  3. MySensors 2.3.0 on Mega 2560 Ethernet Gateway
4 Posts 2 Posters 1.5k Views 1 Watching
  • DbagioniD
    DbagioniD
    Dbagioni
    All
    A little while ago I had upgraded to MySensors 2.3.0 with horrible results....my 18 node network went kablooey. I couldn't get anything stable to save my own life. I was getting 30-90 minutes of runtime on the gateway before it was shutting down and going off line. I of course did this at the exact same time I was rebuilding my gateway, transitioning to the Mega 2560 from thr UNO 328 due to memory and lag issues. To top it all off I am running an NRF24 LNA/PNA radio at MAX because of distance and placement issues.
    Initial gateway
    What I have found was needed to stabilize the gateway.....POWER POWER POWER! It became the Achilles heel of my project. I was initially feeding into the radio then sending power to the Mega via its VCC input (this was ok for the UNO). Voltage going over was good, current wasn't and the gateway would shutdown no matter what the radio power settings were of which radio chip I used. So I switched to a 12v 2.5A power supply and wyed it one connection to the radio board (which has its own voltage regulator) and the other to the Mega's DC jack. Second issue I noted was heat - the Mega runs hotter than the UNO did. I had 130 degrees Fahrenheit on the processor chip. I solved that with a heat sink I had from a raspberry pi and adding a small fan fed from the Mega's 5v pin placed at the back of the Mega. Since that, chip is a cool 80 degrees. I suspect since Im using the Ethernet shield that played a big role in the Mega heating up and the fan really helped.
    Gateway Attempt 3
    The Fan is seen to the immediate left of the LAN jack.
    The toggle switch serves 2 functions...when pushed to the right it resets the gateway, to the left enables inclusion mode. The three LEDs are TX/RX/ERR.
    Hope this helps folks. I will add my wiring and code when I get a chance.
    Heres the gateway mounted in my Ubuntu box, which runs my home media server and OpenHab.
    Happy Building and THANK YOU to everyone who has posted ideas and code snipets that made this possible.
      @Dbagioni
      wow, that sounds weird, to need a heatsink on a Mega gw.. which ic is heating?? sounds like a fishy hw or connection. (even with my 3dprinter, Mega board doesn't heat..).
      DbagioniD 1 Reply Last reply
      • scalzS scalz
        @Dbagioni
        DbagioniD
        DbagioniD
        Dbagioni
        @scalz It was the big chip on the board heating up. I had thought that too so I swapped the mega out last night(had to wait until Amazon delivered it). It got warm (100ish Degrees) but not as hot as the other one did. But I tried to power the gateway as I had originally and the problems started right up again. So Im going with the issue was power related. Im going to keep the fan because a little extra cooling isn't going to hurt anything.
        • DbagioniD
          DbagioniD
          Dbagioni
          As promised this is my wiring and code, hope this help people out
          First the wiring.
          Radio - Mega Pin
          +3V - NA
          -3V - NA
          CSN/CS(Yellow) - 6
          CE(Orange) - 5
          SCK(Green) - 14
          MISO(White) - 15
          MOSI(Blue) - 16
          IRQ(Gray) - 2
          Switch - Mega
          Left - RESET
          Right - 3 (inclusion Button)
          LEDs - Mega
          Red(Err) - 40
          Orange(Rx) - 42
          Green(Tx) - 44
          All are grounded with 330 Ohm resistors.
          And here is my Sketch. One thing I had done when I was just getting lots of shutdowns and errors was to wipe the board - I uploaded blink and left it alone for a minute and then reloaded the gateway with the updated libraries and (knocking on wood) it seems to be stable.
           * Version 1.0 - Henrik EKblad
           * LED purposes:
          #define MY_RADIO_RF24
          #define MY_GATEWAY_W5100
          //#define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
          #define MY_SOFTSPI
          #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
          #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
          // Enable UDP communication
          //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
          #define MY_IP_ADDRESS 192,168,1,XXX
          #define MY_IP_GATEWAY_ADDRESS 192,168,1,XXX
          #define MY_IP_SUBNET_ADDRESS 255,255,255,XXX
          #define MY_PORT 5003//
          // Enable inclusion mode
          #define MY_INCLUSION_MODE_DURATION 90
          // Set blinking period
          // Flash leds on rx/tx/err
          #define MY_DEFAULT_ERR_LED_PIN 40  // Error led pin
          #define MY_DEFAULT_RX_LED_PIN  42  // Receive led pin
          #define MY_DEFAULT_TX_LED_PIN  44  // Transmit led pin
          #if defined(MY_USE_UDP)
          #include <EthernetUdp.h>
          #define MY_SIGNING_SOFT
          #define MY_SIGNING_SOFT_RANDOMSEED_PIN 23
          #define MY_SIGNING_WEAK_SECURITY
          #include <Ethernet.h>
          #include <MyConfig.h>
