  3. Domoticz
  4. Sending data to Domoticz issue
5 Posts 3 Posters 1.6k Views 3 Watching
  • E Offline
    E Offline
    Edi
    Hello guys,
    So the last couple of days I've been struggling to get my Arduino working with Domoticz. My setup:
    • Arduino Uno
    • Moist sensor (using analog)
    • Serial gateway to a raspberry pi with Domoticz
    When I'm monitoring my arduino using the serial monitor, I can see data every 2000ms. I assume that this works, although just in case, here are some of the lines:
    Mositure : 75%
    0;0;1;0;37;75
    0;255;3;0;9;53238 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
    0;255;3;0;9;53340 MCO:SLP:WUP=-1
    Mositure : 75%
    0;0;1;0;37;75
    0;255;3;0;9;53376 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
    0;255;3;0;9;53477 MCO:SLP:WUP=-1
    Mositure : 75%
    0;0;1;0;37;75
    0;255;3;0;9;53513 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
    0;255;3;0;9;53614 MCO:SLP:WUP=-1
    Ok so let's move to the problem:
    I've added the device on Domoticz, seems to work (I've gotten data and I can present it).
    The problem is that I only get data once (just after plugging the USB from Arduino into the pi).
    So in other words, data is being read in Domoticz, although only at initiatialisation(although that's my conclusion I can be wrong in this).
    I've tried several things (hence the comments in the code).
    The Arduino code:
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 115200
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <MyConfig.h>
    //#include <MySensors.h>
    // Setting up format for reading 3 soil sensors
    //#define NUM_READS (int)10    // Number of sensor reads for filtering
    #define CHILD_ID 0
    MyMessage msg(CHILD_ID, V_LEVEL);
    //uint32_t SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
    //long buffer[NUM_READS];
    //int idx;
    //values valueOf[NUM_READS];        // Calculated moisture percentages and resistances to be sorted and filtered
    //int i;                            // Simple index variable
    int sensor_pin = A0;
    int output_value ;
      Serial.begin(9600);
      Serial.println("Reading From the Sensor ...");
      present(CHILD_ID, S_MOISTURE);
      output_value= analogRead(sensor_pin);
      output_value = map(output_value,1023,0,0,100);
      Serial.print("Mositure : ");
      Serial.print(output_value);
      Serial.println("%");
      send(msg.set(output_value));
      sleep(2000);
      //delay(2000);
    Usually I never have problems with these things, and I really hope I did something stupid. I see a lot of potential for MySensors and I hope someone can help me out.
    Thank you in advance!
    Greetings,
    Edi
    • E Edi
      Hello guys,
      • Arduino Uno
      Mositure : 75%
      0;0;1;0;37;75
      Mositure : 75%
      0;0;1;0;37;75
      Mositure : 75%
      0;0;1;0;37;75
      The Arduino code:
      #define CHILD_ID 0
      //int idx;
      int output_value ;
        Serial.begin(9600);
        sleep(2000);
        //delay(2000);
      Greetings,
      Edi
      Hi @edi, welcome to the forum!
      What does the Domoticz log say?
      • E Offline
        E Offline
        Edi
        Hi @mfalkvidd, Thank you =)
        Ah yeah the Domoticz log, the ''last seen status'' dates to 17:07:10.
        Here it is:
        2018-08-11 17:07:10.275 MySensors: Gateway Ready...
        2018-08-11 17:46:15.498 Status: Incoming connection from:
        2018-08-11 18:14:29.385 Status: Incoming connection from:
        I've unplugged it after 18:14
        Replugged it just now:
        2018-08-12 12:25:06.952 Status: MySensors: Using serial port: /dev/ttyACM0
        2018-08-12 12:25:08.529 MySensors: Gateway Ready...
        • E Offline
          E Offline
          Edi
          Bump bump
            Comment the my_debug and try again
            11.9k
            113.3k
