  3. [SOLVED] BME280 power consumtion
11 Posts 6 Posters 10.1k Views 5 Watching
    Maybe you could try the adafruit library and see if it works better
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      ok, i think the problem is solved, the example i was looking at is just wrong, the default mode is normal not forced so default configuration of the driver put in nornal mode not forced, changing the constructor values solves the problem.
      P C 2 Replies Last reply
      • rozpruwaczR rozpruwacz
        P
        P
        peerv
        @rozpruwacz
        Could you please share with me how you managed to get the power consumption of the BME280 down.
        Can this also be done with the Adafruit library?
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          You can checkout my code from github: https://github.com/mczerski/MyMultiSensorBME280. If you want to build this project remember pull also git submodule (git submodule init; git submodule update)
          P 1 Reply Last reply
            C
            C
            Craig Thom
            @rozpruwacz The big downside to using forced instead of normal is that you can't use the IIR filters, since they require relatively recent previous readings to work.
              P
              P
              peerv
              @rozpruwacz Thanks, very impressive solution!
                mickecarlsson
                Just add:
                BME280.writeMode(smSleep);                 // go to sleep, save battery
                After your have read the bme280, just before you call sleep().
                • M mickecarlsson
                  Just add:
                  P
                  P
                  peerv
                  @mickecarlsson What BME280 library are you using?
                    mickecarlsson
                    I am using this:
                    // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code,
                    // written originally by Embedded Adventures.
                    // https://github.com/embeddedadventures/BME280
                    #include <BME280_MOD-1022.h>```
                    alexsh1A 1 Reply Last reply
                    • M mickecarlsson
                      I am using this:
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @mickecarlsson I believe BME280.writeMode(smSleep); is not necessary.
                      Forced mode must be used. I think after taking the measurement the sensor goes back to sleep.
                      BME280.writeMode(smForced);
