  3. Soft WDT reset on ESP8266 RFM69 gateway after find parent
21 Posts 3 Posters 3.6k Views 3 Watching
  • mfalkviddM
    btw, this is the graph I have gotten from RSSI for the last 8 months.
      Isn't it better to log the rssi from the nodes? I mean that the gw is sending its rssi every time it receives something, right? So you could have different rssi values for each node.
        @mfalkvidd said in Soft WDT reset on ESP8266 RFM69 gateway after find parent:
        It looks like a 'Sound Level' chart, judging from the title...
          @gohan logging the rssi value on the node would mean additional radio traffic, and I am more interested in how well the node reaches the gateway than how well the gateway reaches the node anyway.
          gohanG 1 Reply Last reply
          • YveauxY Yveaux
            @yveaux yes. Sound is the most appropriate message type I could find that Domoticz supports.
              @mfalkvidd but how do you know which node rssi is which? You are getting an average of mixed values since domoticz is recording one value every 5 minutes
                @gohan
                if (message.sender == 1)
                  so you are measuring just one node?
                    @gohan yes. If I create one more node I'll probably let the gateway present two rssi children.
                      I just report node TX power every now and then to get an idea of the signal strength and background rssi noise to figure out if there are interference around the node
                      • mfalkviddM
                        Since my node had been reporting without problems for several days, I disconnected the gateway from my computer and plugged it in to a phone charger instead. The gateway came up as it should and Domoticz reconnected but I am no longer getting any messages from the node. Reset the node but that didn't help. Back to troubleshooting.
                          Chinese phone charger? :D
                            @gohan no. I don't want to die.
                              Have you tried adding a ceramic cap on the Vin or 3.3v pins ?
                                @gohan no. I haven't needed one on my nrf24 nodes and I thought the rfm was less sensitive to noise. Isn't it?
                                  Well... kind of. Noise on power rail could also cause other problems too. I suggested the ceramic as it helps filtering the high frequencies in case your phone charger voltage is not very clean
                                  • mfalkviddM
                                    Alright. I'll add a ceramic capacitor.
                                    For compleeness, here is my complete sketch for the node:
                                    // Enable debug prints
                                    #define MY_NODE_ID 1
                                    #define MY_RADIO_RFM69
                                    #define MY_IS_RFM69HW
                                    #define MY_RFM69_FREQUENCY RFM69_433MHZ // RFM69_433MHZ for development branch, RF69_433MHZ for master
                                    #define MY_RF69_IRQ_PIN 2
                                    #define MY_RF69_SPI_CS 10
                                    #include <MySensors.h> // From Library Manager
                                    #include <BME280I2C.h> // From Library Manager
                                    BME280I2C bme;
                                    static const uint64_t UPDATE_INTERVAL = 300000;
                                    #define CHILD_ID_HUM 0
                                    #define CHILD_ID_TEMP 1
                                    #define CHILD_ID_VCC_BEFORE 2
                                    #define CHILD_ID_VCC_AFTER 3
                                    MyMessage msgVccBefore(CHILD_ID_VCC_BEFORE, V_VOLTAGE);
                                    MyMessage msgVccAfter(CHILD_ID_VCC_AFTER, V_VOLTAGE);
                                    //TODO: Add pressure from BME280?
                                    //TODO: Add light detection (irq-based, LDR)
                                    //TODO: Add flooding detection
                                      sendSketchInfo("StorageRoom", "1.1");
                                      present(CHILD_ID_HUM, S_HUM);
                                      wait(100);
                                      wait(100);
                                      present(CHILD_ID_VCC_BEFORE, S_CUSTOM);
                                      wait(100);
                                      present(CHILD_ID_VCC_AFTER, S_CUSTOM);
                                      if (! bme.begin()) {
                                        Serial.println("Could not find a valid BME280 sensor, check wiring! Continuing without sensor...");
                                      static float lastTemp;
                                      static float lastHum;
                                      send(msgVccBefore.set(readVcc() / 1000.0, 3));
                                      float temperature = bme.temp();
                                      if (isnan(temperature)) {
                                        Serial.println("Failed reading temperature");
                                        // Only send temperature if it changed since the last measurement
                                        lastTemp = temperature;
                                    #ifdef MY_DEBUG
                                      Serial.print("T: ");
                                      float humidity = bme.hum();
                                      if (isnan(humidity)) {
                                        Serial.println("Failed reading humidity");
                                        // Only send humidity if it changed since the last measurement
                                        lastHum = humidity;
                                    #ifdef MY_DEBUG
                                      Serial.print("H: ");
                                      Serial.println(humidity);
                                      send(msgVccAfter.set(readVcc() / 1000.0, 3));
                                      sleep(UPDATE_INTERVAL);
                                    long readVcc() {
                                      // From http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                                    and for the gateway:
                                    // Based on https://github.com/mysensors/MySensors/tree/master/examples/GatewayESP8266OTA
                                    #include <ArduinoOTA.h>
                                    #define MY_BAUD_RATE 74880 // To be able to see reset messages
                                    #define WIFI_REPORT_INTERVAL 300000
                                    #define MY_RF69_IRQ_PIN D2
                                    #define MY_RF69_SPI_CS D8
                                    #define MY_GATEWAY_ESP8266
                                    #define MY_WIFI_SSID "Mr-IoT.com"
                                    #include "settings.h"
                                    #define MY_HOSTNAME "RFM69-Gateway"
                                    #define MY_PORT 5003
                                    #if defined(MY_USE_UDP)
                                    #include <WiFiUDP.h>
                                    #include <ESP8266WiFi.h>
                                    #define CHILD_ID_WIFI_RSSI 0
                                    MyMessage msgWifiRssi(CHILD_ID_WIFI_RSSI, V_LEVEL);
                                    #define CHILD_ID_RSSI1 1
                                    MyMessage msgRssi1(CHILD_ID_RSSI1, V_LEVEL);
                                    bool sendRssi = false;
                                    int16_t rssi;
                                      ArduinoOTA.onStart([]() {
                                        DEBUG_OUTPUT("ArduinoOTA start\n");
                                      ArduinoOTA.onEnd([]() {
                                        DEBUG_OUTPUT("\nArduinoOTA end\n");
                                      ArduinoOTA.setPassword((const char *)OTA_PASSWORD);
                                      ArduinoOTA.setHostname(MY_HOSTNAME);
                                      ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
                                        DEBUG_OUTPUT("OTA Progress: %u%%\r", (progress / (total / 100)));
                                      ArduinoOTA.onError([](ota_error_t error) {
                                        DEBUG_OUTPUT("Error[%u]: ", error);
                                        if (error == OTA_AUTH_ERROR) {
                                          DEBUG_OUTPUT("Auth Failed\n");
                                        } else if (error == OTA_BEGIN_ERROR) {
                                          DEBUG_OUTPUT("Begin Failed\n");
                                        } else if (error == OTA_CONNECT_ERROR) {
                                          DEBUG_OUTPUT("Connect Failed\n");
                                        } else if (error == OTA_RECEIVE_ERROR) {
                                          DEBUG_OUTPUT("Receive Failed\n");
                                        } else if (error == OTA_END_ERROR) {
                                          DEBUG_OUTPUT("End Failed\n");
                                      ArduinoOTA.begin();
                                      present(CHILD_ID_WIFI_RSSI, S_SOUND);
                                      wait(100);
                                      present(CHILD_ID_RSSI1, S_SOUND);
                                    long lastSend = 0;
                                      ArduinoOTA.handle();
                                      if (millis() - lastSend > WIFI_REPORT_INTERVAL) {
                                        send(msgWifiRssi.set(WiFi.RSSI(), 1));
                                        lastSend = millis();
                                      if (sendRssi) {
                                        sendRssi = false;
                                        send(msgRssi1.set(rssi, 0));
                                      rssi = _radio.RSSI;
                                      if (message.sender == 1) {
                                        sendRssi = true;
                                      BME280I2C bme;
                                        wait(100);
                                        wait(100);
                                        wait(100);
                                      #ifdef MY_DEBUG
                                          lastHum = humidity;
                                      #ifdef MY_DEBUG
                                      long readVcc() {
                                      int16_t rssi;
                                        ArduinoOTA.begin();
                                        wait(100);
                                      long lastSend = 0;
                                        if (sendRssi) {
                                          sendRssi = false;
                                        rssi = _radio.RSSI;
                                          sendRssi = true;
                                      #21
                                      About 35 minutes after I reset the node, it started reporting again (without any other changes). I have no idea what caused it to start working.
                                      12.5k
