  3. Nodo 485
Nodo 485
4 Posts 2 Posters 1.3k Views 2 Watching
  • bocmauB
    bocmauB
    bocmau
    this is the message sent by the well known Arduino 2009 :
    TSF: MSG: SEND, 9-9-255-255, s = 255, c = 3, t = 7, pt = 0, l = 0, sg = 0, ft = 0, v = OK:
    this is the message sent by the well known Arduino micro ;
    TSF: MSG: SEND, 255-255-255-255, s = 255, c = 3, t = 7, pt = 0, l = 0, sg = 0, ft = 0, v = OK:
    the program is the same for the two cards
    how does this happen?
    • bocmauB bocmau
      @bocmau that's a strange format of the debug log. Where does it come from? The log parser is unable to understand it.
      Could you post the rest of the logs? Just a single line without context is quite hard to make sense from.
      • bocmauB
        bocmauB
        bocmau
        @mfalkvidd said in Nodo 485:
        Thanks I solved in 485 the registration does not work
        We must add #define MY_NODE_ID XX
        • bocmauB bocmau
          @bocmau that's very strange. Which controller are you using?
