  3. Everything nRF52840
Everything nRF52840
323 Posts 28 Posters 172.6k Views 33 Watching
    @heinzv said in Everything nRF52840:
    and what about that:
    https://os.mbed.com/platforms/Nordic-nRF52-DK/
    The mbed compiler doesn't seem to even recognize that there are new GPIO pins on the nRF52840 that don't exist on the nRF52832. For instance, P1.00, which is one of the pins on the Fanstel nRF52840 module. Plus, I'm not sure that printf works with anything other than USB. I've tried setting it to other pins, and it just hangs. I've written some custom code to do my own sserial communications over P1_00 (to handle a PCB backward compatability issue with the nRF52840 Fanstel modules), but if mbed is only half baked, it's not helping me like it should.
    Not sure about platform.io. Thanks for the lead. I'll look into it.
    H
    H
    heinzv
    wrote on last edited by heinzv
    #26
    @neverdie take a look at platform.io, it supports al known SOC's. INstall it then from the Visual Studio Code IDE. Both together are a very professional IoT dev environment (also Web and other development).
    I was doing very complex development like ESPurna project build you would not like to do in the Arduino IDE.
    Let me know if you need further hints.
    VSC and Platform.IO includes not only all SOC HW families but also all kind of libraries you know from Arduino and it can also import Arduino project (*.INO Files).
    Give it a try and you will be suprrised once you get familar.
    It does also the flashing (upload), includes GIT nativly, has a command window, debugging etc etc.
    https://code.visualstudio.com/
    https://marketplace.visualstudio.com/items?itemName=platformio.platformio-ide
    https://marketplace.visualstudio.com/search?term=platform.io&target=VSCode&category=All categories&sortBy=Relevance
    Platforms: Atmel AVR, Atmel SAM, Espressif 32, Espressif 8266, Freescale Kinetis, Infineon XMC, Intel ARC32, Intel MCS-51 (8051), Lattice iCE40, Maxim 32, Microchip PIC32, Nordic nRF51, Nordic nRF52, NXP LPC, RISC-V, Samsung ARTIK, Silicon Labs EFM32, ST STM32, Teensy, TI MSP430, TI Tiva, WIZNet W7500
    Frameworks: Arduino, ARTIK SDK, CMSIS, Energia, ESP-IDF, libOpenCM3, mbed, Pumbaa, Simba, SPL, STM32Cube, WiringPi
      #27
      @heinzv platformio is nice for supporting lot of SOCs. But I think it still rely on sandeep arduino or mbed for nrf5, so, not sure if it adds stuff to the frameworks.. (regarding boards mapping, softdevices, etc). that's what NeverDie is searching I think.. an environment which allows to use all features of the SOC that he buy, ideally with myensors but we still can wait :)
      regarding what you asked me previously, this is one of my reason. As missing core features is not what I'm calling fast/easy to market/production for smarter features!
      That, and nrf is 2.4ghz only (area here is 9000m², few outbuildings with thick walls too), so increase of BOM&layout when using multiple modules (not a big problem for a gw, less nice for nodes). I don't want to use lora too..
      H 1 Reply Last reply
      • scalzS scalz
        H
        H
        heinzv
        #28
        @scalz
        That is what I found at the nordic docu for development
        http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.gs%2Fdita%2Fgs%2Fgs.html&cp=1
        https://www.nordicsemi.com/eng/Products/Bluetooth-low-energy/nRF52-DK
        They mention two dev environments
        • nRF5 Series: Developing with SEGGER Embedded Studio
        • nRF5 Series: Developing on Windows with ARM Keil MDK
        Platform.IO support description for nRF52
        framework-arduinonordicnrf5 Arduino Wiring-based Framework (Nordic NRF5 Core)
        framework-mbed mbed Framework
        tool-jlink SEGGER J-Link Software and Documentation Pack
        tool-nrfjprog nRF5x command line tool
        tool-openocd OpenOCD
        tool-sreccat Merging tool
        toolchain-gccarmnoneeabi gcc-arm-embedded
        So what MCU's and radio/transmission are you using then ... ?
          #29
          I don't see specific support in platformio for nRF52840. Also, it's support for nRF52 generally seems to rely on mbed:
          https://github.com/platformio/platform-nordicnrf52/tree/master/examples?utm_source=platformio&utm_medium=docs
          I suspect the only way to do this is to use Nordic's SDK and one of the tool chains that Nordic recognizes as working with it. I hope I can find one without a heavy learning curve. Either that or limp along with mbed, which is half baked but (so far) at least allows me to do direct registry manipulations. With mbed maybe it will turn out that the total amount of remedial code I have to write isn't huge. Not sure. I don't have much confidence in mbed's future though. I'm noticing that a lot of the posts on their forum go completely unanswered.
          Nordic, on the other hand, seems much better about answering posted questions (well, 5 days a week anyway. Forget about weekends).
          @heinzv We've come full circle on this. I previously posted a question on the Sandeep github as to whether it supported the nRF52840, and the answer was no, its SDK was too new, but that maybe I would have some success in programming it if I treated it like an nRF52832. https://github.com/sandeepmistry/arduino-nRF5/issues/310 Well, that's really no better than the current situation with mbed.
          The only other thing on the horizon might be miropython. Not sure if micropython is fully deterministic enough for microcontroller work (e.g. might it garbage collect in the middle of a critical loop?), but maybe it's worth a shot. "Blinka & her new pal the nRF52840" https://learn.adafruit.com/circuitpython-on-the-nrf52
          • H
            H
            heinzv
            @NeverDie have you also checked this from my previous 3 posts agao
            https://github.com/lpercifield/arduino-nRF5/tree/nrf52840
            this is a fork from sandeeps Arduino-NRF5 project which explicitly adds nRF52840 (that was the reason for the fork) where people have been waiting for (and probably sandeep has not announced a support soon).
            See also sandeeps respons to lpercifield's work
            https://github.com/sandeepmistry/arduino-nRF5/issues/70
            Softdevice in this project is at S132 and Nordic newest is S140 (full BLE5 stack). Don't know why is was not yet worked into and why there is not realy a big progress since 2 years.
            At least there is a project with nRF52 and LoRa (SX1276/RFM95) :-)
            https://github.com/gluedig/nrf52-lora
            • H heinzv
              #31
              @heinzv Thanks for pointing that out. It sounds like lpercifield encountered the exact same problems as me, except two years earlier. But, then he hasn't touched his code in the 2 years afterward. Nordic's SDK has changed since then. I'm just not sure.
              I guess it's a question of whether these one person, piecemeal attempts are enough, or whether joining with a toolchain that has a lot more oomph behind it is preferable. I suspect the total amount of work involved is just too much for one person, in their spare time, to accomplish more than partial coverage. Again, not sure, but I can see what @scalz means.
              I don't think Nordic has any interest in Arduino IDE support per se. If anything, it probably means a costly support burden to them without revenues to support it. Instead, Nordic is clearly targeting big commercial buyers , like phone manufacturers or the like, who will buy millions of chips just to have the latest features/capabilities. So, with nothing to pay for it on the Arduino front, except maybe a tiny bit by Adafruit or Sparkfun, it's necessarily just a bunch of individual, ad hoc efforts, or so it seems to me. Those individuals will solve whatever matters to them personally, but leaving spotty coverage on everything else. It' is admittedly better than nothing. Maybe for what I'm doing it's good enough. More than a little frustrating though.
                #32
                @NeverDie dilemma.
                maybe try: apache mynewt + plugin for visual studio code. that might pick your curiosity. I liked it when I tried. but you know.. :nerd_face:
                or zephyr but I don't know much about it.
                of course, these advanced toolchains are less easy to get started than arduino (setup or coding details). needs to port some arduino libs when you need it (makes sense). You won't get proprietary rf stack like MySensors out of the box too. It'll be BLE based in this case.
                But you'll be able to use your mcu as you wish.
                I hope you'll like it, else do like me :laughing:
                  #33
                  You can also increase range by increasing the number of preamble bytes. Today I upgraded to using 4 preamble bytes. Beyond that it's likely diminishing returns.
                  To do the same on the nRF52840, use:
                    NRF_RADIO->PCNF0=0x02000000;  //4 pre-amble bytes.  S0,LENGTH, and S1 are all zero bits long.
                  @heinzv Another factor in range is how high off the ground your radio nodes are. This can have a huge effect, due to multipath fading from the ground. According to the Fanstel datasheet, for instance, even going from half a meter off the ground to 1.5 meters off the ground can almost triple your range. So, at the very least, try to put your gateway up as high as you can.
                    #34
                    exactly.
                    with infos below, you have everything for estimating the range (maybe that can interest others people too):
                    • https://forum.mysensors.org/post/93384 simple but so true.
                    • an excellent excel sheet made by.. TI! :) where you can pick absorption materials, set height of antenna, indoor/outdoor calc etc
                      http://www.ti.com/tool/RF-RANGE-ESTIMATOR
                      The doc for the sheet http://www.ti.com/lit/an/swra479a/swra479a.pdf , very interesting too with comparison about selectivity/blocking etc
                      or the forum thread in case https://e2e.ti.com/support/wireless_connectivity/proprietary_sub_1_ghz_simpliciti/f/156/t/375556
                      works ok, here, with excel 2010 viewer (else you can't use choice lists)
                      As it targets TI mcu, it's explained in docs that you can try by using an "equivalent" TI mcu, then check datasheet values for your mcu and change what's needed in the excel sheet. Maybe cc2640r2f and nrf52840 has "same" rf perf at 125kbps, no idea about blocking level.
                    Lot of variables, which also make a FCC module to become non-FCC when soldered on a custom board; all certified modules pass tests regarding a specific manufacturer design&usecase, they cannot certify that people won't degrade RF and emit bad stuff, thus that become non-FCC. Applicable to all RF devices though, rf laws rules (even when changing antenna for better gain, or different shape, on wifi router, it breaks certif in theory).
                    Like you said, better pick a good antenna sure! There are antenna which are resistant to detuning, but most of antennas like "coiled" wire, meandered pcb trace (cdebyte 52832 type), or ceramic antennas are easily detuned by pcb layout, or once it's enclosed, or close to objects (stacked boards, metals, hands etc). Then, they need to be rematched to get best range.
                    Good to know and interesting stuff ;)
                      #35
                      Well, interestingly, I just now tried the BLE Long Range preamble, which is 10 reptetitions of 0x3C, and it really does seem to make a noticeable improvement in coverage/range/reliability. Obviously the extra repetitions help, but I think maybe (?) it's also partly because the 4 byte preamble is the one specified by 802.11.15, which is 4 bytes of all zeros (which is pretty weird. Never seen that as the preferred choice before. Usually preambles are alternating high low signals instead).
                      To set the preamble to BLE Long Range, use:
                       NRF_RADIO->PCNF0=0x03000000;  //10 preamble bytes.  S0,LENGTH, and S1 are all zero bits long.
                        #36
                        Skylab has modules at just $5.50: https://www.aliexpress.com/item/Nordic-Offical-Strategic-Partner-SKYLAB-Long-Distance-Range-bluetooth-5-ble-5-0-nrf52-nrf52840-module/32920765239.html?spm=2114.search0604.3.102.59ae549fMHxusA&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10130_10547_10546_10059_10884_10548_315_10545_10887_10696_100031_531_10084_10083_10103_451_10618_452_10307,searchweb201603_45,ppcSwitch_7&algo_expid=43141ae1-fb38-4ef7-b964-6c2d29338f79-16&algo_pvid=43141ae1-fb38-4ef7-b964-6c2d29338f79&priceBeautifyAB=0
                        Unfortunately, I don't see the module on their website, nor does the listing show a pinout. Of course, the antenna won't be good. Regardless, I'd like to see a pinout.
                        monteM 1 Reply Last reply
                          monteM
                          monteM
                          monte
                          @neverdie why won't you use Nordic's native SDK with Eclipse? I found some tutorials how to set it up, so I guess it's an option.
                            H
                            H
                            heinzv
                            @neverdie thanks for the info, I appreciate your effort and investigations. I'll use my gateway and the sensor nodes at least in 1,5m height from the ground.
                            Today I got my nrF52832 and also the nRF52840. The E73..C modules are tiny (around 11x16mm). I can't use it without a breakout board. CDBYTE promised me to send me at least reference PCB design which I can then order from any PCB company.
                            The Skylab moduls are promising, but I see some deficiencies: No pinout, less pins (don't know what was skiped), no 32kHz low power quart for sleep timer ... I have ordered some other modules ... lets see, so far I can't test a lot without the carrier PCB's.
                            Then I join you with testing (range/transmisson test, sensor readout, battery measurement, ePaper ...)
                              #39
                              I seem to be getting noticeably better coverage when receiving with a BT840F than with an nRF52840-DK. That's a bit surprising, as the ground plane is smaller. The are several possible explanations, but I'm guessing the metal can around the radio, which the BT840F has but the nRF52840-DK lacks, probably helps reduce the effective noise floor and thereby improve the S/N ratio. So, if you're picking a module, you may want to pick a module which has that. :) Most of them don't, but there are a few that do.
                                It turns out mbed does support the p1 pins. It just uses a different notation. Instead of P1_00, it's P1_0. Here's a link to all of the pin names: https://github.com/ARMmbed/mbed-os/blob/master/targets/TARGET_NORDIC/TARGET_NRF5x/TARGET_NRF52/TARGET_MCU_NRF52840/TARGET_NRF52840_DK/PinNames.h
                                So, because of ease of use and that I'm already started with it, I'm going to stick with mbed a bit longer. I have run across one inconvenient bug relating to send serial communications, but I've reported it, and I've devised a workaround to it until it gets fixed.
                                Meanwhile, with all the above tweaks, I'm getting pretty good home coverage with just a single gateway mounted centrally on the second floor. It's not yet at LoRa's near perfect transmission/reception for a every conceivable nook and cranny in a home environment, but I suspect it may approach that once the amplified modules becomes available. And that's all transmitting at 1mbps, without the benefit of BLE Long Range which it is capable of doing.
                                • Nca78N
                                  And what about Segger Embedded Studio ? It's now free to use with Nordic SDK for NRF5 MCUs
                                  https://www.segger.com/news/segger-embedded-studio-ide-now-free-for-nordic-sdk-users/
                                    #42
                                    I resurrected @d00616 's code for reading the supply voltage to the nRF52, and it seems to work reasonably accurately on the nRF52840-DONGLE. Here it is again to spare people from searching for it:
                                    uint16_t hwCPUVoltage()
                                      int32_t sample;
                                      NRF_SAADC->RESULT.MAXCNT = 1;
                                      NRF_SAADC->TASKS_START = 1;
                                      NRF_SAADC->EVENTS_END = 0;
                                      NRF_SAADC->TASKS_SAMPLE = 1;
                                      NRF_SAADC->TASKS_STOP = 1;
                                      return (sample*3600)/255;
                                    With that as a voltage reference point, I plan to next try reading and wireless reporting the voltage on a solar panel, the one charging the supercap that will be powering the dongle.
                                    It's nice that the previous work done on the nRF52832 is easily and quickly ported to the nRF52840. :)
                                      #43
                                      I found a driver for doing 802.15.4 on the nRF52840 that looks rather interesting: https://github.com/NordicSemiconductor/nRF-IEEE-802.15.4-radio-driver
                                      The sample application its Wiki makes it look rather easy to use:
                                      https://github.com/NordicSemiconductor/nRF-IEEE-802.15.4-radio-driver/wiki/Sample-application
                                      • Nca78N Nca78
                                        #44
                                        @nca78 said in Everything nRF52840:
                                        Looks quite promising, and probably easier to setup than eclipse. Actually seems quite sophisticated with tight debugger integration.
                                        I tried to get started with eclipse, and I immediately got lost. I just couldn't find a good tutorial for its C++ IDE. Segger looks as though it may be simpler.
                                        In order to be able to run the 802.15.4 demo code, which I refer to above, I need to be able to use an IDE that can utilize the Nordic SDK. I'm not sure that mbed can do that. So, unless someone knows of anything simpler, maybe segger embedded studio is it.
                                          #45
                                          I have Segger Embedded Studio (SES) up and running now. I built and ran the Nordic SDK's "hello world" over serial example. It works. Following this video made it easy:
                                          https://www.youtube.com/watch?v=YZouRE_Ol8g&index=2&t=0s&list=PLx_tBuQ_KSqGHmzdEL2GWEOeix-S5rgTV
                                          It's clear from this that all the Nordic SDK examples directly support SES, because there are preconfigured files within the Nordic SDK for building each example on Segger Embedded Studio. :) I don't see the same for mbed. :(
                                          Also, as an aside, it's worth noting that the SDK's after 12.3 no longer support the nRF51. The current nordic SDK is version 15.2. Make of that what you will.
