💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway
For the Sonoffs, you could wire an external button directly to the onboard button which is on GPIO 0, or you could wire it to GPIO 14 which is broken out on the programming header on most Sonoffs. Some older Sonoffs didn't have GPIO 14 on that header. Once you have a button or switch wired on, you can then change the code or do some firmware scripting depending which flavor of firmware you use.
@Jonathan-Caes said in 💬 Sonoff relay using MySensors ESP8266 wifi or mqtt gateway:
Do you know how I can setup the sonoff gateway on the Vera Edge?
I am using a Vera Plus. I did not go the route of MySensors for my Sonoffs. I use the ESP Easy firmware with a slightly modified Vera plugin. Here is my BLOG post on how to do it.
https://dan.bemowski.info/2017/07/04/using-a-sonoff-with-espeasy-and-vera/You could still go the MySensors route. I just figured I'd show another alternative to this.
@dbemowsk Do you know if there is a way to use vera edge / plus with Tasmota firmware instead of EasyESP??
@sam9s I have never played with Tasmota, so I have to say that I don't know. A Vera plugin would have to be coded or modified as I did with the HTTP Switch plugin to make it work if there is not one out there already. I am assuming that you looked at my blog post on the ESP Easy way.
I will just leave that here for other like me that wondered for hours why they could flash their sonoff, but it did not react once plugged to the main.
You need to setup your arduino with DOUT as flash mode.
Other mode will flash without errors, but the device will appear bricked.
My settings where:
My settings where:
Hello!
Maybe someone here has a code for Sonoff RF with support 433 MHz receiver?
In my opinion, paired with a wireless wall switch, this will turn out to be quite a cheap and convenient solution for lighting control.
The cost of a set of relay and switch about 10 dollars.
Did you try this?
https://github.com/arendst/Sonoff-Tasmota -
Did you try this?
Mqtt Is really easy to use in fact. Just follow a tutorial to install mosquitto and you're ready to go.
It also depends on your controller of course -
@electrik Now I just read the description of this firmware. To do this, I need to understand how to work with MQTT. I hoped to find a simpler solution. Ethernet gateway is much easier to connect.:man-shrugging:
@vladimir what controller are you using? Most home automation controllers like domoticz and Home Assistant have a quick integration with Tasmota or EspEasy
