  2. Announcements
  3. 💬 MYSController
💬 MYSController
58 Posts 24 Posters 32.8k Views 23 Watching
  • BartB Bart
    Is it possible to use this app when using RS485 transport? I have one of these usb (ftdi based) adapters connected with 2 Arduino MEGA on a RS485 bus:
    http://www.banggood.com/USB-To-RS485-TTL-Serial-Converter-Adapter-FTDI-Interface-FT232RL-75176-p-961537.html
    Tried it but I don't see any messages. Connecting serial monitor does show a traffic.
    AWIA
    AWIA
    AWI
    @Bart You should not connect MYSContoller to the RS485 bus but to the serial (or LAN) gateway connection. In other words, MYScontroller works as a controller not a bus monitor.
    • maghacM
      maghacM
      maghac
      Any news regarding OTA for MQTT gatways?
      I have a MQTT GW running on a NodeMCU and I can upload new versions of the GW sketch to it using ArduinoOTA. It would be great to be able to also update the sensors connected to it without having to connect it to my computer.
      • D
        dakipro
        Just wanted to support the support for MQTT, that would really be awesome (especially since MyController can do ota over mqtt :) )
        • J
          J
          juanmrodrigues
          Hi all,
          Thanks again for the great work.
          Simple question: Is still MQTT support in the roadmap? Will it be possible to do FOTA over an MQTT Gateway?
          Regards! Merry Xmas and Happy New Year!
          • RajendraR
            RajendraR
            Rajendra
            Myscontroller latest version 1.0.0.3316 shows trojan at virustotal
            is this ok?
            https://www.virustotal.com/#/file/6082b86e6a56783e692afaa7c6d79e5af0d6ca58476ef7e180a39594ce441cd7/detection
            Whats the reason for it
            Rajendra
            tekkaT 1 Reply Last reply
            • RajendraR Rajendra
              is this ok?
              tekkaT
              tekkaT
              tekka
              @iocare-research-team False alarm (4 out of 67), most likely due to the executable being packed with UPX.
              RajendraR 1 Reply Last reply
              • tekkaT tekka
                RajendraR
                RajendraR
                Rajendra
                @tekka ok.. hope so!
                Rajendra
                • RajendraR
                  RajendraR
                  Rajendra
                  Is there any chance of making this tool Open source. Its great tool.
                  Making it open could lead to its porting to various platforms like android and ios
                  and other desktop OS and also make it more stable.
                  just a suggestion.!
                  Rajendra
                  • L
                    L
                    ludoarchi
                    Nice app ! Is there any How To for the begeners i m not able to connect my network. Thinks
                      Sasquatch
                      latest version I can find is 1.0.0 beta... but i've seen screenshots of 1.2.2. where can i get it from?
                      • G
                        G
                        Guillermo Schimmel
                        Absolutely great work! Just discovering the extent of the work done with mysensors. Amazing. Thanks
                          martim
                          No MQTT Support?
                          • J
                            J
                            jimmy loyens
                            Hello, is it possible to do FOTA updates from a desktop while the main gateway is connected to an openhab server on RPI3? Or do i have to replug my gateway between RPI3 en desktop every time i want to do an update?
                            G 1 Reply Last reply
                            • J jimmy loyens
                              G
                              G
                              Guillermo Schimmel
                              @jimmy-loyens What I do in order to have multiple controllers is to make a ethernet-mqtt gateway on an Arduino Uno.
                              That way I can use OpenHAB, try other controllers and also use mycontroller.org to do node management and FOTA.
                              I think that there is no other way.
                              J 1 Reply Last reply
                              • G Guillermo Schimmel
                                J
                                J
                                jimmy loyens
                                @guillermo-schimmel hi, thanks for your response. "Set up a ethernet mqqt gateway" could you elaborate on this? I'm quite competent with arduino, but i'm still learning about mqtt as i go. I have managed to setup mosquitto on my openhab server thoug. Do you mean let openhab send mqtt messages to the ethernet mysensors gateway and thus making it possible to connect MYSController to the ip of the mysensors ethernet gateway? Do you know of some example code? I know there is an example of an ethernet gateway but can it allso handle mqtt by default? Thanks
                                • J jimmy loyens
                                  J
                                  J
                                  jimmy loyens
                                  @jimmy-loyens ok, i did some reading and i think i just need to build the mqtt gateway (is this correct?). Do you hava an example of how to interface a mqtt gateway to openhab? I suppose this would be quite different to a serial gateway. Thanks
                                  • J jimmy loyens
                                    G
                                    G
                                    Guillermo Schimmel
                                    @jimmy-loyens Yes the mqtt gateway is very simple, just use some arduino+nrf4+ethernet.
                                    There is a simple sketch for that.
                                    In order to connect to openhab you should use openhab 2.4 and the mysensors (unofficial) binding. If you are on an older openhab you can just use the mqtt 1.x binding.
                                    I did a post a few weeks ago. I'll try to find it for you.
                                      G
                                      G
                                      Guillermo Schimmel
                                      @guillermo-schimmel Here you have some openhab+mqtt+mysensors examples
                                      https://forum.mysensors.org/topic/4786/openhab/9
                                        J
                                        J
                                        jimmy loyens
                                        @guillermo-schimmel thanks, seems i have an ethernet shiel + spare uno lying around. I will give it a go. Is the mysensors binding compattible with custom nodes i written my own code for? Wich metod is less work to reprogram my openhab? I'm asking because my openhab is quite elaborate. I have a few 100 items and about 80 mylight sensors plugged in to openhab 😁 right now (serial gateway) they all enter openhab via 1 rule with a large hashmap. If i understand correctly i have to create a thing for each sensor and link each item to the channel of this thing. Got a lot of work to do😉😋
                                        J G 2 Replies Last reply
                                        • J jimmy loyens
                                          J
                                          J
                                          jimmy loyens
                                          @jimmy-loyens i use a mosquitto broker to get messages from my esp milight hub in openhab. Can i use this same broker with different topic? I beleive openhab uses mqtt binding for this. Sorry still got a lot to learn about mqtt🤔
