  3. My very first mysensors node!
3 Posts 2 Posters 1.6k Views 2 Watching
  • M Offline
    M Offline
    Misna
    Hi!
    I'm starting my home automation journey and the architecture will be autonomous mysensors-nodes also controlled by Home Assistant.
    Maybe some sonoff's for some special needs.
    My house has 3 floors and the middle floor is 100% renovated 5 years ago so there I have to make compromises but the other two floors we are renovating and also recabling all the electrics so it's easy to get all cables routed to a central place for automation control.
    I already have Home Assistant running a few months and its collecting sensor data from my geothermal heat pump, UPS device and some software running on my home server.
    This first node is a kind on POC and wife approval node. It goes to a hallway in my basement which we are renovating at the moment.
    The node has:
    • 5V power from the AIO (maybe I'll need a fuse? or this https://www.openhardware.io/view/504/HLK-PM01-breakout-board)
    • Arduino Pro Mini 5V for the brains
    • NRF24 radio
    • DHT22 for temperature and humidity
    • A relay to control lights
    • Standard Finnish light switch (existing one)
    • Hall sensor for laundry room door
    The idea is to make the system fault tolerant and not dependant of Home Assistant which I have to update from time to time and which runs on RPi3 which can fail.
    Other nodes I'm planning:
    • Water pump monitoring and control
    • Electricity monitor
    • Freezer monitoring
    • Laundry room machines monitoring
    • Lights inside and outside of the house
    • Temperature sensors to all rooms
    • Control of under-floor heating valves (21 at the moment)
    • alowhumA Offline
      alowhumA Offline
      alowhum
      Congratulations :-)
      • M Offline
        M Offline
        Misna
        wrote on last edited by Misna
        I have problem now with Home Assistant and this node. It works perfectly reading temperature, humidity and the door status.
        But with the light switch if HA goes to a state where light status is "on" but brightness is "0" it doesn't respond until I manually set the brightness to "100". I tried this with mysensors library version 2.3.1 and 2.2.0 but the behaviour is the same. My gateway version is 2.1.0
        Here is the code for the node. There is nothing special on HA end. I'm running hass.io latest version 0.84.6 and lovelace GUI. Sorry for the comments in the code, they are part english and part finnish :)
        Just this issue to solve and one package from China and I'll get the power supplys and nodes ready. Then pretty soon I'll have 10 mysensors nodes running! I already started with some Sonoff's in the middle froor, four now installed and one waiting for a suitable application.
          * NODE ID: 2
          * Tämä on alasisäeteisen node jossa on:
          * - DHT22 -> lämpö ja kosteus
          * - Releohjaus sisäeteisen valoille (kytkin+rele)
          * - Ovitunnistin (hall-anturi)
          * Kytkennät:
          * - 5=DHT22
          * - 4=Releohjaus
          * - 3=Yläkerran valokytkin
          * - 6=Alakerran valokytkin
          * - 2=Ovitunnistin
        // Enable debug prints
        // Noden ID (oltava kaikissa eri!!)
        #define MY_NODE_ID 2
        #define MY_RADIO_RF24
        #define MY_REPEATER_FEATURE
        #include <SimpleTimer.h>
        #define DOOR_PIN  2 // Ovikytkin
        #define BUTTON_PIN  3  // Yläkerran valokytkin
        #define BUTTON_PIN_2  6  // Alakerran valokytkin
        #define RELAY_PIN  4 // Rele (valo)
        #define DHT_DATA_PIN 5 // Lämpötila-anturi DHT22
        #define CHILD_ID_LIGHT 1
        #define CHILD_ID_HUM 2
        #define CHILD_ID_TEMP 3
        #define CHILD_ID_DOOR 4
        #define LIGHT_OFF 0
        #define LIGHT_ON 1
        #define RELAY_ON 0
        #define RELAY_OFF 1
        #define DOOR_CLOSED 0
        #define DOOR_OPEN 1
        #define SENSOR_TEMP_OFFSET 0 // DHT22 lämpötilan offsetti
        #define SN "kellari_sisaeteinen"
        #define SV "1.2"
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        int16_t last_state = LIGHT_OFF;
        int16_t last_dim = 0;
        // Yläkerran valokytkimen luku
        Bounce debouncer = Bounce();
        // Alakerran valokytkimen luku
        Bounce debouncer_2 = Bounce();
        // Ovikytkimen luku
        Bounce ovidebouncer = Bounce();
        // Lämpötila-anturin oliot
        DHT dht;
        SimpleTimer timer;
        MyMessage light_msg( CHILD_ID_LIGHT, V_STATUS );
        MyMessage dimmer_msg( CHILD_ID_LIGHT, V_PERCENTAGE );
        MyMessage msgOvi(CHILD_ID_DOOR, V_TRIPPED);
          update_light();
          //Serial.println( "Node ready to receive messages..." );
          // Setup the buttons
          pinMode(BUTTON_PIN,INPUT);
          pinMode(BUTTON_PIN_2,INPUT);
          // Activate internal pull-up
          digitalWrite(BUTTON_PIN_2,HIGH);
          pinMode(RELAY_PIN, OUTPUT);
          debouncer.attach(BUTTON_PIN, INPUT_PULLUP);
          debouncer.interval(25);
          debouncer_2.attach(BUTTON_PIN_2, INPUT_PULLUP);
          debouncer_2.interval(25);
          // Ovikytkin
          ovidebouncer.attach(DOOR_PIN, INPUT_PULLUP);
          ovidebouncer.interval(25);
          // Timer lämpötila-anturin lukemista varten (millisekunteja) eli luetaan 1min välein
          timer.setInterval(60000, lampotilaLuku);
          //In MySensors2.x, first message must come from within loop()
          static bool first_message_sent = false;
          if ( first_message_sent == false )
            //Serial.println( "Sending initial state..." );
            send_dimmer_message();
            send_status_message();
            lampotilaLuku();
            send(msgOvi.set(DOOR_CLOSED));
            first_message_sent = true;
          debouncer.update(); // Update the Bounce instance (yläkerran valokytkin)
          // Laskevan reunan tunnistus (yläkerran valokytkin)
          if ( debouncer.fell() )
            //Serial.println( "Laskeva reuna" );
            nappiPainettu(); // Valon ohjaus
          // Nousevan reunan tunnistus (yläkerran valokytkin)
          if ( debouncer.rose() )
            //Serial.println( "Nouseva reuna" );
          debouncer_2.update(); // Update the Bounce instance (alakerran valokytkin)
          // Laskevan reunan tunnistus (alakerran valokytkin)
          if ( debouncer_2.fell() )
          // Nousevan reunan tunnistus (alakerran valokytkin)
          if ( debouncer_2.rose() )
          // Ovitunnistimen luku
          if (ovidebouncer.update())
            // Get the update value.
            int value = ovidebouncer.read();
            // Send in the new value.
            //Serial.println( "Oven status muuttui" );
            send(msgOvi.set(value==HIGH ? 1 : 0));
          // Lämpötila-anturin timer pyörii..
          timer.run();
          sendSketchInfo( SN, SV );
          present( CHILD_ID_LIGHT, S_DIMMER );
          present(CHILD_ID_HUM, S_HUM);
          present(CHILD_ID_DOOR, S_DOOR);
          metric = true; // Lämpötila-anturi
        // Vastaanotetaan HA:lta komentoja
          //When receiving a V_STATUS command, switch the light between OFF
          //and the last received dimmer value
          // Tämä on ON/OFF viesti HA:lta
          if ( message.type == V_STATUS )
            //Serial.println( "V_STATUS command received..." );
            int lstate = message.getInt();
            if (( lstate < 0 ) || ( lstate > 1 )) {
              //Serial.println( "V_STATUS data invalid (should be 0/1)" );
              return;
            last_state = lstate;
            //If last dimmer state is zero, set dimmer to 100
            if (( last_state == LIGHT_ON ) && ( last_dim == 0 ))
              last_dim=100;
            //Update constroller status
          // Tämä on himmennys viesti HA:lta
          else if ( message.type == V_PERCENTAGE )
            //Serial.println( "V_PERCENTAGE command received..." );
            int dim_value = constrain( message.getInt(), 0, 100 );
            if ( dim_value == 0 ) {
              //Update constroller with dimmer value & status
              last_state = LIGHT_ON;
              last_dim = dim_value;
            //Serial.println( "Invalid command received..." );
            return;
          //Here you set the actual light state/level
          update_light();
        // Releen ohjaus statuksen perusteella
        void update_light()
          if ( last_state == LIGHT_OFF )
            //Serial.println( "Light state: OFF" );
            //Serial.print( "Light state: ON, Level: " );
            //Serial.println( last_dim );
            digitalWrite(RELAY_PIN, RELAY_ON);
        // Lähetetään HA:lle dimmer arvo
        void send_dimmer_message()
          send( dimmer_msg.set( last_dim ) );
        // Lähetetään HA:lle valon status (ON/OFF)
        void send_status_message()
          if ( last_state == LIGHT_OFF ) {
            send( light_msg.set( (int16_t)0) );
            send( light_msg.set( (int16_t)1) );
        // Luetaan DHT22 arvot
        void lampotilaLuku()
          dht.readSensor(true);
          if (isnan(temperature)) {
            //Serial.println("Failed reading temperature from DHT!");
            lastTemp = temperature;
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            //Serial.print("T: ");
            //Serial.println(temperature);
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            //Serial.println("Failed reading humidity from DHT");
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            //Serial.print("H: ");
            //Serial.println(humidity);
            nNoUpdatesHum++;
        // Napin painon jälkeen valon ohjaus ja statuksen päivitys
        void nappiPainettu()
          if (last_state == LIGHT_ON)
            //Serial.println( "Valo OFF napista" );
            last_dim=0;
            update_light(); // Releen toggle
            //Serial.println( "Valo ON napista" );
            last_dim=100;
          //Serial.println( "Lahetetaan HA:lle uusi status" );
          send_status_message(); // Lähetä HA:lle uusi status (ON/OFF)
          send_dimmer_message(); // Lähetä HA:lle uusi dim arvo (0/100)
        Here are parts concerning from configuration.yaml file:
        # Mysensors serial gateway config
        mysensors:
          gateways:
            - device: '/dev/ttyACM0'
              baud_rate: 115200
              persistence_file: '/config/mysensors.json'
          optimistic: false
          persistence: true
          version: 2.0
