  3. 💬 EFEKTA Temp&Hum sensor(ver. nRF52 )+E-Ink display
nrf52832e-ink displaye-papernrf52nrf52810nrf52811nrf52840temperature & humidity sensor
105 Posts 11 Posters 35.2k Views 12 Watching
  • berkseoB berkseo
    @heinzv Yes, I plan to add one-tenth resolution.
    Convert numbers and letters to an array in C is simple. I use a program TheDotFactory. http://www.eran.io/the-dot-factory-an-lcd-font-and-image-generator/
    I would be glad if someone made his version of the software in the public domain.
    Please show photos of your assembled working device.
    H
    H
    heinzv
    wrote on last edited by heinzv
    #47
    @berkseo I found out, that I still miss two parts (from AE), everything else is there. So I started a testing with my development boards.
    I attach a picture of this setup. I use a CBYTE nRF52832 module, a SHT35 (SHT20 is not there and the 1uF capacitors for the bare e-paper displays) and a waveshare e-paper with PCB.
    I'm now out for two weeks and will then have my parts hopefully.
    The module on the right side is my BMP (black magic probe).
    berkseoB 1 Reply Last reply
    • H heinzv
      berkseoB
      berkseoB
      berkseo
      @heinzv said in 💬 EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
      CBYTE nRF52832
      I have a question for you, teach:). Do you use CBYTE nRF52832 and Arduino IDE? I was unable to run these modules. How did you manage that? Did you add inductance to the circuit? I assembled my own nRF52 modules according to the scheme DC-DC from Datasheet (I needed a module on components of size 0603 and 0805 for convenient soldering), the scheme worked and the device is perfectly stitched through the ARDUINO IDE
      https://www.youtube.com/watch?v=hXmxzo0OiMs
      • H
        H
        heinzv
        #49
        @berkseo (update): What kind of probems did you face? Why have you been unable to run this modules in the Arduino? Did you have problmes to upload the sketch?
        Maybe you had the problem, that the modules are not detected during upload!
        I had the same problem and the EBYTE E73 nRF52832 modules are locked by factory and thus not detected by the IDE's. You can unloack them with nRF Go studio, nrfutil (or nrfprog) and do a mass erase. In nRF Go studio you might require a J-Link programmer, you can olaso unlock it with openocd with a simple cheap ST-Link adapter.
        openocd -s $OPENOCD/tcl -f interface/stlink-v2.cfg -f target/nrf52.cfg -c init -c "reset init" -c halt -c "nrf52 mass_erase" -c "program $FIRMWARE verify" -c reset -c exit
        I typically use the nRF52 modules with my selfmade Black Magic Probe (1.60), which is supported by Arduino IDE.
        The EBYE modules have all the Nordic reference design parts soldered. So nothing else is required (no coils etc.)
        Here are my two modules which work:
        I found this breakout boards for the E73 module here
        https://oshpark.com/shared_projects/q4weF4UL
        The other module were designed by ranseyer and myself
        let me know if you have more questions
        • H heinzv
          berkseoB
          berkseoB
          berkseo
          nRF Go studio
          How do I unlock (if locked) E73 with nRF Go studio ? What should be done, what actions?
          1. Connect E73 to J-Link
          2. Connect J-Link to the USB port of the computer
            3.??
            4.??
          H 1 Reply Last reply
          • berkseoB berkseo
            nRF Go studio
              3.??
              4.??
            H
            H
            heinzv
            #51
            @berkseo you have to connect your E73 module with a J-Link adapter, if the adapter is recognized by nRFgo Studio, the nRFx Programming will be enabled (turn from grey to black) and then you can select "Recover" (only shown if you have a locked device). You should do then also a "Erase all").
            Again, it only works with a Segger compatible J-Link adapter. Do you have one? It is anyhow recommended if you want to use Segger Embedded Studio (required for using the nRF52840 and the newest 15.2 SDK).
            The other/second method could work with a ST-Link or black magic probe (a 2€ clone can do it, I created a couple of them) and with openocd.
            The unlock screen look like this, if you have a locked or no device connected but a valied J-Link adapter
            And after recover, you get a screen like this to erase or flash a program
            • H heinzv
              berkseoB
              berkseoB
              berkseo
              #52
              @heinzv
              Thanks for the tips, very hard to find information. I have a pair of j-link adapters. There are also several different clones of st-link v2. (but I don't have a linux machine now.) I'll try nRFgo Studio tomorrow. Earlier I wrote that I assembled my Assembly nRF52832 (dc-dc), no problems in the Arduino IDE(chips in the ribbon, see the link below). So I thought that the E73 modules do not work because of a slightly different circuit (see photo without cover) in the circuit no inductance on the DCC pin and no connection outputs through inductance to the DEC4 pin.
              https://ru.aliexpress.com/item/Free-shipping-NRF52832-QFAA-NRF52832-QFAA-R-N52832-NRF52832-5pcs-lot-100-NEW-and-ORIGINAL/32828951084.html?spm=a2g0v.10010108.1000016/B.1.10a9e326lCcYJ6&isOrigTitle=true
              • berkseoB berkseo
                @heinzv
                H
                H
                heinzv
                @berkseo I have updated my post above with an additiona picture.
                You can do all on Windows (I mostly use Windows 10 x64). I sometimes use Linux like for creating the BMP clones. I'm using the latest Mint version in a VMware VM.
                Let me know if you need more infos ...
                BTW: I was further working on the own created nRF52832 PCB's with ePaper (I have many E73 modules left) and will start soldering the PCB's I have ordered from you if all parts are there (most of thema are).
                The one ordered soldered module is still in transit (or I did not get it so far).
                Below another picture of the ePaper output. I have tested the idea with two fonts: The larger one for the non decimals and a smaller one for the decimal. I'm using the GxEPD standard e-Paper library in my latested sketch, as it's easier to use, has more fonts und is ready for more ePaper modules/sizes.
                It is just an intermediate state (batter symbol, larger font missing etc.).
                berkseoB 2 Replies Last reply
                • H heinzv
                  berkseoB
                  berkseoB
                  berkseo
                  It's great, I am very glad that you are doing the further development of this direction.
                  • berkseoB
                    berkseoB
                    berkseo
                    #55
                    Making your characters is easy.
                    .. Absolutely any font, you are limited only by the memory capabilities of the nRf52. .. And it makes no sense to store all the characters if you need only numbers, it saves space very well.
                    • H heinzv
                      berkseoB
                      berkseoB
                      berkseo
                      #56
                      I have not sent it to you yet, I have a problem with China, I am still waiting for new modified boards, I want to send you the latest version, please wait, do not cancel the order. I will also add new PCBs to the package (there are no changes in the components and numbering, just placed differently)
                      The device has become thinner, less in height, all electronic components have been removed from the side of the batteries, and PCB have been prepared for mounting in the case.
                      • berkseoB berkseo
                        H
                        H
                        heinzv
                        @berkseo Thanks, very good modifications. I'll wait patiently :-) I'll then not use the 5 + 5 PC's and eait for the new ones.
                        Do I understand you right, that I'll receive another 5 + 5 updated PCB's without additional money charged? That would be great (if required I can send you additional €'s or US$).
                        Thanks for the font-hints. I'll test it once I'm back from my BIZ-trip.
                        • berkseoB
                          berkseoB
                          berkseo
                          #58
                          @HEINZV Thanks for the clues. Now all modules are programmed in the Arduino IDE. Absolutely all modules - https://youtu.be/J0M2vgW--FM
                          Truth were nuances. Had to remove all the drivers for J-LINK, remove nRF GO. Then I installed the j-LINK Windows v640 drivers. Then again I installed nRF GO. And the most important point when installing nRF GO refuse to install drivers for J-LINK. nRF GO works with both my Chinese j-LINK clones :)
                          • H
                            H
                            heinzv
                            @berkseo glad to hear, that it worked.
                            I'm meanwhile working on the sketch for the Tem & Hum sensor node. As written, I've switched to the GxEPD e-Paper library. It is easier to use and is installable via the Arduino Studio or via platform.io.
                            I've evaluated a lot of fonts and have finally found one I like and which fits to the display even with the decimals. I used the fontconvert from the GxEPD lib which can convert any TTF or OTF font.
                            Here is a picture (I'm still using the MySesnors PCB from ranseyer waiting for the new PCB's from you)
                            • H heinzv
                              berkseoB
                              berkseoB
                              berkseo
                              @heinzv Finally got the PCB. Soon I will send the finished device.
                              1_1543170753492_F436A79B-4D32-458F-BDBB-1CB435D7668B.jpg 0_1543170753492_805C0A8F-BB55-497D-B063-431C1D2E5687.jpg
                              • berkseoB berkseo
                                H
                                H
                                heinzv
                                @berkseo good to hear. And you also mentioned to send some new PCB'
                                s? Let me know if I had to pay something additional.
                                • berkseoB
                                  berkseoB
                                  berkseo
                                  #62
                                  The second revision of the device is ready, the tests are passed. Added cutouts and holes on the power Board for mounting in the case. Transferred inductance of the display (680), made a cut for her on the power PCB. All this slightly reduced the size of the device, now the size of 36mm x 52mm (old size 36mm x 54mm). The down-converter moves to the other side of the power PCB.
                                  • H heinzv
                                    berkseoB
                                    berkseoB
                                    berkseo
                                    @heinzv The device and additional PCB are shipped.
                                    • H
                                      H
                                      heinzv
                                      @berkseo looks very good, very professional work. I'll solder a few devices once I get the new PCB's and will also work further on my version of the firmware. It works already quite nice (transfering float values and showing decimals).
                                      Attached the picture of a working pair of a sensor node (using my PCB's) and a SHT31 and a nRF52 serial gateway.
                                      • H
                                        H
                                        heinzv
                                        #65
                                        @berkseo I've got your Temp/Hum sensor today and the PCB's (3+3). Since I have ordered the cr2477 batteries and your batterholder takes only the cr2450, I've tried it with the program adapter and USB power. It works. Thanks. I have ordered now additional cr2450 batteries.
                                        I took the batteryholder form your list and they are for the cr2477!
                                        Then I soldered my own first two PCB's, the battery PCB and the Sensor PCB. It took me quite a while (3 hours at least). It's nothing for beginners (but I not a beginner :-) )
                                        However during my testing, I found my battery PCB working and the sensor node runs the MYSensors part and the LED blinks but the E-Paper does not work and also the SHT20 returns 998 for temp and hum.
                                        I have not found the C12 capacitor in your parts decription list, but only a C14 (which is not printed on the PCB) with 10uF. So I assumed the C12 = 10uF. I have seached the page and there is no C12.
                                        One the other hand, I have not found C14 on the new PCB. Maybe it's below C13 and no part print on PCB? The C13 is larger then the pads below, so it's confusing.
                                        Maybe you can update/correct it on openhwardware, so that I can solder it correct.
                                        So looking for the problems with e-paper and SHT20: A schematic diagram would really really help me, otherwise I'm lost. Please provide it (or at least via a PM?).
                                        Would it be possible to get it? If you have e.g. an Eagle project (schematics and board).
                                        It was really essential, that you provided the programm adapter for the tiny SWD connector. Thanks for that!
                                        here are my soldered PCB's:
                                        • H heinzv
                                          berkseoB
                                          berkseoB
                                          berkseo
                                          #66
                                          Then I soldered my own first two PCB's, the battery PCB and the Sensor PCB. It took me quite a while (3 hours at least). It's nothing for beginners (but I not a beginner )
                                          I have not found the C12 capacitor in your parts decription list, but only a C14 (which is not printed on the PCB) with 10uF. So I assumed the C12 = 10uF. I have seached the page and there is no C12. All capacitors are ceramic.
                                          There are 3 types of battery holders, I make ready-made devices only on 2450, it is optimal, 2477 very high, the device in the case turns out to be disproportionate.
                                          I solder for about half an hour:). Judging by the description of your problems, it's all about soldering. Solder the temperature sensor and the connector for the display should be a Hairdryer and solder paste. This is by the way perhaps the two most difficult procedures at home.
                                          C13 is a capacitor from 47mf to 200mf, I added it later. C14 is a 0.1 mf capacitor. C12 is a capacitor on the display inductance input, it should be from 4.7 mf to 10mf.
                                          Full schemes there is no, there is only parts of. I have this project done right in the program for PCB layout. But I understand that this is becoming a problem, and I will add the scheme to the project in the near future. Sorry, I know I should have done this a long time ago :((.
                                          You wrote a post last year :), I with the holidays just gave all that up. How you're doing now. Were you able to find a problem with the display and the temperature sensor?
