[solved] raspberry gateway - installation problems (and more)
Hello!
I just tried to set up a raspberry gateway according to this https://www.mysensors.org/build/raspberry .
(on raspberry1). everything went smooth, but somehow it's not working:pi@MysensorPi:~/MySensors $ ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1pi@MysensorPi:~/MySensors $ sudo ./bin/mysgw Nov 10 22:35:30 INFO Config file /etc/mysensors.conf does not exist, creating new file. Nov 10 22:35:30 INFO Starting gateway... Nov 10 22:35:30 INFO Protocol version - 2.3.0 Nov 10 22:35:30 INFO EEPROM file /etc/mysensors.eeprom does not exist, creating new file. Nov 10 22:35:30 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,VER=2.3.0 Nov 10 22:35:30 DEBUG TSF:LRT:OK Nov 10 22:35:30 DEBUG TSM:INIT Nov 10 22:35:30 DEBUG TSF:WUR:MS=0 Nov 10 22:35:30 DEBUG !TSM:INIT:TSP FAIL Nov 10 22:35:30 DEBUG TSM:FAIL:CNT=1 Nov 10 22:35:30 DEBUG TSM:FAIL:DIS Nov 10 22:35:30 DEBUG TSF:TDI:TSLso now on i should ask here =)
i used one of these radios (recomendation from @gohan in 2017 :)): https://gearbest.com/transmitters-receivers-module/pp_453011.html and connected it accordingly (except i used 5v pin for VCC)
first of all i don't understand why it's not working when there were just top c&p a few lines?an then i'm not really sure in general what i need to do. what i WANT to do:
sensors > raspberry pi gateway > openhab controller
mosquitto is running on my openhab installation, so mqtt would be ok. i searched for a while, but i couldn't find anything noob-proved... -
Hello!
mosquitto is running on my openhab installation, so mqtt would be ok. i searched for a while, but i couldn't find anything noob-proved...Nov 10 22:35:30 DEBUG !TSM:INIT:TSP FAIL
This means the Raspberry Pi is unable to communicate with the radio module. The most common reason is a wiring problem. Could you post a few photos of the wiring (from different angles)? Maybe we can help spot a problem.
If you have more than one nrf24 module, see if switching helps to check if the radio is broken.
here's the wiring. i checked 3 times and now i rewired again with another nrf24 module - error remains the same:
oh boi. had to connect the radio to the board mentioned in the opening post:
and connect the other boards to my raspberry... now it seems to work! unfortunately i can't test it because i'm not able to upload anything to my Sensebender Micro boards. now i'm waiting for my new ftdi programmer :rage: -
alright! now with new programmer a was able to upload the "standard" sketch to my sensebender micro and the gateway even gets "something":
Nov 14 20:11:52 DEBUG TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0: Nov 14 20:11:52 DEBUG TSF:MSG:BC Nov 14 20:11:52 DEBUG TSF:MSG:FPAR REQ,ID=3 Nov 14 20:11:52 DEBUG TSF:PNG:SEND,TO=0 Nov 14 20:11:52 DEBUG TSF:CKU:OK Nov 14 20:11:52 DEBUG TSF:MSG:GWL OK Nov 14 20:11:52 DEBUG TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=O K:0 Nov 14 20:11:54 DEBUG TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 Nov 14 20:11:54 DEBUG TSF:MSG:PINGED,ID=3,HP=1 Nov 14 20:11:54 DEBUG TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st= OK:1 Nov 14 20:11:54 DEBUG TSF:MSG:READ,3-3-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFF FFFFFF0300 Nov 14 20:11:54 DEBUG GWT:TPS:TOPIC=mysensors-out/3/255/4/0/0,MSG SENT Nov 14 20:11:54 DEBUG TSF:MSG:READ,3-3-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 Nov 14 20:11:54 DEBUG TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st= OK:0100 Nov 14 20:11:54 DEBUG TSF:MSG:READ,3-3-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1 Nov 14 20:11:54 DEBUG GWT:TPS:TOPIC=mysensors-out/3/255/0/0/17,MSG SENT Nov 14 20:11:54 DEBUG TSF:MSG:READ,3-3-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0 Nov 14 20:11:54 DEBUG GWT:TPS:TOPIC=mysensors-out/3/255/3/0/6,MSG SENT Nov 14 20:11:56 DEBUG TSF:MSG:READ,3-3-0,s=255,c=3,t=11,pt=0,l=17,sg=0:Sensebend er Micro Nov 14 20:11:56 DEBUG GWT:TPS:TOPIC=mysensors-out/3/255/3/0/11,MSG SENT Nov 14 20:11:56 DEBUG TSF:MSG:READ,3-3-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.4 Nov 14 20:11:56 DEBUG GWT:TPS:TOPIC=mysensors-out/3/255/3/0/12,MSG SENT Nov 14 20:11:56 DEBUG TSF:MSG:READ,3-3-0,s=1,c=0,t=6,pt=0,l=0,sg=0: Nov 14 20:11:56 DEBUG GWT:TPS:TOPIC=mysensors-out/3/1/0/0/6,MSG SENT Nov 14 20:11:56 DEBUG TSF:MSG:READ,3-3-0,s=2,c=0,t=7,pt=0,l=0,sg=0: Nov 14 20:11:56 DEBUG GWT:TPS:TOPIC=mysensors-out/3/2/0/0/7,MSG SENT Nov 14 20:11:56 DEBUG TSF:MSG:READ,3-3-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2 Nov 14 20:11:56 DEBUG TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st= OK:1 Nov 14 20:11:56 DEBUG TSF:MSG:READ,3-3-0,s=1,c=1,t=0,pt=7,l=5,sg=0:24.7 Nov 14 20:11:56 DEBUG GWT:TPS:TOPIC=mysensors-out/3/1/1/0/0,MSG SENT Nov 14 20:11:56 DEBUG TSF:MSG:READ,3-3-0,s=2,c=1,t=1,pt=2,l=2,sg=0:55 Nov 14 20:11:56 DEBUG GWT:TPS:TOPIC=mysensors-out/3/2/1/0/1,MSG SENT Nov 14 20:11:56 DEBUG TSF:MSG:READ,3-3-0,s=255,c=3,t=0,pt=1,l=1,sg=0:88 Nov 14 20:11:56 DEBUG GWT:TPS:TOPIC=mysensors-out/3/255/3/0/0,MSG SENTis this right? and if so, how can i translate all this stuff? :eye:
ohhhhhhh. this makes sense:
[20:17:18] openhabian@openHABianPi:~$ mosquitto_sub -t mysensors-out/# 22.3 61cool cool. now i just have to figure out how to define my items on the openhab part!
cheers
