  3. Repeater drops nodes
34 Posts 5 Posters 6.0k Views 7 Watching
  • T
    titvs
    @itbeyond im running 2.3 on gateway, nodes and repeater… Im glad someone showed up with the same issue. The behaviour is similar: everything is ok and, in my case, it starts to "NACK" after around 16 min… Seems to be a software problem then and not the "popular" NRF24 reception issues. What radios are you using? NRF24's?
    tekkaT 1 Reply Last reply
    • T titvs
      tekkaT
      tekkaT
      tekka
      @titvs see here https://forum.mysensors.org/topic/9642/nrf24-transmission-of-data-works-fine-but-constant-nack-s-produced/12
      Please test https://github.com/tekka007/MySensors/tree/RF24Test
      • T
        titvs
        @tekka ok, will test your version tomorrow and collect the node log. Do i need to upload your version to the node, repeater and gateway?
        • T titvs
          tekkaT
          tekkaT
          tekka
          @titvs are you using nrf24L01+ PA+LNA modules?
          • tekkaT tekka
            titvs
            @tekka using normal NRF24's on the nodes and a nrf24L01+ PA+LNA on the gateway.
            tekkaT I 2 Replies Last reply
            • T titvs
              tekkaT
              tekkaT
              tekka
              @titvs ok - I'd recommend to update all devices and re-run the test.
              • T titvs
                I
                I
                itbeyond
                @titvs my testing seems to show that this updated version from @tekka does resolve the problem. I have added some questions about the release details etc in the post https://forum.mysensors.org/topic/9642/nrf24-transmission-of-data-works-fine-but-constant-nack-s-produced/12
                • I itbeyond
                  titvs
                  @itbeyond Nice! Will test it today and post my results.
                  • tekkaT tekka
                    titvs
                    wrote on last edited by titvs
                    #24
                    @tekka well, unfortunately i had the same problem. The far away node connected to the Repeater but after aprox 1h working ok, it stopped being updated at Domoticz with transportCheckUplink() false.
                    You changed a timing setting, right? With the normal version the node stopped being updated at about 15-16 min and now it changed to about 1 hour…
                    I have a node connected directly to the gateway with the nrf24L01+ PA+LNA working without problems, so it seems to be some kind of problem with the Repeater code and timings...
                    • T titvs
                      tekkaT
                      tekkaT
                      tekka
                      @titvs It would be helpful if you could post the debug log showing what you describe + the sketch you are using.
                      • tekkaT tekka
                        titvs
                        @tekka the debug log (MY_DEBUG)/sketch from the node that gets disconnected or the repeater?
                        • T titvs
                          I
                          I
                          itbeyond
                          @titvs I have tested a repeater and it is still working ok after 48 hours using the CE timing modified code.
                          • I itbeyond
                            titvs
                            @itbeyond can you please post the initial code defines for your repeater and a node that connects to it? To see if I’m doing something wrong...
                            In the meantime I’m going to get the debug log and sketch code for my node.
                            • T titvs
                              tekkaT
                              tekkaT
                              tekka
                              @titvs ideally both + sketch
                              • tekkaT tekka
                                titvs
                                #30
                                @tekka Well, im running your beta code and like @itbeyond it seems to be working for 24h now. Uploaded the new compiles with the lib from the RF24Fix branch to all the nodes, gateway and repeater and it seems the drops stopped.
                                Built a couple of Relay nodes, one of which is connected to the repeater and they also seem to be working correctly.
                                Im linking the ZIP to the node log file with the RF24 verbose debug (its a tad big), if you want to take a look:
                                LOG
                                And this is my TEMP+HUM node sketch:
                                // Enable debug prints
                                //#define MY_RS485
                                #define MY_RF24_CHANNEL 1   //////////////
                                // ONLY IF USING FIXED ID REPEATER
                                //#define MY_PARENT_NODE_ID 0            // REPEATER NODE ID
                                //#define MY_PARENT_NODE_IS_STATIC        // this will force your node to use only the repeater
                                #include <U8g2lib.h>  //////////////////////
                                #include <Wire.h>    /////////////////////////
                                U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, A5, A4);   // U8G2 Constructor (A5 - Clock SCL ; A4 - Data SDA)
                                #define DHT_DATA_PIN 3
                                #define SENSOR_TEMP_OFFSET 0
                                static const uint64_t UPDATE_INTERVAL = 60000;
                                #define CHILD_ID_HUM 0
                                #define CHILD_ID_TEMP 1
                                float lastTemp;
                                float lastHum;
                                uint8_t nNoUpdatesTemp;
                                uint8_t nNoUpdatesHum;
                                bool metric = true;
                                DHT dht;
                                void before(){
                                   u8g2.begin();
                                   u8g2.firstPage();
                                   do {
                                     u8g2.setFont(u8g2_font_helvR14_tf);
                                     u8g2.drawStr(38,15,"OLED");
                                     u8g2.drawStr(15,35,"Temp+Hum");
                                     u8g2.drawStr(46,60,"v1.2");
                                   } while ( u8g2.nextPage() );
                                  delay(3000);
                                  u8g2.clear();
                                   u8g2.firstPage();
                                    do {
                                     u8g2.drawStr(3, 32, "Connecting...");
                                  sendSketchInfo("TEMPHUM_OLED", "1.2");
                                  present(CHILD_ID_HUM, S_HUM);
                                  u8g2.clear();
                                    u8g2.firstPage();
                                    do {
                                        u8g2.setFont(u8g2_font_haxrcorp4089_tr); // 7 PIXEL HIGHT
                                        u8g2.drawStr(1,12,"WARNING: UPDATE_INTERVAL");
                                       u8g2.drawStr(1,24,"is smaller than supported by");
                                        u8g2.drawStr(1,36,"the sensor!");
                                    delay(4000);
                                 while (transportCheckUplink() == false){
                                  u8g2.firstPage();
                                  do {
                                    u8g2.setFont(u8g2_font_helvR14_tf); // 14 px height
                                    u8g2.drawStr(3, 32, "Disconnected!");
                                  dht.readSensor(true);
                                  if (isnan(temperature)) {
                                    lastTemp = temperature;
                                    // apply the offset before converting to something different than Celsius degrees
                                    if (!metric) {
                                    // Reset no updates counter
                                    nNoUpdatesTemp = 0;
                                    #ifdef MY_DEBUG
                                    Serial.print("T: ");
                                    nNoUpdatesTemp++;
                                  if (isnan(humidity)) {
                                    lastHum = humidity;
                                    nNoUpdatesHum = 0;
                                    #ifdef MY_DEBUG
                                    Serial.print("H: ");
                                    Serial.println(humidity);
                                    nNoUpdatesHum++;
                                  u8g2.firstPage();
                                  do {
                                  u8g2.setFont(u8g2_font_fub30_tn);
                                  u8g2.setCursor(2, 35);
                                  u8g2.print(temperature, 1);
                                  u8g2.setFont(u8g2_font_inb16_mf);
                                  u8g2.drawGlyph(88, 35, 0x00b0); // degree
                                  u8g2.drawStr(100, 35, "C");
                                  u8g2.setCursor(70, 60);
                                  u8g2.print(humidity, 0);
                                  u8g2.drawStr(100, 60, "%");
                                  u8g2.setFont(u8g2_font_open_iconic_thing_2x_t); // 16 pix height
                                  u8g2.drawGlyph(45, 60, 0x0048); // drop
                                  //sleep(UPDATE_INTERVAL);
                                  delay(UPDATE_INTERVAL);  // POWERED NODE
                                • T titvs
                                  LOG
                                  //#define MY_RS485
                                  float lastTemp;
                                  float lastHum;
                                  bool metric = true;
                                  DHT dht;
                                  void before(){
                                     u8g2.begin();
                                     u8g2.firstPage();
                                     do {
                                    delay(3000);
                                    u8g2.clear();
                                     u8g2.firstPage();
                                      do {
                                    u8g2.clear();
                                      u8g2.firstPage();
                                      do {
                                      delay(4000);
                                    u8g2.firstPage();
                                    do {
                                      if (!metric) {
                                      nNoUpdatesTemp = 0;
                                      #ifdef MY_DEBUG
                                      nNoUpdatesTemp++;
                                      lastHum = humidity;
                                      nNoUpdatesHum = 0;
                                      #ifdef MY_DEBUG
                                      nNoUpdatesHum++;
                                    u8g2.firstPage();
                                    do {
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @titvs ok, do you also have the repeater log + sketch? btw, for powered nodes I'd recommend using wait() instead of delay() - this ensures a proper functionality of the communcation stack.
                                  • tekkaT tekka
                                    titvs
                                    @tekka i didnt save the log from the Repeater but if it helps i'm going to collect it. As for the Repeater sketch, its the default:
                                    //#define MY_RADIO_NRF5_ESB
                                    //#define MY_RADIO_RFM95
                                    #define MY_NODE_ID 51    // FIXED NODE ID
                                      //Send the sensor node sketch version information to the gateway
                                      sendSketchInfo("Repeater Node", "1.0");
                                    • T titvs
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @titvs Would be great if you collect the debug log of the repeater, especially when the NACKs happen - this may help to understand the origin of the issue
                                      • tekkaT tekka
                                        titvs
                                        @tekka Here it is: REPEATER LOG
                                        It seems to be working ok but there are still some NACKs on the log. Radio issues perhaps? Neverthless, im not getting the node dropouts i got with the 2.3.0 version...
