  3. ๐Ÿ’ฌ STM32 Sensor Node
mysensors stm32f103c8t6 stm32
21 Posts 7 Posters 6.9k Views 5 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/590/STM32-Sensor-Node
      Nice. You may consider adding a small connector for external antenna
      • F Offline
        F Offline
        freynder
        Thank you. Good idea about the antenna. I updated everything to V3 which contains a much better layout, clear markings and an u.FL connector. I was quick to order V2 prototype boards yesterday, I guess I will need to order another batch for V3 now ;)
          do you think you could fit the RFM69W modules?
          • F Offline
            F Offline
            freynder
            Probably, there should be enough space. It would probably require a bit of work as well to move vias around.
            I ordered my 3rd batch of prototype boards yesterday and will hold making changes now until I can test.
            Adding RFM69W (or RFM69HCW for that matter) support is not really a priority for me to be honest since the CW modules should have the same performance and HW is out of the question due to legislation in my country (25 mW e.r.p. for 868Mhz). So my question: would that be something you really need?
              I'm talking about normal rfm69w, the rfm69hw are the high power ones but the footprint is the same
              • F Offline
                F Offline
                freynder
                Yes I know, I didn't say otherwise.
                • L Offline
                  L Offline
                  lafleur
                  It would be nice if you could post a .pdf of the schematic.... not everyone has the tool to see the board from the .sch file.
                  • F Offline
                    F Offline
                    freynder
                    @lafleur: sure, I added the pdf.
                    • F Offline
                      F Offline
                      freynder
                      @gohan: I added the RFM69(H)W footprint as an exercise. You can find it here https://github.com/freynder/STM32_Sensor. I will not update the design files here as I'm waiting for the prototype boards for V3.4 to test and update the results here so it remains consistent. Not sure how evolutions are supposed to be handled on openhardware.io... create a new entry?
                        Ok, keep us posted. Also make sure about trace length for the antenna as I remember there should be some specs about it.
                        • F Offline
                          F Offline
                          freynder
                          @gohan: what do you mean exactly? I kept antenna connections very close together. They also lay in a ground plane: http://i.imgur.com/KzE7CXc.png .
                            the "10 ANT" pad is not very close to the ANT hole, are you sure it is not affecting the antenna length?
                            • F Offline
                              F Offline
                              freynder
                              @gohan: I'm not sure. The antenna trace is surrounded by the ground plane up to the ANT hole so I assumed antenna length would need to be measured from there but that might not be correct. I'm not 100% sure though and don't know how much of an impact it might have. I will test both lengths once the boards arrive. Any insight would be appreciated.
                              • F Offline
                                F Offline
                                freynder
                                Assembled and performed a few simple tests: upload using SWD, upload using serial (using buttons to select boot mode), running securitypersonalizer and basic mysensors sketch with RFM69 initialization. Everything seems to be working. More extensive tests will be performed later.
                                  Good, keep us posted. :+1:
                                  • I Offline
                                    I Offline
                                    ian1scott
                                    @freyender - nice project, perfect for my needs. So I got a couple of boards from OSHpark, ordered some parts online then I went to populate one of the boards and realized there's no silkscreen for parts! Do you have an overlay or something that tells me which part goes where? Or am I being thick and missing something that is right under my eyes? Thanks!
                                    • F Offline
                                      F Offline
                                      freynder
                                      @ian1scott: sorry for the late reply. The part references can be found in the Fab layer in the kicad file.
                                      • nagelcN Offline
                                        nagelcN Offline
                                        nagelc
                                        Nice board. Have you run it on battery? How is the power consumption?
                                        • F Offline
                                          F Offline
                                          freynder
                                          Power consumption should be comparable to the blue pill with leds and regulator removed. Never got around measuring it myself but here are some results for the bluepill: https://www.stm32duino.com/viewtopic.php?f=3&t=658&start=40 , stating 13ยตA in STOP mode.
                                          Also note that last time I checked, low power was not supported in MySensors for these MCU's so you would need to add it in yourself.
                                          With your input, this post could be even better ๐Ÿ’—
