  3. Misol rain gauge tipping bucket rain amount
8 Posts 5 Posters 4.2k Views 4 Watching
  • ร Offline
    ร Offline
    รอเรือ
    wrote on last edited by รอเรือ
    Has someone measured what amount of rain one "tip" of the tipping bucket of the MISOL rain gauge corresponds to? It would be great to know so I can calibrate my scripts.
    EDIT: I found this article that suggests it should be 0.0161 inches which is 0.40894 mm.
    EDIT2: Another source is suggesting 0.2794 mm.
    EDIT3: packetrat is suggesting 83.82 pulses per inch which should be 0,303030303 mm
    • hekH Offline
      hekH Offline
      This guy:
      https://pi.gate.ac.uk/posts/2014/01/25/raingauge/
      have calculated it to 0.2794 mm per tip.
      ร 1 Reply Last reply
        This guy:
        ร Offline
        ร Offline
        รอเรือ
        @hek Thanks! I just saw that while editing my first post. It sounds a little bit low.
        • hekH Offline
          hekH Offline
          Maybe you should do some tests to see if it is looks resonable.
            ร Offline
            ร Offline
            รอเรือ
            @hek
            I let 1126-202 grams water slowly flow into the 55 cm2 gauge and it generated 475 tips.
            That gives me 0.3537 mm/tip. I'll go with that. :relaxed:
            • Z Offline
              Z Offline
              zimzim
              What script did you use to test Misol Rain Gauge tipping bucket.
              Finding a tutorial/testing for it proves to be difficult i'm not sure where to put the red and green wires into as well
              • P Offline
                P Offline
                pkkrusty
                Old topic, but my test shows .304mm per tip. I calculated the surface area as 54.7854cm^2, which is 5cm x 11cm minus the small rounded corners. I slowly poured 60cc water and counted 36 tips. Thus, spread out over the whole surface, I poured 1.09518cm of water, divided by 36 tips equals .3042173mm per tip.
                YoshuY 1 Reply Last reply
                • P pkkrusty
                  YoshuY Offline
                  YoshuY Offline
                  Yoshu
                  11.9k
                  113.3k
