  3. Trying to get a dual mode sleep going.
4 Posts 2 Posters 1.0k Views 2 Watching
  • DbagioniD Offline
    DbagioniD Offline
    Dbagioni
    wrote on last edited by Dbagioni
    Hello Everyone
    Im trying to get a dual sleep code going. My project is a monitor for my detached shed. It will be powered by either a 12 or 9 volt battery and the radio will have to be the higher powered NRF24 LNA/PNA (Its a good 200 yards from the house).
    I've managed to get the node base code working fine....reports the doors open/closed, sends back temp/humidity/battery percent.......but only when the door are opened or closed, which as you can imagine I don't sped a ton of time in the shed so its not that often.
    What I want to do is have the sensor wake under 2 conditions.....1 every hour or two to send temp/humidity and battery data back, and 2 when the doors are opened or closed (the kids have a habit of leaving the door open after getting their bikes).
    I could use a little help.
     * MySensors Custom Door/Window Sensor, with temperature sensor
     * and battery level reporting Version 2.2
     * D.B******* 7/13/2018
     * Version 1 - Initial concept code
     * Version 2 - adds Temp/humidity/ and battery monintoring
     * The Mysensors libraries will handle all the radio protocols
     * and create the network.
     * DO NOT USE REPEATER MODE if this is battery powered
     * digital I/O pin 3 (BUTTON_PIN below) and GND and the other
     //Enble serial monitoring
     //Enable radio (Im using NRLF24A)
     // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_TX_LED_PIN 6  // tramsmit led pin
    #include <MyConfig.h>
    #include <DHT_U.h>
    #define SKETCH_NAME "Shed Monitoring Sensor"
    #define SKETCH_VERSION "2.0"
    #define CHILD_ID_BATTERY 1
    #define CHILD_ID_HUMIDITY 2
    #define CHILD_ID_SENSOR1 3
    #define CHILD_ID_SENSOR2 4
    #define CHILD_ID_TEMPF 5
    #define CHILD_ID_TEMPC 6
    #define SENSOR1_PIN 2 //digital pin to connect sensors to.
    #define SENSOR2_PIN 3
    #define BATTERY_SENSE_PIN  A0  // select the input pin for the battery sense point
    #define DHT_PIN 4 //digital pin for the DHT sensor
    #define DHTTYPE 11
    #define SENSOR_TEMP_OFFSET 0 //allows for small corrections to sensor innacuracies
    unsigned long SLEEP_TIME = 300000; //600000 = 10 min, 300000 = 5 min - Sleep time in MilliSeconds
    static const uint64_t UPDATE_INTERVAL = 2100;
    float lastTempF;  //stores farenheit
    float lastTempC;
    float lastHum;
    uint8_t nNoUpdatesTempF;
    uint8_t nNoUpdatesHum;
    uint8_t nNoUpdatesTempC;
    #if (SENSOR1_PIN < 2 || SENSOR1_PIN > 3)
    #error SENSOR1_PIN must be either 2 or 3 for interrupts to work
    #if (SENSOR2_PIN < 2 || SENSOR2_PIN > 3)
    #error SENSOR2_PIN must be either 2 or 3 for interrupts to work
    #if (SENSOR1_PIN == SENSOR2_PIN)
    #error SENSOR1_PIN and SENSOR2_PIN2 cannot be the same
    #if (CHILD_ID_SENSOR1 == CHILD_ID_SENSOR2)
    #error CHILD_ID_SENSOR1 and CHILD_ID_SENSOR2 cannot be the same
    MyMessage msgBatt(CHILD_ID_BATTERY, V_VAR1);
    MyMessage msgHum(CHILD_ID_HUMIDITY, V_HUM);
    MyMessage msgSensor1(CHILD_ID_SENSOR1, V_TRIPPED);
    MyMessage msgSensor2(CHILD_ID_SENSOR2, V_TRIPPED);
    MyMessage msgTempF(CHILD_ID_TEMPF, V_TEMP);
    MyMessage msgTempC(CHILD_ID_TEMPC, V_TEMP);
    int oldBatteryPcnt = 0; //sets initial battery precentage to 0
    DHT dht(DHT_PIN, DHTTYPE);
      dht.begin();
      batteryReference();
      pinMode(SENSOR1_PIN, INPUT_PULLUP);
      pinMode(SENSOR2_PIN, INPUT_PULLUP);
    void batteryReference(){
        analogReference(INTERNAL1V1);
        analogReference(INTERNAL);
    void presentation(){
      present(CHILD_ID_BATTERY, S_CUSTOM);
      present(CHILD_ID_HUMIDITY, S_HUM);
      present(CHILD_ID_SENSOR1, S_DOOR);
      present(CHILD_ID_SENSOR2, S_DOOR);
      present(CHILD_ID_TEMPF, S_TEMP);
      present(CHILD_ID_TEMPC, S_TEMP);
     uint8_t value;
      static uint8_t sentValue=2;
      static uint8_t sentValue2=2;
      sleep(5);
      value = digitalRead(SENSOR1_PIN);
      if (value != sentValue) {
        send(msgSensor1.set(value==HIGH));
        sentValue = value;
      value = digitalRead(SENSOR2_PIN);
      if (value != sentValue2) {
        send(msgSensor2.set(value==HIGH));
        sentValue2 = value;
       float temperaturef = dht.readTemperature(true);
       float temperaturec = dht.readTemperature(false);
       float humidity = dht.readHumidity();
      if (isnan(temperaturef)) {
      } else if (temperaturef != lastTempF || nNoUpdatesTempF == FORCE_UPDATE_N_READS) {
        lastTempF = temperaturef;
        nNoUpdatesTempF = 0;
        temperaturef += SENSOR_TEMP_OFFSET;
        send(msgTempF.set(temperaturef, 1));
        #ifdef MY_DEBUG
        Serial.print("Temp F: ");
        Serial.println(temperaturef);
        nNoUpdatesTempF++;
       if (isnan(temperaturec)) {
      } else if (temperaturec != lastTempC || nNoUpdatesTempC == FORCE_UPDATE_N_READS) {
        lastTempC = temperaturec;
        nNoUpdatesTempC = 0;
        temperaturec += SENSOR_TEMP_OFFSET;
        send(msgTempC.set(temperaturec, 1));
        #ifdef MY_DEBUG
        Serial.print("Temp C: ");
        Serial.println(temperaturec);
        nNoUpdatesTempC++;
      if (isnan(humidity)) {
        lastHum = humidity;
        // Reset no updates counter
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("Humidity: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      Serial.println(sensorValue);
      // vout = (sensorvalue x 3.3) / 1023
      //vin = vout /  (R2/(R1+R2));
      float batteryV  = ( sensorValue * 0.003225806 ) / 0.3; // divide R2/(R1+R2)
      int batteryPcnt = sensorValue / 10 ;
      if ( batteryPcnt > 100 )
      batteryPcnt = 100;
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
      if (oldBatteryPcnt != batteryPcnt)
        // Power up radio after sleep
        send(msgBatt.set(batteryPcnt));
        oldBatteryPcnt = batteryPcnt;
      sleep(SENSOR1_PIN-2, CHANGE, SENSOR2_PIN-2, CHANGE, 0);
    Ive tried adding the SLEEP_TIME into the sleep line, but when I put in in the door monitor becomes unresponsive.
    • skywatchS Offline
      skywatchS Offline
      skywatch
      Change this line......
      to
      sleep(digitalPinToInterrupt (SENSOR1_PIN), CHANGE, digitalPinToInterrupt (SENSOR2_PIN), CHANGE, SLEEP_TIME);
      Make sure that status of battery/doors is saved and only sent if it changes, add the battery level send (or a heartbeat) in the main loop and you should be there.
      Depending on the controller you are using you could also look into using smartsleep as well, but for now this is perhaps more flexible for your needs.....
      DbagioniD 1 Reply Last reply
      • skywatchS skywatch
        to
        DbagioniD Offline
        DbagioniD Offline
        Dbagioni
        @skywatch
        Perfect - works like a charm.
        Thank you
        Dave
        • skywatchS Offline
          skywatchS Offline
          skywatch
          Happy to have helped! ;)
