  3. BME280 How to use it outdoors
36 Posts 9 Posters 35.8k Views 10 Watching
  • R r-nox
    That's my line of thought.
    K Offline
    K Offline
    karl261
    @r-nox Hm, it is reading every 15 seconds at the moment. Do you think this is too much?
    The current sensor is not completely broken, it seems. Sometimes it is showing "normal" values. I brought it into the house to test it, and in the house it seems to show normal values. I will know more tomorrow morning.
    According to its specs it is supposed to be good for weather monitoring. But then, it seems it does not like "weather" too much.
    I also found it strange that in the past 30 days the maximum humidity it read was 87 %. And for sure there were plenty of nights here with 100 %. But ok, I could live with that. But it has started to show far too low values for humidity, down to 0 %. I'll leave it in the house for 1-2 days and then see how it behaves outside.
    • R Offline
      R Offline
      r-nox
      I don't know the specs for reading it off hand. Perhaps your housing is holding humidity. I plan to add a fan to mine. Spin the fan for a few moments before reading to cycle the air.
      • K Offline
        K Offline
        karl261
        So, this story also continues. After having these problems, I brought the sensor into the house and left it running for the past several weeks in the living room. Actually it is working fine. No more problems.
        Now, for Christmas, I have brought it back outside to the birdhouse. And it is still working fine, even at -10 °C. Let's see how long it will last this time.
        What I also noticed is that now I have a second of these in the greenhouse where the humidity is definitely from time to time 100%. At 4°C. But both outdoor sensors somehow never reach 100%, but stop somewhere between 85-90%. It seems they are not made to detect 100% humidity.
        • K Offline
          K Offline
          karl261
          Now after 2-3 month more outside the sensor seems to be finally dead. No reaction anymore. Also the 2nd one in the greenhouse does not reply anymore. I'll have to check. The one in the living room is fine.
          It seems that at least the ones I bought are not really lasting long outdoors.
          parachutesjP 1 Reply Last reply
          • R Offline
            R Offline
            r-nox
            Time to try something else.
            • ferroF Offline
              ferroF Offline
              ferro
              What about to use PTFE (teflon) tape to protect the sensor board, see this project. It seems, characteristics of the material (PTFE) enables it to use it for this purpose, it is mentioned also link text here
              • K Offline
                K Offline
                karl261
                wrote on last edited by karl261
                #29
                Interesting idea, the ptfe tape. I will try it with the next sensor!
                So, only the outdoor sensors fail. It is now more than one that failed.
                I have one in the living room -- perfect.
                And, very strange: I have one in the green house. Huge T differences, sometimes very hot, and often 100% humidity. Actually conditions should be worse for this sensor compared to the outdoor sensor. But: it is just fine.
                Weird.
                • D Offline
                  DavidZH
                  @karl261 Do you happen to live near te sea? Because salty air wreaks havoc on anything sooner or later. Tiny electronics rather sooner...
                  I have a BME280 outside and that's been running for over a year now. It's pretty well protected though, but it catches a few hours of direct sunlight per day.
                  • K Offline
                    K Offline
                    karl261
                    #31
                    Hi, no, I live rather far from the sea. I don't know what is killing the outdoor sensor. The same in the greenhouse survives much weirder temperatures and humidities.
                    ร 1 Reply Last reply
                    • K karl261
                      ร Offline
                      ร Offline
                      รอเรือ
                      @karl261 Any update on this topic?
                      Are you still struggling with that your BME280s don't seem to last long time outdoors?
                      • ร รอเรือ
                        ร Offline
                        ร Offline
                        รอเรือ
                        Anyway. My crappy BME280 clone that I bought on ebay for $8.98 (in December 2016) lasted only for 4 days.
                        Now I will have to take down my weather station and repair it.
                        I will now buy an original Adafruit BME280 for 289 SEK (32$) + postage. I hope that one will last.
                        skywatchS 1 Reply Last reply
                        • ร รอเรือ
                          skywatchS Offline
                          skywatchS Offline
                          skywatch
                          @รอเร-อ
                          I got 2x "BME280" from China today - they are not bosch sensors. If you are having problems, check carefully the markings with magnifying glass or microscope.
                          This may be the problem.....??
                          • K karl261
                            parachutesjP Offline
                            parachutesj
                            @karl261 said in BME280 How to use it outdoors:
                            Quite old thread, but wanted to provide an update:
                            I have a BME280 up and running since about 1 year now. It is in the weather station outside on the roof. It is vented very well but protected from direct exposure to sun, wind and rain. Readings are reliable. What I did is treating the whole board except the sensor chip with this:
                            https://de.aliexpress.com/item/2pcs-lot-Genuine-Kafuter-k-705-RTV-Silicone-Rubber-Electronic-Glue-Sealant-Transparent-Organosilicon-45g/32649754904.html?spm=a2g0s.9042311.0.0.27424c4d0W1ssb
                            N 1 Reply Last reply
                            • parachutesjP parachutesj
                              N Offline
                              N Offline
                              @parachutesj thank you for the link I never noticed those before.
