://www.mysensors.org/build/serial_gateway
    CrankyCoderC
    CrankyCoderC
    CrankyCoder
    @yveaux apologies. I have a raspberry pi mqtt gateway. there is a repeater in between the gateway and the module under the bed. I will look into that buffer feature or see if i can get openhab to slow down the group commands.
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • electrikE electrik
      Is this feature MY_RX_MESSAGE_BUFFER_FEATURE somehow available on the ESP8266 gateway too? Or an alternative?
      @electrik yes it is available
      Edit: Sorry, seems like it is not available on esp8266.
      electrikE 1 Reply Last reply
        electrikE
        electrikE
        electrik
        @mfalkvidd That is good to hear. What should I do to have that enabled?
        • YveauxY Yveaux
          CrankyCoderC
          CrankyCoderC
          CrankyCoder
          @yveaux is this something that could be a problem at the repeater and the node itself? I don't think it's the gateway as the messages aren't coming in, it's being delivered to the node.
          www.CrankyCoder.net
          MySensors: 2.3
            @electrik It should have been sufficient to follow the documentation, but it seems like MY_RX_MESSAGE_BUFFER_FEATURE is only available for atmega328 (or perhaps also for SAMD and Linux/Raspberry Pi but definitely not for esp8266).
            I have created an issue to clarify the documentation.
            Thanks to @Yveaux for notifying me.
              electrikE
              electrikE
              electrik
              @mfalkvidd all right thanks. Is there an alternative to avoid losing messages on an ESP8266 MQTT gateway?
                @electrik decrease the message rate or the number of messages sent in bursts
                • YveauxY Yveaux
                  electrikE
                  electrikE
                  electrik
                  wrote on last edited by electrik
                  @yveaux What is a rate that is still expected to be possible? Or, how often is the buffer from the NRF emptied?
                    @electrik that's a tough one... Every time loop() executes, or if you call eg wait() the queue is emptied.
                    So it all depends on what you do in your sketch.
                    • YveauxY Yveaux
                      electrikE
                      electrikE
                      electrik
                      @yveaux so by calling wait () a couple of times in the loop, it will be processed more often. I will try that, thanks
                      • electrikE
                        electrikE
                        electrik
                        @Yveaux do you know if there are plans to support this buffering on the ESP8266 or the ESP32? Is it all related to SoftSPI?
                          @electrik the problem is the arduino port, not the mySensors stack. Last time I checked the issue on GitHub was still unresolved...
                          • YveauxY Yveaux
                            @yveaux This seems to be the original issue, which is closed: https://github.com/esp8266/Arduino/issues/1943
                            That sounds hopeful, but no time to check it right now...
                            • YveauxY Yveaux
                              electrikE
                              electrikE
                              electrik
                              @yveaux Did you find some time already to have a look at this? :-)
                              12.5k
