  3. battery powered sensor / watchdog?
29 Posts 8 Posters 5.9k Views 8 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    i fully agree. But my sensor bombs out after a week or so of running. It's just a temp sensor used from the examples. Only thing I did was change the sleep timeout. So i am thinking either there is something with the cheap pro mini clones. Or something with the radio not sending. Which could be it, for all I know it's waking up and the arduino is saying everything is good but the radio isn't working. The only thing I know for certain is a reset brings it all back online.
    Quite possible the packets are lost in the RF transmission. Just difficult to leave a serial monitor hooked up to it outside for a week till it dies lol.
    :joy:
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • electrikE
      electrikE
      electrik
      wrote on last edited by electrik
      Yes I understand. It is hard to find the cause in these cases. Do you have the possibility to move the node closer to the gateway or add a repeater to see if the problem persists?
      Edit: or hookup the serial monitor, but place the node inside somewhere :-)
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        I have definitely thought of throwing a repeater in the room closest to where it is outside. That could definitely help. Can't move it closer since it's a temp sensor in my pool lol.
        Wonder if i made a connector out of rj45 if it would work over that length to something inside :)
        www.CrankyCoder.net
        MySensors: 2.3
        • electrikE
          electrikE
          electrik
          so just to make sure I understand. Is the node also in the pool? Or just the sensor?
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            just the sensor. Node is in box outside of the pool.
            www.CrankyCoder.net
            MySensors: 2.3
            • E
              E
              executivul
              Put an esp wifi node in the box with a beefier battery, or another box next to the first one if it isn't large enough. There is an "esp bridge" app that can easily do serial monitoring over wifi. That way you should have console output from the node when ot craps out. I've used it to debug some app that controls some contactors via a 5v relay board, turning contactors off sent the w5500 to Valhalla, the debug output via the esp saved the day since the device is located in a cielling a few meters up.
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                This is a cool idea. Definitely worth throwing some bigger batteries at it for debugging. I am looking for this bridge stuff now :)
                www.CrankyCoder.net
                MySensors: 2.3
                E 1 Reply Last reply
                • CrankyCoderC CrankyCoder
                  E
                  E
                  executivul
                  @crankycoder https://github.com/jeelabs/esp-link
                    I eneble wdt on pretty much all my nodes. Just remember to disable it before entering sleep. How did you setup the node? Do you have any booster running?
                    • CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      Where do you put your enable/disable watchdog? My node sleeps for 90 minutes at a time. Do you mean like a voltage booster? no, but i am monitoring the battery voltage so i know when it gets close to the 3.3 that the radio needs.
                      www.CrankyCoder.net
                      MySensors: 2.3
                        I enable it at beginning of loop and disable it before the sleep. What battery do you use? Btw the nrf24 radio can go down to 1.8V
                        • CrankyCoderC
                          CrankyCoderC
                          CrankyCoder
                          Im using an 18650. currently it's sitting around 3.9v.
                          Do you have a link to the proper "mysensors" way of handling watch dog? Im not opposed to trying it. Especially if it gets hung up trying to do something then maybe the WDT while it's awake may help.
                          www.CrankyCoder.net
                          MySensors: 2.3
                          12.5k
