  3. [SOLVED] BME280 power consumtion
11 Posts 6 Posters 10.0k Views 5 Watching
  • rozpruwaczR Offline
    rozpruwaczR Offline
    rozpruwacz
    Hi all,
    I'm using this library:
    https://github.com/finitespace/BME280
    to comunicate with this module:
    http://www.ebay.com.au/itm/I2C-SPI-Breakout-Temperature-Humidity-Barometric-Pressure-BME280-Digital-Sensor-/191736124959
    in my sketch i create the driver with this statement:
    BME280I2C bme;
    which acording to example sketch BME280_Modes.ino should result in 0.16 μA power consumtion but my bme280 module consumes almost 0.5mA in this mode ...
    has anyone any expirience with bme280 and know how much power it realy should consume ?
      Maybe you could try the adafruit library and see if it works better
        rozpruwaczR Offline
        rozpruwacz
        ok, i think the problem is solved, the example i was looking at is just wrong, the default mode is normal not forced so default configuration of the driver put in nornal mode not forced, changing the constructor values solves the problem.
        P C 2 Replies Last reply
        • rozpruwaczR rozpruwacz
          P Offline
          P Offline
          peerv
          @rozpruwacz
          Could you please share with me how you managed to get the power consumption of the BME280 down.
          Can this also be done with the Adafruit library?
            rozpruwaczR Offline
            rozpruwacz
            You can checkout my code from github: https://github.com/mczerski/MyMultiSensorBME280. If you want to build this project remember pull also git submodule (git submodule init; git submodule update)
            P 1 Reply Last reply
              C Offline
              C Offline
              Craig Thom
              @rozpruwacz The big downside to using forced instead of normal is that you can't use the IIR filters, since they require relatively recent previous readings to work.
                P Offline
                P Offline
                peerv
                @rozpruwacz Thanks, very impressive solution!
                • M Offline
                  M Offline
                  mickecarlsson
                  Just add:
                  BME280.writeMode(smSleep);                 // go to sleep, save battery
                  After your have read the bme280, just before you call sleep().
                  • M mickecarlsson
                    Just add:
                    P Offline
                    P Offline
                    peerv
                    @mickecarlsson What BME280 library are you using?
                    • M Offline
                      M Offline
                      mickecarlsson
                      I am using this:
                      // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code,
                      // written originally by Embedded Adventures.
                      // https://github.com/embeddedadventures/BME280
                      #include <BME280_MOD-1022.h>```
                      alexsh1A 1 Reply Last reply
                      • M mickecarlsson
                        I am using this:
                        alexsh1A Offline
                        alexsh1A Offline
                        alexsh1
                        @mickecarlsson I believe BME280.writeMode(smSleep); is not necessary.
                        Forced mode must be used. I think after taking the measurement the sensor goes back to sleep.
                        BME280.writeMode(smForced);
