  3. MYSController for RPi?
10 Posts 5 Posters 2.2k Views 4 Watching
  • jimbolayaJ
    jimbolayaJ
    jimbolaya
    Is there such a version? I’d like to try FOTA but don’t have a Windows machine. Thanks!
    Jim
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      try MyController, it works on linux. You can even run it on rpi, but I would not recommend it since it is quite resource hungry.
      • jimbolayaJ
        jimbolayaJ
        jimbolaya
        wrote on last edited by jimbolaya
        Is that just a controller or can it also upload firmware?
        Jim
        mfalkviddM G 2 Replies Last reply
        • jimbolayaJ jimbolaya
          @jimbolaya It can upload firmware. See https://www.mysensors.org/controller/mycontroller for more information.
            G
            G
            Guillermo Schimmel
            @jimbolaya It can upload firmware. I'm just doing the same as you. I run a very small virtual machine just for administration of nodes and firmware.
            • jimbolayaJ
              jimbolayaJ
              jimbolaya
              This looks like a great start. I use Domoticz and will stick with it for the z-wave support. Any experience using the two controllers on the same pi? Perhaps shut down Domoticz and then start MyController for the FOTA?
              Jim
              G S 2 Replies Last reply
                G
                G
                Guillermo Schimmel
                @jimbolaya if you use mqtt gateway you don't even need to stop one controller. You can use them all (if they support mqtt).
                I'm doing OpenHAB+Mycontroller.org+several local scripts.
                jimbolayaJ 1 Reply Last reply
                • G Guillermo Schimmel
                  jimbolayaJ
                  jimbolayaJ
                  jimbolaya
                  @guillermo-schimmel Is the same true for serial gateway?
                  Jim
                  G 1 Reply Last reply
                    G
                    G
                    Guillermo Schimmel
                    @jimbolaya
                    @jimbolaya said in MYSController for RPi?:
                    I don't know, but don't think so. It would be difficult for more than one program to take control of the serial port.
                      Sathishkumar Thangavel
                      @jimbolaya Or you can use https://github.com/tsathishkumar/MySController-rs A light weight controller which can be used for FOTA and act as a proxy for all other usages.
