  3. battery powered sensor / watchdog?
29 Posts 8 Posters 5.9k Views 8 Watching
  • CrankyCoderC CrankyCoder
    did you do anything to try to over come it? or do you think either spending more for better quality or maybe an external watch dog chip?
    alexsh1A
    alexsh1A
    alexsh1
    @crankycoder I think the biggest issue for me is that I’m not ordering in large quantities. AliExpress or ebay are really competitive if you need a few components.
    Digi-key for example wants me to have a minimum spending of £30 for free shipping (AliExpress is offering free shipping).
    • CrankyCoderC
      CrankyCoderC
      CrankyCoder
      agreed. hard to beat aliexpress for pricing.
      Home Automation Tinkerer
      www.CrankyCoder.net
      Gateway: MQTTClientGateway
      MySensors: 2.3
      ileneken3I 1 Reply Last reply
        ileneken3I
        ileneken3I
        ileneken3
        @crankycoder
        Speaking of pricing, a Pro Mini 3.3Mhz can be had for as little as $2-$3. Couldn't that be used to provide all the functionality (and more) of a TPL5010? Of course, it would require a small programming with a small script that uses low power sleep, removing the LED, maybe regulator too.
        • CrankyCoderC
          CrankyCoderC
          CrankyCoder
          that's where the problem is. the whole sensor is a pro mini. it periodically stops doing it's thing.
          www.CrankyCoder.net
          MySensors: 2.3
            ileneken3I
            ileneken3I
            ileneken3
            @crankycoder
            What I meant was that keep the sensor as is (whether it is a pro mini or anything else), and use a different pro mini as the watchdog - in place of the TPL5010. In this case, it would take a double board failure in order to have a complete failure.
            • CrankyCoderC
              CrankyCoderC
              CrankyCoder
              hmmm possible. power consumption would be a concern. having a second node running granted it wouldn't have a radio. I could potentially do the same thing with an attiny85 as it's smaller and lower power. It gets the cost down a little too... about to the same price as as the TPL5010. lol. in a pinch a pro mini would definitely work. Since I have some attiny85s that may be my option right now since i have them and don't have to buy the TPL5010's.
              I think Jon Oxer did something with a hardware external watchdog like that. I am now wondering if i could use the attiny85, have it sleep as well. Wakeup hourly to see if it should reset the sensor. But also wake up on interrupt, where in the sensor if it's running well would pulse to the attiny. The tiny would reset the counter. Then each hour if the tiny wakes up, and the sensor hasn't reported in a couple hours, it would just reset it.
              This is an actual possibility. lol
              www.CrankyCoder.net
              MySensors: 2.3
              • electrikE
                electrikE
                electrik
                IMHO, a watchdog reset is something that shouldn't occur normally. If it does, something is wrong in your code and that should be fixed...
                Or are there maybe packets that get lost?
                • CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  i fully agree. But my sensor bombs out after a week or so of running. It's just a temp sensor used from the examples. Only thing I did was change the sleep timeout. So i am thinking either there is something with the cheap pro mini clones. Or something with the radio not sending. Which could be it, for all I know it's waking up and the arduino is saying everything is good but the radio isn't working. The only thing I know for certain is a reset brings it all back online.
                  Quite possible the packets are lost in the RF transmission. Just difficult to leave a serial monitor hooked up to it outside for a week till it dies lol.
                  :joy:
                  www.CrankyCoder.net
                  MySensors: 2.3
                  • electrikE
                    electrikE
                    electrik
                    wrote on last edited by electrik
                    Yes I understand. It is hard to find the cause in these cases. Do you have the possibility to move the node closer to the gateway or add a repeater to see if the problem persists?
                    Edit: or hookup the serial monitor, but place the node inside somewhere :-)
                    • CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      I have definitely thought of throwing a repeater in the room closest to where it is outside. That could definitely help. Can't move it closer since it's a temp sensor in my pool lol.
                      Wonder if i made a connector out of rj45 if it would work over that length to something inside :)
                      www.CrankyCoder.net
                      MySensors: 2.3
                      • electrikE
                        electrikE
                        electrik
                        so just to make sure I understand. Is the node also in the pool? Or just the sensor?
                        • CrankyCoderC
                          CrankyCoderC
                          CrankyCoder
                          just the sensor. Node is in box outside of the pool.
                          www.CrankyCoder.net
                          MySensors: 2.3
                          • E
                            E
                            executivul
                            Put an esp wifi node in the box with a beefier battery, or another box next to the first one if it isn't large enough. There is an "esp bridge" app that can easily do serial monitoring over wifi. That way you should have console output from the node when ot craps out. I've used it to debug some app that controls some contactors via a 5v relay board, turning contactors off sent the w5500 to Valhalla, the debug output via the esp saved the day since the device is located in a cielling a few meters up.
                            • CrankyCoderC
                              CrankyCoderC
                              CrankyCoder
                              This is a cool idea. Definitely worth throwing some bigger batteries at it for debugging. I am looking for this bridge stuff now :)
                              www.CrankyCoder.net
                              MySensors: 2.3
                              E 1 Reply Last reply
                                E
                                E
                                executivul
                                @crankycoder https://github.com/jeelabs/esp-link
                                  I eneble wdt on pretty much all my nodes. Just remember to disable it before entering sleep. How did you setup the node? Do you have any booster running?
                                  • CrankyCoderC
                                    CrankyCoderC
                                    CrankyCoder
                                    Where do you put your enable/disable watchdog? My node sleeps for 90 minutes at a time. Do you mean like a voltage booster? no, but i am monitoring the battery voltage so i know when it gets close to the 3.3 that the radio needs.
                                    www.CrankyCoder.net
                                    MySensors: 2.3
                                      I enable it at beginning of loop and disable it before the sleep. What battery do you use? Btw the nrf24 radio can go down to 1.8V
                                      • CrankyCoderC
                                        CrankyCoderC
                                        CrankyCoder
                                        Im using an 18650. currently it's sitting around 3.9v.
                                        Do you have a link to the proper "mysensors" way of handling watch dog? Im not opposed to trying it. Especially if it gets hung up trying to do something then maybe the WDT while it's awake may help.
                                        www.CrankyCoder.net
                                        MySensors: 2.3
                                        12.5k
