  3. Using loop function with MySensors-master/examples/ (2.2)
12 Posts 2 Posters 2.9k Views 2 Watching
  • E Offline
    E Offline
    eric007
    I'm using Mysensors for the very first time (2.2 version)
    I'm confused, everything is working excepted the loop function.
    Precisely,
    I'm editing RelayActuator and placed my code in loop function (it was already declared but empty) but my code is ignored.
    Both functions, loop() and setup() usually used in a sketch are ignored.
    (I do think that they are ignored because each serial feedback, like Serial.println(...) don't do anything)
    What can I do if i want to use them ?
    Eric.
    • E eric007
      Precisely,
      Eric.
      Hi @eric007, welcome to the forum!
      loop and setup are supposed to work just like on non-MySensors sketches.
      Is MY_DEBUG defined? If not, are you calling Serial.begin() in setup? What Arduino model are you using? Do you get any other output on the serial monitor?
      Could you post your entire sketch?
      • E Offline
        E Offline
        eric007
        Thanks for your answer,
        here the thing:
        i've 4 relays connected to an Adruino nano(328)
        MysensorSerialGatreway is doing the right job and all is working.
        But, i want to add a timeout option that switch off a relay after timeout reached.
        I want this option in case of a freeze or bug with my domoticz controller (running on a raspberry pi)
        Relay are used for watering my garden, so i prefer having a solution on my arduino for switching off relays in case of any bug.
        So, my idea is pretty simple:
        each time a relay is switched on i store the time
        (i'm doing this in receive() function)
         In the loop function i do some tests and check the timeout for each relay
        I wanted to know if it was working (i do think my code is correct) so i put some Serial output.
        as you can see in setup() or in loop(), there are two outputs.
        I do have the Mysensors classic outputs but mine do not produce anything.
        so have you an idea ?
        thanks a lot.
        here my code:
        • The MySensors Arduino library handles the wireless radio link and protocol
        • between your home built sensors/actuators and HA controller of choice.
        • The sensors forms a self healing radio network with optional repeaters. Each
        • repeater and gateway builds a routing tables in EEPROM which keeps track of the
        • network topology allowing messages to be routed to nodes.
        • Created by Henrik Ekblad henrik.ekblad@mysensors.org
        • Copyright (C) 2013-2015 Sensnology AB
        • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
        • Documentation: http://www.mysensors.org
        • Support Forum: http://forum.mysensors.org
        • This program is free software; you can redistribute it and/or
        • modify it under the terms of the GNU General Public License
        • version 2 as published by the Free Software Foundation.
        • REVISION HISTORY
        • Version 1.0 - Henrik Ekblad
        • DESCRIPTION
        • Example sketch showing how to control physical relays.
        • This example will remember relay state after power failure.
        • http://www.mysensors.org/build/relay
        //#define MY_RADIO_NRF5_ESB
        //#define MY_RADIO_RFM95
        #define MY_REPEATER_FEATURE
        #define RELAY_PIN 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define RELAY_ON 1 // GPIO value to write to turn on attached relay
        unsigned long t1[4]; // Calcul de la durée depuis l'activation d'un relay
        #define DUREEMAX 3600000 // duréee maximale après laquelle les relais sont automatiquement éteints
        void before()
        for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
        Serial.println("setup ok");
        sendSketchInfo("Relay", "1.0");
        	present(sensor, S_BINARY);
        void loop() //my watchdog
        unsigned long t=millis();
        unsigned long t2[4];
        if (t>=t1[0]) {t2[0]=t-t1[0];} // if t<t1 then millis() function have reached the max value on a arduino (after 50 working day ), and get back to 0
        {t2[0]=4294967295-t1[0]+t; }
        if (t>=t1[1]) {t2[1]=t-t1[1];}
        {t2[1]=4294967295-t1[1]+t; }
        if (t>=t1[2]) {t2[2]=t-t1[2];}
        {t2[2]=4294967295-t1[2]+t; }
        if (t>=t1[3]) {t2[3]=t-t1[3];}
        {t2[3]=4294967295-t1[3]+t; }
        if (t2[0]>DUREEMAX) { digitalWrite(RELAY_PIN,RELAY_OFF);} // switch off relay, timeout reached
        if (t2[1]>DUREEMAX) { digitalWrite(RELAY_PIN+1,RELAY_OFF);} // switch off relay, timeout reached
        if (t2[2]>DUREEMAX) { digitalWrite(RELAY_PIN+2,RELAY_OFF);} // switch off relay, timeout reached
        if (t2[3]>DUREEMAX) { digitalWrite(RELAY_PIN+3,RELAY_OFF);} // switch off relay, timeout reached
        Serial.println("loop test");
        if (message.type==V_STATUS) {
        // Change relay state
        digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        // Store state in eeprom
        if (message.sensor-1<4 && message.sensor-1>=0)
        {t1[message.sensor-1] = millis();}
        • E eric007
          here the thing:
          thanks a lot.
          here my code:
          • REVISION HISTORY
          • DESCRIPTION
          void before()
          @eric007 coyld you post the debug output of the node? It might give a clue. I can’t see snything wrong with the sketch, you should definitely get the ”setup ok” print.
          • E Offline
            E Offline
            eric007
            here a snapshot of the Serial output (is that you wanted ?)
            One more thing
            usually, when I compile sketch without loop() or setup() function, an error is done.
            But here, i can remove loop() and setup() function and compile without any errors
            can both functions (loop and setup) be located elsewhere ? in a .h ou .cpp dependencies that used with #include Mysensors.h
            One last thing,
            I use last version of IDE Arduino , under debian computer.
            When i compile other sketch (my very firsts examples, without Mysensors) loop() and setup() have the right behavior
            thank for help,
            Eric.
            • E Offline
              E Offline
              eric007
              One more thing: even if compilation succeed, there are always two warnings:
              Warnings are (my traduction):
              WARNING : wrong .ci folder in library "Mysensors"
              WARNINR : wrong .mystools floder in library "Mysensors"
              For any sketch (using or not Mysensors) i do have this Warning, since i've installed mysensors library.
              It might be the the problem ?
              thank,
              Eric.
              • E eric007
                One more thing
                One last thing,
                thank for help,
                Eric.
                @eric007 the debug output shows that the node is unable to find a path to the gateway. The default setting is to not enter setup or loop until communication has been established (since, for most use cases, running a node without communication isn't very useful)
                What type of gateway are you using? Could you post the debug output from it?
                • E eric007
                  thank,
                  Eric.
                  @eric007 you can safely ignore the "Faux" folder warning. The english translation is "spurious" in case you want to search here in the forum.
                  • E Offline
                    E Offline
                    eric007
                    Ok! I did not know.
                    I was doing a try on my node and turned off my gateway.
                    tomorrow i will do it again and with the gateway!
                    i'll will send you a feedback.
                    Thank you so much for your answers and your availability,
                    Eric,
                    • E Offline
                      E Offline
                      eric007
                      I'im using GarewaySerial and domoticz as controller.
                      Eric.
                      • E Offline
                        E Offline
                        eric007
                        it works perfectly, you were so right from the beginning.
                        I took a wrong way because of the compilation success without loop() and setup() function in my sketch.
                        Anyway, my project works fine and thank you again.
                        • E eric007
                          Great work @eric007, thanks for reporting back!
