  3. RFM69HCW Feather M0 MQTT
23 Posts 3 Posters 4.3k Views 1 Watching
  • Andrew MaynardA
    Andrew MaynardA
    Andrew Maynard
    Im trying to combine the GatewayEsp8266MQTTClient and lafleurs soil moisture sketch. i keep getting this error when compiling
    MyTransportRFM69.cpp: In function 'bool transportInit()':
    MyTransportRFM69.cpp:171:42: error: expected primary-expression before ',' token
    if (_radio.initialize(MY_RFM69_FREQUENCY, _address, MY_RFM69_NETWORKID))
    anyone have some suggestions? am i declaring the frequency wrong?
    • Andrew MaynardA Andrew Maynard
      @andrew-maynard welcome to the MySensors community!
      You may have declared the frequency wrong, but it is hard to tell without knowing how you declared it. Could you share how you declare the frequency?
      If you haven't already, take a look at the documentation: https://www.mysensors.org/apidocs/group__RFM69SettingGrpPub.html#ga3abb7e6bc4ad07943afe0ce3e381c9ec
      • Andrew MaynardA
        Andrew MaynardA
        Andrew Maynard
        ive been reading your responses everywhere. lol i had hoped you would respond.
            #define MY_DEBUG                                  // used by MySensor (Print debug messages via serial)
            #define MY_RADIO_RFM69                            // Select Radio-Module RFM69
            #define MY_RFM69_FREQUENCY
            #define RF69_433MHZ            // Define our Frequency of 433 MHz
            #define MY_IS_RFM69HW                             // Module is high power (HW/HCW)
            //#define MY_RFM69_NETWORKID 100                  // leave out for gateway selection
            #define MY_RF69_SPI_CS 8                          // SPI CS PIN
            #define MY_RF69_IRQ_PIN 3                         // IRQ PIN
            #define MY_RF69_IRQ_NUM 3                         // IRQ PIN NUM (for M0 it is the same as IRQ PIN. Will be obsolete in
            //#define MY_NODE_ID 162                            // Node ID
            #define MY_DEFAULT_TX_LED_PIN 13                  // LED Pin for "Blink while sending"```
          @andrew-maynard this is how the frequency is defined:
          #define MY_RFM69_FREQUENCY   (RFM69_433MHZ)
          Remove these two lines:
          In addition to the documentation I linked before, you can also see the section "Configuring MySensors for RFM69" at https://www.mysensors.org/build/connect_radio#rfm6995-&-arduino
          Andrew MaynardA 2 Replies Last reply
            Andrew MaynardA
            Andrew MaynardA
            Andrew Maynard
            • Andrew MaynardA
              Andrew MaynardA
              Andrew Maynard
                Andrew MaynardA
                Andrew MaynardA
                Andrew Maynard
                wrote on last edited by Andrew Maynard
                  [[topic:post-is-deleted]]
                  @andrew-maynard what board and board version are you using? Check the beginning of the output when compiling, it should look like this:
                  Using board 'd1_mini' from platform in folder: C:\Users\Micke\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1
                  Using core 'esp8266' from platform in folder: C:\Users\Micke\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1
                  The ESP8266MQTTClient example compiles fine for me, using MySensors 2.3.0.
                  Andrew MaynardA 1 Reply Last reply
                    Andrew MaynardA
                    Andrew MaynardA
                    Andrew Maynard
                    @mfalkvidd Im sorry I was being dummy and overthinking it. I'm using a feather M0 with rfm69hcw. I was under the impression even the client would need some MQTT info. I managed to get the sketch compiling and getting some output from serial monitor but its not consistent at all. I can see through domoticz log that its connected to mysensor. The sketch is a basic Temperatureandhumidity nothing changed except radio type. Thank you for the documentation! helped to clear things up.
                    #define MY_SERIALDEVICE Serial  // this will override Serial port define in MyHwSAMD.h file
                    #define MY_RFM69_NEW_DRIVER
                    #define MY_RF69_IRQ_NUM 3                         // IRQ PIN NUM (for M0 it is the same as IRQ PIN. Will be obsolete in upcoming MySensors.h)
                    91177 TSM:FAIL:CNT=6
                    91187 TSM:FAIL:DIS
                    91197 TSF:TDI:TSL
                    101208 TSM:FAIL:RE-INIT
                    101219 TSM:INIT
                    101309 TSM:INIT:TSP OK
                    101320 TSM:FPAR
                    101335 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    103348 !TSM:FPAR:NO REPLY
                    103358 TSM:FPAR
                    103372 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    105384 !TSM:FPAR:NO REPLY
                    105394 TSM:FPAR
                    105408 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    107420 !TSM:FPAR:NO REPLY
                    107430 TSM:FPAR
                    107445 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    109457 !TSM:FPAR:FAIL
                    109468 TSM:FAIL:CNT=7
                    109479 TSM:FAIL:DIS
                    109490 TSF:TDI:TSL
                      91187 TSM:FAIL:DIS
                      91197 TSF:TDI:TSL
                      101219 TSM:INIT
                      101320 TSM:FPAR
                      103358 TSM:FPAR
                      105394 TSM:FPAR
                      107430 TSM:FPAR
                      109479 TSM:FAIL:DIS
                      109490 TSF:TDI:TSL
                      @andrew-maynard you can use the log parser to get more information about what the log says. In your case, the sensor node is not getting a reply from your gateway. Could you post the gateway log as well?
                      • Andrew MaynardA
                        Andrew MaynardA
                        Andrew Maynard
                        I'm thinking of switching to esp8266 gateway. maybe get that working then try again with raspberry pi? I'm not ready to give up. I dont see as much documentation though.
                          @andrew-maynard what type of documentation are you looking for?
                          • Debugging FAQ, shows the most common problems and how to troubleshoot them
                          • The Getting started guide describes how MySensors is designed to work
                          • We have build pages that describe how to build a lot of different sensors and gateways
                          • The Download/API page has links to documentation for the serial API, the Sensor API and the technical documentation.
                          • The forum (search) has over 90,000 posts covering experience from thousands of MySensors users.
                          • Andrew MaynardA
                            Andrew MaynardA
                            Andrew Maynard
                            oh I didnt mean it as not enough documentation in total. you guys put some serious hard work in this project and I really do appreciate it. I would think you guys are paid! I just meant in terms of raspberry pi as a gateway with rfm69hcw. Am I wrong? btw this is one of the liveliest communities I've experienced! once again thank you and I do appreciate it!
                            • Andrew MaynardA
                              Andrew MaynardA
                              Andrew Maynard
                              I'm on the beginner side so it seems a little easier to change a few things in the esp8266gateway sketch and go.
                                @andrew-maynard I'd say that if you have Linux experience, the Raspberry Pi gateway is probably easier to configure and troubleshoot (since it will be a familiar environment). But if you're not already familiar with Linux, learning Linix+MySensors at the same time will be harder than using the esp8266 gateway.
                                • Andrew MaynardA
                                  Andrew MaynardA
                                  Andrew Maynard
                                  This is the debug from the gateway.
                                  If for some reason the transceiver isn't working it should say in debug, correct?
                                  Aug 02 01:17:32 INFO  Starting gateway...
                                  Aug 02 01:17:32 INFO  Protocol version - 2.3.1-alpha
                                  Aug 02 01:17:32 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.1-alpha
                                  Aug 02 01:17:32 DEBUG TSF:LRT:OK
                                  Aug 02 01:17:32 DEBUG TSM:INIT
                                  Aug 02 01:17:32 DEBUG TSF:WUR:MS=0
                                  Aug 02 01:17:32 DEBUG TSM:INIT:TSP OK
                                  Aug 02 01:17:32 DEBUG TSM:INIT:GW MODE
                                  Aug 02 01:17:32 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                                  Aug 02 01:17:32 DEBUG MCO:REG:NOT NEEDED
                                  Aug 02 01:17:32 DEBUG MCO:BGN:STP
                                  Aug 02 01:17:32 DEBUG MCO:BGN:INIT OK,TSP=1
                                  Aug 02 01:17:32 DEBUG GWT:RMQ:MQTT RECONNECT
                                  Aug 02 01:17:32 DEBUG connected to 192.168.1.110
                                  Aug 02 01:17:32 DEBUG GWT:RMQ:MQTT CONNECTED
                                  Aug 02 01:17:32 DEBUG GWT:TPS:TOPIC=domoticz/out/MyMQTT/0/255/0/0/18,MSG SENT
                                    the debug can tell you if spi is working ok.
                                    when you get FPAR NO REPLY it could be because of bad rfm69 interrupt. but your define looks ok..
                                    could you try to add in your sketch define this one:
                                    #define MY_RFM69_RST_PIN 4
                                    As your rfm69 reset signal is routed to D4..
                                    • mfalkviddM
                                      Could the problems be related to https://github.com/mysensors/MySensors/issues/1155 ?
                                      • scalzS scalz
                                        Andrew MaynardA
                                        Andrew MaynardA
                                        Andrew Maynard
                                        @scalz YES!!! I think that was the problem on the Feather m0 side. still not receiving messages though. i did test it out with
                                        pi@raspberrypi3:~ $ mosquitto_pub -t 'domoticz/in/MyMQTT' -m '0,29'
                                        I see it in the domoticz log.
                                        2018-08-05 02:17:49.130 Status: MySensorsMQTT: connected to: 192.168.1.110:1883
                                        2018-08-05 02:17:49.230 Status: MQTT: Subscribed
                                        2018-08-05 02:17:55.937 Status: MQTT: Worker stopped...
                                        2018-08-05 02:17:56.939 Status: MQTT: Connecting to 192.168.1.110:1883
                                        2018-08-05 02:17:57.040 Status: MQTT: connected to: 192.168.1.110:1883
                                        2018-08-05 02:17:57.040 Status: MySensorsMQTT: connected to: 192.168.1.110:1883
                                        2018-08-05 02:17:57.141 Status: MQTT: Subscribed
                                        2018-08-05 02:45:42.707 MySensorsMQTT: Topic: domoticz/in/MyMQTT, Message: 0,29
                                        I figure it cant hurt to show my ./configure.
                                        pi@raspberrypi3:~ $ ./configure --my-gateway=mqtt --my-controller-ip-address=192.168.1.110 --my-mqtt-publish-topic-prefix=domoticz/out/MyMQTT --my-mqtt-subscribe-topic-prefix=domoticz/in/MyMQTT --my-mqtt-client-id=pi  --my-transport=rfm69 --my-rfm69-frequency=433 --my-is-rfm69hw^C
                                        Am I missing something? Is there a something specific I should enter below for my client id?
                                        Thanks again for responding. I appreciate it!
                                          Andrew MaynardA
                                          Andrew MaynardA
                                          Andrew Maynard
                                          @mfalkvidd I will try it on an esp8266 tomorrow and see if anything changes. When going back versions is there anything else i need to do besides deleting directory and going through ./configure again? I will try the 2.2 version first. I already went from 2.3.1 to 2.3.0.
