  3. Sensor required to detect PVC insulated COPPER wire
14 Posts 5 Posters 2.9k Views 5 Watching
  • Y Offline
    Y Offline
    yemesvee
    please see picture, the wire lies under Fibre glass mesh, When the mesh moves I have to count no.off copper wire loops. Please suggest suitable sensor.
    • H Offline
      H Offline
      hard-shovel
      wrote on last edited by hard-shovel
      If the mesh moves at constant speed, How about a simple optical IR Sensor (break beam or Reflective), then checking pulse width of signal to detect mesh vs cable. Otherwise synchronize pulse width detection ratio in correlation to mesh speed.
      Similar to this
      Y 1 Reply Last reply
      • B Offline
        B Offline
        bjacobse
        Or create a metal detector, that will detect every copper wire that passes below the sensor.
        What is important is to ensure a good reliability, so you are getting results that is reliable. Both IR detector and metal detector should be usable for you
        https://circuitdigest.com/microcontroller-projects/arduino-metal-detector-circuit-code/
        https://www.allaboutcircuits.com/projects/metal-detector-with-arduino/
        • K Offline
          K Offline
          kimot
          Try inductive proximity sensor. It can detect Cooper with 0.25 - 0.5 sensitivity compared to steel. By the way I think we can see one of this on top side of your picture.
          • M Offline
            M Offline
            MrRobots
            If the copper loop is continuous (it looks like it is), inject a small RF (mW) signal on the wire (at the feed end of the mesh) and place the complement detector under the final end.
            • M MrRobots
              Y Offline
              Y Offline
              yemesvee
              @mrrobots Thanks for the reply. I don't have much knowledge about injecting RF signal. Please give me more inputs.
              • Y Offline
                Y Offline
                yemesvee
                @kimot thanks for the reply. Yes we have tried with 30mm sensing range inductive proximity sensor... It's not working on copper.
                B 1 Reply Last reply
                • Y yemesvee
                  B Offline
                  B Offline
                  bjacobse
                  @yemesvee
                  Then another approach you can count rotations on one of the drums, add a magnet to the drum, and use a reed relay as sensor.
                  then you have to manually calibrate, measure pulses until you have reach 1 loop.
                  then re-check count pulses until you have reached 10 loops. just to ensure you have measured correctly.
                  you can use this sketch as a start
                  https://www.mysensors.org/build/binary
                  • H hard-shovel
                    Similar to this
                    Y Offline
                    Y Offline
                    yemesvee
                    @hard-shovel Thanks for the reply. The Ir sensor will detect both mesh and copper wire. How to count the no. of copper wire loops?? I don't understand..Can you please elaborate...
                    H 1 Reply Last reply
                    • B bjacobse
                      @yemesvee
                      Y Offline
                      Y Offline
                      yemesvee
                      @bjacobse Thanks for the reply. I want to count no. of copper wire loops only. Because the distance between loops varies.
                      • K Offline
                        K Offline
                        kimot
                        Color sensor?
                        color sensor
                        • K Offline
                          K Offline
                          kimot
                          But I still think, that using opto detection will be easy possible.
                          For example photo resistor has got large area for receiving light and mesh will not cover it completely.
                          But wire almost does.
                          So signal level from photoresistor differ for mesh and wire and you can measure it by software or set analog comparator trigger level.
                          Experimet with D, L1 and L2
                          https://en.wikipedia.org/wiki/Photoresistor
                          1_1546419957383_IMG_20190102_100018.jpg 0_1546419957381_IMG_20190102_095905.jpg
                          • Y yemesvee
                            H Offline
                            H Offline
                            hard-shovel
                            @yemesvee
                            If using a digital sensor mounted as per Kimot diagram you will receive a pulse stream, check the width of the pulsed to find if mesh or cable.
                            use the function pulseIn to determine the pulse width.
                            The simple example of the time duration of a pulse
                            int SensorPin = 3;
                            unsigned long duration = 0;
                            unsigned long CableDuration = 100;     // Set to suitable value
                            unsigned long CableCount = 0;
                              pinMode(SensorPin , INPUT);
                              duration = pulseIn(SensorPin , HIGH);
                              Serial.print("Duration  : ");
                              Serial.println(duration);
                              if (duration >= CableDuration) {
                                ++ CableCount;
                                Serial.print("Cable detection  :");
                                Serial.println(CableCount);
                            K 1 Reply Last reply
                            • H hard-shovel
                              @yemesvee
                              int SensorPin = 3;
                                  ++ CableCount;
                              K Offline
                              K Offline
                              kimot
                              wrote on last edited by kimot
                              @hard-shovel
                              But mesh is on other direction too - parallel with movement and sure not still at the same position and pure parallel.
                              So digital signal can be generated longer time than you expected.
                              12.0k
