  3. [SOLVED] Raspberry PI gateway
4 Posts 2 Posters 1.4k Views 2 Watching
  • cadetC
    cadetC
    cadet
    Hi.
    Just install RPi gateway 2.3.0 and add it to Vera
    inclusion button inactive - both grey.??
    Please help
    cadetC 1 Reply Last reply
    • cadetC cadet
      Hi.
      Please help
      cadetC
      cadetC
      cadet
      install 2.1.1 - same problem
      try another Vera - same problem
      I have arduino GW on that Vera and it work fine
      But no inclusion with RPi
      • cadetC cadet
        cadetC
        cadetC
        cadet
        Found
        anvil 2 years ago
        Solved - user error 🙂
        Inside the Raspberry Pi setup (file /MySensors/examples_linux/mysgw.cpp), the inclusion mode define must be added:
        This is present in the Serial & Ethernet gateway example ino files, just missing from the Raspberry Pi version as it is on GitHub.
        With this added, the response to the StartInclusion mode request is then received & everything is fine:
        TX(fromController) 0;0;3;0;5;1
        RX(fromRaspberryPiGateway) 0;255;3;0;5;1
        On the plus side, by working this out I'm a lot more familiar with the workings of MySensors!
        Cheers!
        • cadetC cadet
          Found
          anvil 2 years ago
          Cheers!
          @cadet Great to hear you solved it and thanks for the feedback! :+1:
