  3. Motor status manager with Wemos D1 mini & current sensor ASC712
11 Posts 2 Posters 2.5k Views 2 Watching
  • P Offline
    P Offline
    phamchien1112
    Re: [Wemos D1 Mini / ESP8266](MySensors and Analog A0)
    Dear, I want to manager motor (220V -80w)status with Wemos D1mini and Current sensor ASC712. If motor burned ( Current =0, or approximately =0), system will show status of motor on android app. I hope everyone can help/support me code for this system. Thank you
      It is not really mysensors related, but i'd get a sonoff pow and you would get pretty much all you are looking for.
      • P Offline
        P Offline
        phamchien1112
        Dear Gohan,
        If i use SONOFF pow, I will not know where the power failure , in any case motor burned. At the same time, it is not possible to collect engine operating time.
          There are some rules you can make on the app and it should also keep track of the power usage. If that is not enough for you, you can flash tasmota on the sonoff and use any controller that can use mqtt to get data from the sonoff and control the relay.
          • P Offline
            P Offline
            phamchien1112
            Thanks you, Gohan.:v:
            • P Offline
              P Offline
              phamchien1112
              Dear Gohan,
              Thank for your supporting.
              I want to add adapter 220v-5v with a buzzer when motor burned ( Current =0, or approximately =0) the relay will turn on.
              I trying to use SONOFF 4CH R2 to setup system function as above but can not setup .
              If i flash tasmota SONOFF 4CU R2, then i can set up as mention above? Or have any other way for set up.
              I hope early receive your support.
              Thanks you.
                Sonoff 4CH does not have power reading
                P 1 Reply Last reply
                  P Offline
                  P Offline
                  phamchien1112
                  @gohan
                  type sonoff 4CH R2.
                  If can not using sonoff 4CH R2, dou you know other way for setting up.
                  Thanks you.
                  gohanG 1 Reply Last reply
                    you can use one sonoff pow and another sonoff basic, I think you can create rules between devices but I don't use the sonoff app as I already have my home automation setup, so I don't know exactly how to do what you are asking using just the stock firmware and its app
                    • P phamchien1112
                      @gohan
                      type sonoff 4CH R2.
                      Thanks you.
                      @phamchien1112 maybe you can also consider this https://shelly.cloud/product/shelly-4pro/ , maybe a little overkill for your needs
                      • P Offline
                        P Offline
                        phamchien1112
                        @gohan Thank you.
                        12.1k
