  3. RelayWithButtonActuator - another n00b question
relayactuatorbutton
10 Posts 3 Posters 4.5k Views 1 Watching
  • gaduG
    gaduG
    gadu
    So here we go again with the n00b questions...
    Setup:
    Two relays and one button
    Use case:
    1. Press button
      1.1) Relay_1 ON
      1.2) Relay_2 ON
      1.3) delay(1000) then Relay_2 OFF
    2. Press button
      4.1) Relay_1 OFF
    Been trying this a couple of hours today and nothing worked, if I add some delay or change anything in the sketch the button instantly stops working. I have no sketch to share since nothing has been even close. I've searched the forum and nothing.
    Anyone have any pinpointers where to start looking? Links? Anything? :)
    I tried different versions like this with only one relay and trying to get it to turn off after 1sec, but with no success....
       debouncer.update();
       // Get the update value
       int value = debouncer.read();
       if (value != oldValue && value==0) {
      gw.send(msg.set(state?false:true), true); // Send new state and request ack back
       oldValue = value;
     delay(1000);
    O 1 Reply Last reply
    • gaduG
      gaduG
      gadu
      This was actually useful....
      http://playground.arduino.cc/Code/AvoidDelay
      • gaduG gadu
        Setup:
        Use case:
        1. Press button
          1.1) Relay_1 ON
          1.2) Relay_2 ON
        2. Press button
          4.1) Relay_1 OFF
           debouncer.update();
           oldValue = value;
         delay(1000);
        O
        O
        olaeke
        @gadu You should be aware that the delay function stop the processing so it is a huge chance that you will miss incoming messages because 99% om the time the mainloop will hang waiting. Try use millis() function instead
        • gaduG
          gaduG
          gadu
          @olaeke hehe yup, google helped me out there... Sometimes you get stuck on silly things...
          • gaduG
            gaduG
            gadu
            I'm still at this trying to create a sketch.
            Been playing around with millis() without any luck, ran into a example while google for a solution, however this uses delay.
            Not an issue though that delay is stops the processing, just trying to understand how this works. I've come this far (using led instead of relay), the idea is that when pressing the button the led = high for 1sec then led = low.
            In MQTT I need to see both V_LIGHT=1 and then V_LIGHT=0.
            Any ideas or pinpointers? I know i'm wandering the dark here.. :)
            This is the sketch so far, cut&paste from all over...
             #define BUTTON_PIN  3
             #define RELAY_ON 1
             #define RELAY_OFF 0
             // constants won't change. Used here to
             // set pin numbers:
             const int ledPin =  4;      // the number of the LED pin
             int oldValue=1;
             // Variables will change:
             int ledState = LOW;             // ledState used to set the LED
             Bounce debouncer = Bounce();
             bool state;
             // the follow variables is a long because the time, measured in miliseconds,
             // will quickly become a bigger number than can be stored in an int.
               gw.sendSketchInfo("RelayDelay with button", "1.0");
              // Setup the button
               pinMode(BUTTON_PIN,INPUT);
               // Activate internal pull-up
               debouncer.attach(BUTTON_PIN);
               debouncer.interval(5);
               gw.present(CHILD_ID, S_LIGHT);
                // set the digital pin as output:
               pinMode(ledPin, OUTPUT);
               digitalWrite(ledPin, ledState);
               state = gw.loadState(CHILD_ID);
               //digitalWrite(ledPin, state?RELAY_ON:RELAY_OFF);
               debouncer.update();
             if(value == 0 && oldValue == 1) {
               if(ledState == HIGH) {
            digitalWrite(ledPin, LOW);
               digitalWrite(ledPin, HIGH);
               //gw.send(msg.set(state?false:true), true);
               delay(1000);
               if (message.isAck()) {
             // Change relay state
             state = message.getBool();
             // Store state in eeprom
             gw.saveState(CHILD_ID, state);
            • gaduG gadu
               #define RELAY_ON 1
               #define RELAY_OFF 0
               // set pin numbers:
               int oldValue=1;
               bool state;
                // Setup the button
                 debouncer.update();
                 delay(1000);
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              try like this... I did not create a device for relay 2...
              (untested, but compiles)
              #define RELAY_PIN_1  4  // Arduino Digital I/O pin number for relay
              #define RELAY_PIN_2  5
              #define BUTTON_PIN   3  // Arduino Digital I/O pin number for button
              #define RELAY_ON  1
              #define RELAY_OFF 0
              int oldValue=0;
              boolean state;
              unsigned long relayTwoTimerStart;
                gw.sendSketchInfo("Relay & Button", "1.0");
                digitalWrite(RELAY_PIN_1, RELAY_OFF);
                pinMode(RELAY_PIN_1, OUTPUT);
                pinMode(RELAY_PIN_2, OUTPUT);
                digitalWrite(RELAY_PIN_1, state?RELAY_ON:RELAY_OFF);
                debouncer.update();
                oldValue = value;
                if (millis() - relayTwoTimerStart < 1000UL)
                  if (digitalRead(RELAY_PIN_2) == LOW)
                    digitalWrite(RELAY_PIN_2, HIGH);
                  if (digitalRead(RELAY_PIN_2) == HIGH)
                    digitalWrite(RELAY_PIN_2, LOW);
                  digitalWrite(RELAY_PIN_1, state? RELAY_ON : RELAY_OFF);
                  if (state)
                    relayTwoTimerStart = millis();
              • gaduG
                gaduG
                gadu
                Omg, works just perfect! Thanks alot!!
                • gaduG gadu
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  I got lucky I guess.
                  So, what are you doing with this then?
                  • gaduG
                    gaduG
                    gadu
                    @BulldogLowell
                    Well, the idea is actually simple. I have today a HTPC hidden on the other side of the livingroom wall (where the tv is). Both are connected to a Master (HTPC) and Slave (TV) power strip (are they called so?)
                    When I start the HTPC with a button the PC boots and and the power strip turns on the TV.
                    These are a bit pricey and now it has started to give me trouble, so why not let a cheaper arduino with two relays take care of it?
                    One relay starts the PC (toggle) and the other relay starts the TV. This gives me also the option to start the HTPC/TV remote as well using OpenHAB and MQTT.
                    Before shutting down the PC it can simply publish a command to turn off the TV using mosquitto_pub.
                    Perhaps not the most optimal solution, but it's simple which means a higher WAF as well ;)
                    Hope it made any sense... :)
                    • gaduG gadu
                      @BulldogLowell
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @gadu
                      String totalProjectSuccess = itWorks + wifeIsHappy;
