  3. Regulators needed
Regulators needed
9 Posts 6 Posters 3.2k Views 8 Watching
  • D Offline
    So I was working on building myself a new serial gateway tonight when I realized that I am out of 3.3v TO-92 package regulators. I have some AMS1117 3.3v regulators, but they are in an SMT package making mounting them to a thru hole regulator near impossible. I figured since I need to buy more, I will go with LDO regulators. Are there any that perform better than others? Are there any things I should be watching out for? Is there a good place to buy them cheap where I can get them in a pack of 20 or so to stock up?
      The most common ldo I saw are le33 and mcp1700
      • N Offline
        N Offline
        It's a good question, and it deserves a good answer. Since a gateway will probably be mains powered, rather than battery powered, I'm guessing that an LDO with less ripple and/or more noise rejection might improve the range/coverage of the gateway. i.e. just slapping in the cheapest, most common chips might be self defeating. That's too vague an answer though, and I'm sorry I can't do better. Has anyone looked into that angle?
        D 1 Reply Last reply
        • N NeverDie
          @neverdie Good points though.
          • D Offline
            Another one that seems promising is the LP2950 series. Just wondering if anyone has had any experience with these?
            N C 2 Replies Last reply
            • D dbemowsk
              N Offline
              N Offline
              @dbemowsk said in Regulators needed:
              LP2950
              Did you try them in the end or did you chose another one ?
              I didn't know about those, they seem very nice if your node needs low current and you have a high input voltage, the max 30V is really nice for nodes like a led dimmer up to 24V.
              • N Nca78
                LP2950
                @nca78 I did go with those and it seems to be working great.
                • H Offline
                  H Offline
                  heinzv
                  wrote on last edited by heinzv
                  LP2950
                  I will use the AP2112K 3v3
                  https://www.diodes.com/assets/Datasheets/AP2112.pdf
                  it has overall very good values, 600mA output current, high effciency. I would not use the AMS1117 for battery usage.
                  It is also used by the excellent Adafruit Feather:
                  https://www.kiwi-electronics.nl/adafruit-feather-m0-wifi-atsamd21-atwinc1500?lang=en
                  Output Voltage Accuracy: ±1.5%
                  Output Current: 600mA (Min.)
                  Foldback Short Current Protection: 50mA
                  Enable Function to Turn ON/OFF VOUT
                  Low Dropout Voltage (3.3V): 250mV (Typ.) IOUT = 600mA
                  Excellent Load Regulation: 0.2%/A (Typ.)
                  Excellent Line Regulation: 0.02%/V (Typ.)
                  Low Quiescent Current: 55μA (Typ.)
                  Low Standby Current: 0.01μA (Typ.)
                  • D dbemowsk
                    C Offline
                    C Offline
                    cabat
                    @dbemowsk
                    I used LP2950-5.0 in one node when feeding from 12v - about 3 months everything works quite stably.
