  3. Minimal design thoughts
299 Posts 34 Posters 272.2k Views 17 Watching
  • AnticimexA Anticimex
    @tbowmo I don't remember. But I got at least three (don't think I requested more since at the time I was not sure it would meet my personal demands, nor if the MySensors community would accept it). Since it is now kind of "official" I guess it has :)
    tbowmoT
    tbowmoT
    tbowmo
    ok, I'll try and get some samples then.
    Has there been any work done to support easy initialization of the keys on new devices?
    AnticimexA 1 Reply Last reply
    • tbowmoT tbowmo
      AnticimexA
      AnticimexA
      Anticimex
      @tbowmo That's already done. Available in development branch. I will update it to support devices without UART in the near future. Check libraries/sha204/examples/sha204_personalizer
      Auto-generation of keys is supported as well as manually contributed ones (all devices in the same environment needs to share a key). All necessary personalization for MySensors usage is done (default settings are fine) and locking of both configuration and data sections are suppored (only configuration section is mandatory to lock).
      • tbowmoT
        tbowmoT
        tbowmo
        @Anticimex
        It's wit a separate sketch, right? Can we do anything in the protocol for key initialization? So when a device asks for a node Id it could also get the shared key supplied via radio?
        I am thinking about creating a plug and play ready unit, with a preloaded sensor sketch from the factory in China, would be nice if people had an easy method of initializing things without reloading other sketches
        • tbowmoT tbowmo
          @Anticimex
          AnticimexA
          AnticimexA
          Anticimex
          @tbowmo short answer: no. Sending the key in clear text is out of the question. That is totally not secure. The whole idea with that circuit is that the key is prestored and hidden. Technically it is possible but then one also has to work around the payload size limitation in the rf protocol.
          • tbowmoT
            tbowmoT
            tbowmo
            @Anticimex
            I know that there are some gotcha's with cleartext key transfer.. But I thought thata if output power is set to lowest value in the GW, and key transfers only could be done while in discovery mode. Then the risk of anyone snooping it, is lower..
            Going into "easy initialize thinking mode" :d
            • tbowmoT tbowmo
              @Anticimex
              AnticimexA
              AnticimexA
              Anticimex
              @tbowmo I do understand what you seek. However.
              1. If we do accept the added cost in memory use and component cost (and development effort) of using a strong authentication hardware, it makes no sense throwing it all away by implementing its use in an insecure way (although the common man probably won't be able to compromise it).
              2. I have already made one big sacrifice in allowing truncated signatures (or we would have to implement a framing protocol for sending >32 byte messages).
              3. I am not going to implement a signing scheme which I would be able to hack myself.
              Basically, my ambition with the signing is not a "low risk" of hacking. it is a "no" risk of hacking. (with the reservation of the truncated signature as mentioned above). Signatures will be inversely proportional to the complexity of the message. Signature size = 32-7-<payload size>-1 byte. In other words, the maximum possible signature size for a 1-byte message is 23 bytes. But I do think HMAC-256 is still a bitch to hack even if a portion of it is sliced off.
              Also, how do you prevent an attacker from issuing its own keys by resetting the HW in some way? And besides, all users have to program their devices for them to do anything at all. Doing the ATSHA204 personalization is a one-time effort, and adds quite little work and I see no reason why it would not be possible to do this by OTA either if one preferred to do that. The configurations and keys are permanently stored on the devie in EEPROM. So the personalization is only executed once on every security-enabled device.
              I think we need to save as much space as possible so having all nodes drag around the logic to do key replacement will add a memory cost in itself. And if you take security really seriously, you do want to lock down the fused key as well. Atmel is quite fuzzy about what security can be guaranteed if the data section is not locked so I am not sure if key readout is prevented with data unlocked even if configuration forbids it. The datasheet is not clear on that.
              The idea is:
              You deploy a gateway that has the ability to sign (and verify) messages. You personalize the ATSHA device on your gateway with some personal secret key. The personalization sketch allows you to randomize that key if desired.
              You take the sketch and store the generated key in it and tucks it away. For every node you want to add, you download and execute the personalization once. And then your done with that. It will from there on be able to exchange signed messages with your gateway until you either revoke the key in the gateway (reprogram it if data is unlocked or replace it and change the key in the new device).
              In my opinion, a one-time initialization is not that difficult. But perhaps my sketch is complex, I welcome feedback on that topic. I have tried to explain the expected usage in the comments in the sketch header.
              My personal opinion on the security matter: We do it properly or we skip it. Every user ultimately decides by them self if they want security in their sensor network. And if they do go for it, it should be trustworthy.
                Let's continue the discussion in the security thread.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @hek
                  Yes.. forgot about that.. :)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    sample order is sent for the atsha204 chips.. Hope it will go through at atmel..
                    I could only order 3 samples in total.. But that should be enough for checking that everything is working, and for sending one off to manufacturer in China.
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      Figners crossed that the chinese dont muck it up :)
                      Let me know if you need assistance in verifying the ATSHA on the prototype. I have one hooked up to my PC for debugging purposes, prepared and confguration locked for MySensors usage.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Anticimex
                        My plan is to just run your test code, to verify that i can talk to the device. Just like i did with the external Flash chip.
                        • tbowmoT tbowmo
                          @Anticimex
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @tbowmo
                          Alright. Just so you know, I have not adapted it for your board pinout yet. I will change my breadboard prototype accordingly and retest when I implement the non-UART support in the personalizer. I hope to be finished with that before you get your samples.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            #183
                            Hmm.. I like dirtypcbs "honest" approach to things:
                            Hey Thomas Mørch,
                            Your PCB order number xxxxx has been shipped.
                            If you used DHL/FEDEX/UPS a tracking number will be sent later. We hope it is provided within 48hours, but our logistics company is being painfully slow with updates and provides incorrect numbers. We fired them, and will start working directly with DHL October 1st, 2014.
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              I'm going to enjoy this ^^
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @Anticimex
                                :) The whole site of dirtypcbs are made up like that, trash talking their own product.. But so far the service has been ok from them. This is first time I ordered with express shipment, hopefully they'll arive later this week..
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @tbowmo said:
                                  dirtypcbs
                                  Well, for a site that in their website footer prints
                                  "No bull, just crappy PCBs"
                                  what can possibly go wrong :D
                                  RJ_MakeR 1 Reply Last reply
                                    @tbowmo said:
                                    dirtypcbs
                                    RJ_MakeR
                                    RJ_MakeR
                                    RJ_Make
                                    @Anticimex said:
                                    @tbowmo said:
                                    dirtypcbs
                                    LOL
                                    RJ_Make
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Anticimex
                                      Just received the tracking number.. (so it took them 2 days to go from the factory to the shipping company :))
                                      Anyway, now I have a tracking number, so I can keep an eye on things :)
                                      • tbowmoT tbowmo
                                        I'm thinking about spinning up the good old eagle cad program again, and start creating sensor boards (Like so many others here :))
                                        Only thing is, that unlike (almost) everyone else, that are using normal arduino micro boards, I'm thinking about skipping that part, and create my "own" arduino board, thinking about the following:
                                        1. use atmega 328 tqfp (That's doable for home soldering :))
                                        2. pads for a 32Khz crystal, for timing purposes
                                        3. Standard atmel programming header.
                                        4. ftdi header like on arduino mini, so could use arduino bootloader (could be some details about the baudrate though, as it's running off internal RC oscillator)
                                        5. Using Si7021 integrated humidity / temperature sensor, footprint for bmp180 barometric sensor
                                        6. skip power converters, run everything off a battery directly (disable brownout detection in atmel)
                                        7. SPI flash / e2prom onboard. Using same connections as moteino from lowpowerlabs, so should be able to use same bootloader for updates to firmware
                                        8. pinheader for connecting radio module
                                        9. Pinheader for D3-D7 on one side, and SDA/SCL + A0/A1 and power on the other side
                                        10. Formfactor is 30x17.5mm (almost same size as the NRF24 module).
                                        11. ATSHA204A sot23 footprint on board (Connected to A3). Can be used for SHA256 key exchange and verification
                                        12. status LED (on A2)
                                        Any thoughts about this? Or should I wait for the all in one mysensors battery sensor board? (When will that be available?)
                                        / Thomas
                                        (Spec updated January 28th, 2015)
                                        C
                                        C
                                        CodeIt
                                        @tbowmo Since Domoticz (home automation software) got support for MySensors i have been looking for cool sensors. I want to place a MySensor node in every room in my house with temp/humidity motion and reed contact, run directly from battery. Your board looks very promising. I only have one question. Is it possible to have two interrupts (for the motion sensor and reed contact)?
                                        hekH 1 Reply Last reply
                                        • C CodeIt
                                          wrote on last edited by hek
                                          #190
                                          @CodeIt
                                          D2 is connected to radio socket IRQ pin.
                                          But as it currently not used by the library you could just cut the leg on radio and connect it to whatever you want.
