  3. Gateway <-> Motion Sensor doesn't work
3 Posts 2 Posters 842 Views 2 Watching
  • T
    tiziano venceslao santambrogio
    Hi everyone
    I uploaded the GatewayESP8266MqttClient sketch on wemos D1Mini, changing AP and MQTT server and MotionSensor on an Arduino nano without changing any data.
    Now, between the 2 devices it seems that they do not exchange information.
    Can someone tell me where I'm wrong? I tried to change other settings (MY_RF24_CHANNEL, MY_RF24_DATARATE, MY_RF24_PA_LEVEL ...) but it does not change anything.
    Debug Sensor:
    724796 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    726803 !TSM:FPAR:NO REPLY
    726805 TSM:FPAR
    726836 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    728843 !TSM:FPAR:NO REPLY
    728845 TSM:FPAR
    728876 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    730883 !TSM:FPAR:FAIL
    730885 TSM:FAIL:CNT=7
    730887 TSM:FAIL:DIS
    730889 TSF:TDI:TSL
    790891 TSM:FAIL:RE-INIT
    790893 TSM:INIT
    790899 TSM:INIT:TSP OK
    790902 TSF:SID:OK,ID=100
    790904 TSM:FPAR
    790935 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    792942 !TSM:FPAR:NO REPLY
    792944 TSM:FPAR
    792975 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    794982 !TSM:FPAR:NO REPLY
    794984 TSM:FPAR
    795015 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    797022 !TSM:FPAR:NO REPLY
    797024 TSM:FPAR
    797054 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    799062 !TSM:FPAR:FAIL
    799064 TSM:FAIL:CNT=7
    799066 TSM:FAIL:DIS
    799068 TSF:TDI:TSL
    Debug Gateway:
    8125 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    scandone
    state: 2 -> 2 (b0)
    8229 GWT:TPC:CONNECTING...
    8757 GWT:TPC:CONNECTING...
    state: 2 -> 0 (2)
    reconnect
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 10
    cnt
    connected with NETGEAR, channel 3
    dhcp client start...
    9285 GWT:TPC:CONNECTING...
    ip:192.168.0.63,mask:255.255.255.0,gw:192.168.0.1
    9476 GWT:TPC:IP=192.168.0.63
    9506 MCO:BGN:STP
    9524 MCO:BGN:INIT OK,TSP=1
    9553 GWT:TPC:IP=192.168.0.63
    9584 GWT:RMQ:MQTT RECONNECT
    9633 GWT:RMQ:MQTT CONNECTED
    9663 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    pm open,type:2 0
    905682 TSF:SAN:OK
    • T tiziano venceslao santambrogio
      Hi everyone
      Debug Sensor:
      726805 TSM:FPAR
      728845 TSM:FPAR
      730887 TSM:FAIL:DIS
      730889 TSF:TDI:TSL
      790893 TSM:INIT
      790904 TSM:FPAR
      792944 TSM:FPAR
      794984 TSM:FPAR
      797024 TSM:FPAR
      799066 TSM:FAIL:DIS
      799068 TSF:TDI:TSL
      Debug Gateway:
      scandone
      state: 2 -> 2 (b0)
      state: 2 -> 0 (2)
      reconnect
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 10
      cnt
      9506 MCO:BGN:STP
      pm open,type:2 0
      905682 TSF:SAN:OK
      Hi @tiziano-venceslao-santambrogio, welcome to the forum.
      If you haven't already, see https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for how to troubleshoot the most common problems. Unstable power is the most common cause of communication problems. What capacitors are you using?
      It would also be great if you could include the first lines of the debug logs. They contain i formation on which settings the nodes are using.
      • T
        Thanks and congratulations for the great site.
        I put a 10uF capacitor in parallel of both modules.
        Below the initial part of the sensor and then the total strings of the gateway (the gateway after these strings does not print any other data)
        Debug Sensor:
        16 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
        26 TSM:INIT
        27 TSF:WUR:MS=0
        33 TSM:INIT:TSP OK
        35 TSM:FPAR
        37 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2046 !TSM:FPAR:NO REPLY
        2049 TSM:FPAR
        2051 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        4058 !TSM:FPAR:NO REPLY
        4060 TSM:FPAR
        4062 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        6069 !TSM:FPAR:NO REPLY
        6071 TSM:FPAR
        6073 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        8080 !TSM:FPAR:FAIL
        8081 TSM:FAIL:CNT=1
        8083 TSM:FAIL:DIS
        8085 TSF:TDI:TSL
        18087 TSM:FAIL:RE-INIT
        18089 TSM:INIT
        18096 TSM:INIT:TSP OK
        18098 TSM:FPAR
        18100 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        20108 !TSM:FPAR:NO REPLY
        20110 TSM:FPAR
        20112 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        22120 !TSM:FPAR:NO REPLY
        Debug Gateway:
        Ž@lðhà,LJ¬ðCXа47 MCO:BGN:INIT GW,CP=RNNGE---,REL=255,VER=2.3.1
        98 TSF:LRT:OK
        113 TSM:INIT
        127 TSF:WUR:MS=0
        150 TSM:INIT:TSP OK
        scandone
        state: 0 -> 2 (b0)
        200 TSM:INIT:GW MODE
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 7
        cnt
        337 TSM:READY:ID=0,PAR=0,DIS=0
        370 MCO:REG:NOT NEEDED
        396 TSM:READY:NWD REQ
        2678 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        scandone
        2762 GWT:TPC:CONNECTING...
        3290 GWT:TPC:CONNECTING...
        3818 GWT:TPC:CONNECTING...
        4346 GWT:TPC:CONNECTING...
        4374 GWT:TPC:IP=192.168.0.63
        4405 MCO:BGN:STP
        4423 MCO:BGN:INIT OK,TSP=1
        4451 GWT:TPC:IP=192.168.0.63
        4482 GWT:RMQ:MQTT RECONNECT
        4541 GWT:RMQ:MQTT CONNECTED
        4571 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
        pm open,type:2 0
