  3. Sensor required to detect PVC insulated COPPER wire
14 Posts 5 Posters 3.3k Views 5 Watching
  • H
    H
    hard-shovel
    wrote on last edited by hard-shovel
    If the mesh moves at constant speed, How about a simple optical IR Sensor (break beam or Reflective), then checking pulse width of signal to detect mesh vs cable. Otherwise synchronize pulse width detection ratio in correlation to mesh speed.
    Similar to this
    Y 1 Reply Last reply
    • bjacobseB
      bjacobseB
      bjacobse
      Or create a metal detector, that will detect every copper wire that passes below the sensor.
      What is important is to ensure a good reliability, so you are getting results that is reliable. Both IR detector and metal detector should be usable for you
      https://circuitdigest.com/microcontroller-projects/arduino-metal-detector-circuit-code/
      https://www.allaboutcircuits.com/projects/metal-detector-with-arduino/
      • K
        K
        kimot
        Try inductive proximity sensor. It can detect Cooper with 0.25 - 0.5 sensitivity compared to steel. By the way I think we can see one of this on top side of your picture.
          MrRobots
          If the copper loop is continuous (it looks like it is), inject a small RF (mW) signal on the wire (at the feed end of the mesh) and place the complement detector under the final end.
          • M MrRobots
            Y
            Y
            yemesvee
            @mrrobots Thanks for the reply. I don't have much knowledge about injecting RF signal. Please give me more inputs.
            • Y
              Y
              yemesvee
              @kimot thanks for the reply. Yes we have tried with 30mm sensing range inductive proximity sensor... It's not working on copper.
              bjacobseB 1 Reply Last reply
              • Y yemesvee
                bjacobseB
                bjacobseB
                bjacobse
                @yemesvee
                Then another approach you can count rotations on one of the drums, add a magnet to the drum, and use a reed relay as sensor.
                then you have to manually calibrate, measure pulses until you have reach 1 loop.
                then re-check count pulses until you have reached 10 loops. just to ensure you have measured correctly.
                you can use this sketch as a start
                https://www.mysensors.org/build/binary
                • H hard-shovel
                  Similar to this
                  Y
                  Y
                  yemesvee
                  @hard-shovel Thanks for the reply. The Ir sensor will detect both mesh and copper wire. How to count the no. of copper wire loops?? I don't understand..Can you please elaborate...
                  H 1 Reply Last reply
                  • bjacobseB bjacobse
                    @yemesvee
                    Y
                    Y
                    yemesvee
                    @bjacobse Thanks for the reply. I want to count no. of copper wire loops only. Because the distance between loops varies.
                    • K
                      K
                      kimot
                      Color sensor?
                      color sensor
                      • K
                        K
                        kimot
                        But I still think, that using opto detection will be easy possible.
                        For example photo resistor has got large area for receiving light and mesh will not cover it completely.
                        But wire almost does.
                        So signal level from photoresistor differ for mesh and wire and you can measure it by software or set analog comparator trigger level.
                        Experimet with D, L1 and L2
                        https://en.wikipedia.org/wiki/Photoresistor
                        1_1546419957383_IMG_20190102_100018.jpg 0_1546419957381_IMG_20190102_095905.jpg
                        • Y yemesvee
                          H
                          H
                          hard-shovel
                          @yemesvee
                          If using a digital sensor mounted as per Kimot diagram you will receive a pulse stream, check the width of the pulsed to find if mesh or cable.
                          use the function pulseIn to determine the pulse width.
                          The simple example of the time duration of a pulse
                          int SensorPin = 3;
                          unsigned long duration = 0;
                          unsigned long CableDuration = 100;     // Set to suitable value
                          unsigned long CableCount = 0;
                            pinMode(SensorPin , INPUT);
                            duration = pulseIn(SensorPin , HIGH);
                            Serial.print("Duration  : ");
                            Serial.println(duration);
                            if (duration >= CableDuration) {
                              ++ CableCount;
                              Serial.print("Cable detection  :");
                              Serial.println(CableCount);
                          K 1 Reply Last reply
                          • H hard-shovel
                            @yemesvee
                            int SensorPin = 3;
                                ++ CableCount;
                            K
                            K
                            kimot
                            wrote on last edited by kimot
                            @hard-shovel
                            But mesh is on other direction too - parallel with movement and sure not still at the same position and pure parallel.
                            So digital signal can be generated longer time than you expected.
