  3. battery powered sensor / watchdog?
29 Posts 8 Posters 5.9k Views 8 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    oh don't say that. aliexpress is my addiction!!!!
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    alexsh1A 1 Reply Last reply
    • CrankyCoderC CrankyCoder
      alexsh1A
      alexsh1A
      alexsh1
      @crankycoder said in battery powered sensor / watchdog?:
      I do like most people - its easier and one does not have to spend 50 bucks to get a free shipping. No brainer. However, quality may be compromised too.
      CrankyCoderC 1 Reply Last reply
      • alexsh1A alexsh1
        CrankyCoderC
        CrankyCoderC
        CrankyCoder
        did you do anything to try to over come it? or do you think either spending more for better quality or maybe an external watch dog chip?
        www.CrankyCoder.net
        MySensors: 2.3
          alexsh1A
          alexsh1A
          alexsh1
          @crankycoder I think the biggest issue for me is that I’m not ordering in large quantities. AliExpress or ebay are really competitive if you need a few components.
          Digi-key for example wants me to have a minimum spending of £30 for free shipping (AliExpress is offering free shipping).
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            agreed. hard to beat aliexpress for pricing.
            www.CrankyCoder.net
            MySensors: 2.3
            ileneken3I 1 Reply Last reply
              ileneken3I
              ileneken3I
              ileneken3
              @crankycoder
              Speaking of pricing, a Pro Mini 3.3Mhz can be had for as little as $2-$3. Couldn't that be used to provide all the functionality (and more) of a TPL5010? Of course, it would require a small programming with a small script that uses low power sleep, removing the LED, maybe regulator too.
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                that's where the problem is. the whole sensor is a pro mini. it periodically stops doing it's thing.
                www.CrankyCoder.net
                MySensors: 2.3
                  ileneken3I
                  ileneken3I
                  ileneken3
                  @crankycoder
                  What I meant was that keep the sensor as is (whether it is a pro mini or anything else), and use a different pro mini as the watchdog - in place of the TPL5010. In this case, it would take a double board failure in order to have a complete failure.
                  • CrankyCoderC
                    CrankyCoderC
                    CrankyCoder
                    hmmm possible. power consumption would be a concern. having a second node running granted it wouldn't have a radio. I could potentially do the same thing with an attiny85 as it's smaller and lower power. It gets the cost down a little too... about to the same price as as the TPL5010. lol. in a pinch a pro mini would definitely work. Since I have some attiny85s that may be my option right now since i have them and don't have to buy the TPL5010's.
                    I think Jon Oxer did something with a hardware external watchdog like that. I am now wondering if i could use the attiny85, have it sleep as well. Wakeup hourly to see if it should reset the sensor. But also wake up on interrupt, where in the sensor if it's running well would pulse to the attiny. The tiny would reset the counter. Then each hour if the tiny wakes up, and the sensor hasn't reported in a couple hours, it would just reset it.
                    This is an actual possibility. lol
                    www.CrankyCoder.net
                    MySensors: 2.3
                    • electrikE
                      electrikE
                      electrik
                      IMHO, a watchdog reset is something that shouldn't occur normally. If it does, something is wrong in your code and that should be fixed...
                      Or are there maybe packets that get lost?
                      • CrankyCoderC
                        CrankyCoderC
                        CrankyCoder
                        i fully agree. But my sensor bombs out after a week or so of running. It's just a temp sensor used from the examples. Only thing I did was change the sleep timeout. So i am thinking either there is something with the cheap pro mini clones. Or something with the radio not sending. Which could be it, for all I know it's waking up and the arduino is saying everything is good but the radio isn't working. The only thing I know for certain is a reset brings it all back online.
                        Quite possible the packets are lost in the RF transmission. Just difficult to leave a serial monitor hooked up to it outside for a week till it dies lol.
                        :joy:
                        www.CrankyCoder.net
                        MySensors: 2.3
                        • electrikE
                          electrikE
                          electrik
                          wrote on last edited by electrik
                          Yes I understand. It is hard to find the cause in these cases. Do you have the possibility to move the node closer to the gateway or add a repeater to see if the problem persists?
                          Edit: or hookup the serial monitor, but place the node inside somewhere :-)
                          • CrankyCoderC
                            CrankyCoderC
                            CrankyCoder
                            I have definitely thought of throwing a repeater in the room closest to where it is outside. That could definitely help. Can't move it closer since it's a temp sensor in my pool lol.
                            Wonder if i made a connector out of rj45 if it would work over that length to something inside :)
                            www.CrankyCoder.net
                            MySensors: 2.3
                            • electrikE
                              electrikE
                              electrik
                              so just to make sure I understand. Is the node also in the pool? Or just the sensor?
                              • CrankyCoderC
                                CrankyCoderC
                                CrankyCoder
                                just the sensor. Node is in box outside of the pool.
                                www.CrankyCoder.net
                                MySensors: 2.3
                                • E
                                  E
                                  executivul
                                  Put an esp wifi node in the box with a beefier battery, or another box next to the first one if it isn't large enough. There is an "esp bridge" app that can easily do serial monitoring over wifi. That way you should have console output from the node when ot craps out. I've used it to debug some app that controls some contactors via a 5v relay board, turning contactors off sent the w5500 to Valhalla, the debug output via the esp saved the day since the device is located in a cielling a few meters up.
                                  • CrankyCoderC
                                    CrankyCoderC
                                    CrankyCoder
                                    This is a cool idea. Definitely worth throwing some bigger batteries at it for debugging. I am looking for this bridge stuff now :)
                                    www.CrankyCoder.net
                                    MySensors: 2.3
                                    E 1 Reply Last reply
                                      E
                                      E
                                      executivul
                                      @crankycoder https://github.com/jeelabs/esp-link
                                        I eneble wdt on pretty much all my nodes. Just remember to disable it before entering sleep. How did you setup the node? Do you have any booster running?
                                        • CrankyCoderC
                                          CrankyCoderC
                                          CrankyCoder
                                          Where do you put your enable/disable watchdog? My node sleeps for 90 minutes at a time. Do you mean like a voltage booster? no, but i am monitoring the battery voltage so i know when it gets close to the 3.3 that the radio needs.
                                          www.CrankyCoder.net
                                          MySensors: 2.3
                                          12.5k
