  3. 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway
mqttsonoffhome assistanesp8266
93 Posts 25 Posters 41.6k Views 20 Watching
  • J Jan Gatzke
    @gohan won't this option miss some features? :D
    @Jan-Gatzke for a sonoff there aren't many options and also a wired button you are pretty sure it would always work. 😀
    • dbemowskD
      dbemowskD
      For the Sonoffs, you could wire an external button directly to the onboard button which is on GPIO 0, or you could wire it to GPIO 14 which is broken out on the programming header on most Sonoffs. Some older Sonoffs didn't have GPIO 14 on that header. Once you have a button or switch wired on, you can then change the code or do some firmware scripting depending which flavor of firmware you use.
      • dbemowskD dbemowsk
        @Jonathan-Caes said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
        Do you know how I can setup the sonoff gateway on the Vera Edge?
        I am using a Vera Plus. I did not go the route of MySensors for my Sonoffs. I use the ESP Easy firmware with a slightly modified Vera plugin. Here is my BLOG post on how to do it.
        https://dan.bemowski.info/2017/07/04/using-a-sonoff-with-espeasy-and-vera/
        You could still go the MySensors route. I just figured I'd show another alternative to this.
        sam9sS
        sam9sS
        sam9s
        @dbemowsk Do you know if there is a way to use vera edge / plus with Tasmota firmware instead of EasyESP??
        dbemowskD 1 Reply Last reply
        • sam9sS sam9s
          dbemowskD
          dbemowskD
          @sam9s I have never played with Tasmota, so I have to say that I don't know. A Vera plugin would have to be coded or modified as I did with the HTTP Switch plugin to make it work if there is not one out there already. I am assuming that you looked at my blog post on the ESP Easy way.
            Can the Vera plug in work with mqtt?
              dbemowskD
              dbemowskD
              @gohan Here is a plugin for MQTT using Vera. You would still need to have an MQTT Broker set up though. I am surprised that there is not an active MQTT plugin for Vera in the plugins section. Didn't find anything when I did a search for MQTT.
                I was just asking since tasmota works great on mqtt
                • tripyT
                  tripyT
                  tripy
                  I will just leave that here for other like me that wondered for hours why they could flash their sonoff, but it did not react once plugged to the main.
                  You need to setup your arduino with DOUT as flash mode.
                  Other mode will flash without errors, but the device will appear bricked.
                  My settings where:
                  K 1 Reply Last reply
                  • tripyT tripy
                    My settings where:
                    K
                    K
                    kalle
                    @tripy yes, you are absolute right - you need to set the flash Mode to DOUT for flashing the newer SONOFF generation (the SONOFF's with the hidden green LED).
                    • vladimirV
                      vladimirV
                      vladimir
                      Hello!
                      Maybe someone here has a code for Sonoff RF with support 433 MHz receiver?
                      In my opinion, paired with a wireless wall switch, this will turn out to be quite a cheap and convenient solution for lighting control.
                      The cost of a set of relay and switch about 10 dollars.
                      • electrikE
                        electrikE
                        electrik
                        Did you try this?
                        https://github.com/arendst/Sonoff-Tasmota
                        vladimirV 1 Reply Last reply
                        • electrikE electrik
                          Did you try this?
                          vladimirV
                          vladimirV
                          vladimir
                          @electrik Now I just read the description of this firmware. To do this, I need to understand how to work with MQTT. I hoped to find a simpler solution. Ethernet gateway is much easier to connect.:man-shrugging:
                          gohanG 1 Reply Last reply
                          • electrikE
                            electrikE
                            electrik
                            Mqtt Is really easy to use in fact. Just follow a tutorial to install mosquitto and you're ready to go.
                            It also depends on your controller of course
                              vladimirV
                              vladimirV
                              vladimir
                              @electrik Thanks you! Now I will order everything I need on TaoBao in China. I just yesterday learned about the existence of the Sonoff module with 433 MHz radio support and wall switches for them.
                              • vladimirV vladimir
                                @vladimir what controller are you using? Most home automation controllers like domoticz and Home Assistant have a quick integration with Tasmota or EspEasy
                                  vladimirV
                                  vladimirV
                                  vladimir
                                  @gohan I use OpenHAB 2. As I understand it, it also integrates well with Tasmota.
                                    good, give it a try
