  3. Gateway MQTT with RFM69
gateway mqtt rfm69
9 Posts 4 Posters 1.9k Views 3 Watching
  • M Offline
    M Offline
    miclane
    I'm trying to make an MQTT gateway with an arduino uno, a HanRun HR911105A shield and an RFM69.
    I am in version 2.3.1 of MySensors.
    I realized for several years this type of gateway with NRF24 + which works without problem.
    With the RFM69, if I put the MISO cable at 12, the MQTT connection tries to wait for incomprehensible IP addresses but the RFM69 starts up well.
    If I remove the MISO, the MQTT connection is at the correct address and works but of course the RFM69 does not start.
    I tried cabling the RST on the GND of the shield but always the same.
    I looked a lot of post but I did not find anything to deal with the problem.
    Any ideas ? an advice ? an experiment ?
    Thanks in advance.
    mfalkviddM Y 2 Replies Last reply
    • M miclane
      Thanks in advance.
      @miclane HR911105A is known to have trouble sharing the SPI bus. The general recommendation is to use softspi. See https://www.mysensors.org/build/ethernet_gateway for the wiring and defines.
      • M Offline
        M Offline
        miclane
        Thank you for your reply.
        But I do not see anything on the page indicated which corresponds to the pinning for an RFM69.
        I tried to compose with this page and the RFM69 pinouts but I get the same results.
        Either the ethernet part works but not the radio part.
        Either the radio part works but not the ethernet part.
        Is this configuration really operational?
        Because a lot of post does not seem to have managed to make it work.
        Cordially.
        • M miclane
          Cordially.
          @miclane yes you are right, there are no instructions for rfm69. Sorry.
          I have very little experience with rfm69, no experience with the ethernet shield, no experience with softspi and no experience with mqtt. Hopefully someone else can help.
          • M miclane
            Thanks in advance.
            Y Offline
            Y Offline
            @miclane said in Gateway MQTT with RFM69:
            HanRun HR911105A
            This only tells what ethernet jack is on the board. Do you have more information on your ethernet shield? (specs, schematics, or even a picture?)
            What changed (apart from the mySensors library version) since then?
            Please share your sketch and a startup debug log.
            • M Offline
              M Offline
              miclane
              1. Yes, there is of course the RJ45 plug on the shield which fits directly by the arduino UNO. The only indications are HanRun HR911105A 15/10.
              2. What has changed is that I have always used NRF24 +. The gateway that I use in operation at home is also in version MySensors 2.3.1 with NRF24+
              3. I use the basic sketch on the site :
              #define MY_TRANSPORT_WAIT_READY_MS 10000
              #define MY_RADIO_RFM69
              #define MY_RF69_SPI_CS 9
              #define MY_GATEWAY_W5100
              #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mhs-pub-1"
              #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mhs-sub-1"
              #define MY_MQTT_CLIENT_ID "MHS_GW_02"
              #define MY_MQTT_USER "xxxxxx"
              #define MY_MQTT_PASSWORD "yyyyyyyy"
              #define MY_IP_ADDRESS 12,9,0,101
              #define MY_IP_GATEWAY_ADDRESS 12,9,0,1
              #define MY_CONTROLLER_IP_ADDRESS 12,9,0,8
              #define MY_PORT 1883
              #include <Ethernet.h>
              void setup() {}
              void presentation() {}
              void loop() {}
              Thank you.
              • fritsF Offline
                fritsF Offline
                frits
                Hello @miclane,
                I'm currently building an MQTT Gateway with RFM69 and Wiznet W5100 module.
                Are you using the same ethernet module? Please read about the chip select/SEN issue:
                https://arduinodiy.wordpress.com/2017/04/12/the-w5100-bug/
                I've modified my module and both chips (RFM69, W5100) are starting up.
                Mapping:
                W5100-MO = RFM69-MOSI = D11
                W5100-MI = RFM69-MISO =  D12
                W5100-SCK = RFM69-SCK = D13
                W5100-NSS = D10
                RFM69-NSS = A0
                RFM69-DI00 = D02
                Defines:
                #define MY_IS_RFM69HW  // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
                #define MY_RF69_SPI_CS 14
                #define MY_W5100_SPI_EN 10
                • M Offline
                  M Offline
                  miclane
                  Thank you for your very clear answer.
                  I will test by getting a MOSFET.
                  Have a good day.
                  • fritsF Offline
                    fritsF Offline
                    frits
                    just wanted to add that my W5100/RFM69 ethernet gateway works - but I had to patch two lines in the Ethernet library (w5100.h), see
                    https://forum.mysensors.org/topic/6330/still-searching-for-a-working-ethernet-gw-with-rfm69/8
                    Now I'll see if the MQTT gateway works, too...
                    12.1k
