Moisture reading inverse in Domoticz
Hello everyone here at MySensors,
I have made a mysensors sketch to measure soil moisture in the garden, the sketch work properly, so it is not falling apart ;)
Only the value in Domoticz is the opposite of what it really is.
If I have the sensor loose on the desk I get 20cb as value (irrigation advise) and when I put the sensor in a glass of water I get 100cb (dangerously dry)is there a possibility to turn this into domoticz, or is the problem in the mysensors sketch?
I read the value in this way:
int moistureLevel11 = (1023 - analogRead(VOCHT_PUT_1_PIN))/ 10.23; if (moistureLevel11 != lastsoilValue11) { send (msg11.set(moistureLevel11)); lastsoilValue11 = moistureLevel11;}And With: S_Moisture
I Use Mysensors 2,3 and Domoticz Beta V4.10064
thank you in advance
dzjr
dzjr
@dzjr the debug log from the node would be useful to see which number is being sent.
If the value needs to be inverted in the sketch, just remove this part:
1023 -Thank Your for the reply,
I removed the 1023 - And it looks bij now, i think that i have to tweak it to get te right value.
The node i have combined in a gateway, do i get a good debug than with #my_debug ?
This is the MyDebug output:
0 MCO:BGN:INIT GW,CP=R-NGA---,VER=2.3.0 3 MCO:BGN:BFR 741 GWT:TIN:IP=192.168.0.145 1744 MCO:BGN:STP 1746 MCO:REG:NOT NEEDED 1748 MCO:BGN:INIT OK,TSP=NA 39316 GWT:TSA:ETH OK 39375 GWT:RFC:MSG=0;0;3;0;2; 39382 GWT:RFC:MSG=0;0;3;0;2;Get Version 45932 GWT:RFC:MSG=0;0;3;0;18;PING 55858 GWT:RFC:MSG=0;0;3;0;18;PING 65783 GWT:RFC:MSG=0;0;3;0;18;PING 75709 GWT:RFC:MSG=0;0;3;0;18;PING 85635 GWT:RFC:MSG=0;0;3;0;18;PING 95560 GWT:RFC:MSG=0;0;3;0;18;PING 105486 GWT:RFC:MSG=0;0;3;0;18;PING 115411 GWT:RFC:MSG=0;0;3;0;18;PING 125337 GWT:RFC:MSG=0;0;3;0;18;PINGi have edit the sketch to this:
int moistureLevel11 = (analogRead(VOCHT_PUT_1_PIN)) / 5.8; if (moistureLevel11 != lastsoilValue11) { send (msg11.set(moistureLevel11)); lastsoilValue11 = moistureLevel11;}i only have to adjust the " / 5.8 " for the right value in the ground.
Thank you for helping!
dzjr
@dzjr , glad you solved your problem .. but... can you please share which sensor are you using to measure the soil moisture?
I found a lot of sensor suitable for in-house measuring but nothing for outside which is not becoming unusable very quickly.
Whatever information is highly appreciated...Giacomo
I use the soil humidity sensor with the external pcb.
Only I find the measured range somewhat disappointing, I get when completely in water, not the measured value "saturated" it lingers on irrigation.
so if you have a different solution, I am very much recommended.
dzjr
@dzjr this is what I also had in mind but... are you using a commercial sensor or you built one yourself?
When I say "sensor" I mean the device that is currently in the soil.
I checked different commercial sensor and all seem to become unusable in a very short time... this is why I'm really interested in your solution -
I checked different commercial sensor and all seem to become unusable in a very short time... this is why I'm really interested in your solutionI now use the commercial sensors from the above link.
Because the sketch I was still testing the sensors I only tried in a plant or loose on my desk with a glass of water.
For the control I make an output of the arduino high and use it to control the transistors.
I will try to post a photo tomorrow.
dzjr
